Can't get online sources folder to show
AlVal
Post Fri Oct 25, 2013 9:06 pm
2013-10-25 21:35:53,632 INFO [PluginCompilerThread] Started looking for plugins
2013-10-25 21:35:54,941 INFO [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy), version: 2
2013-10-25 21:35:55,642 INFO [PluginCompilerThread] Added Web Resouce plugin ITVPlayer (UK only) (ITVPlayer.groovy), version: 3
so I have the latest iplayer and itvplayer plugins, and they are being loaded.
https://www.itv.com/itvplayer/emmerdale
added as a web resource (video) through console
http://feeds.bbc.co.uk/iplayer/categori ... ns/tv/list
also added as a web resource (video) through console
can't get an "online sources" folder to appear though, have checked both in mediabrowser web client, and android serviigo, and tv (samsung ue55c9000)
don't see anything wrong in the logs
am I missing something required to trigger the creation of the online sources folder? at what level is this folder supposed to appear?
AlVal
Post Fri Oct 25, 2013 9:15 pm
Re: Can't get online sources folder to show
Solved my own problem - in case it helps anyone else -
using console > presentation > video > online > display category obviously needs to be on!
