How do I play a video?
rogerdavis
Post Sat Oct 26, 2013 2:18 am
Hi, I installed Serviio. I added a few files to the library, one had an .avi and one a .mkv file.
I started the media browser and am asked for a sign in. I don't know the password to sign in, though. How do I receive one?
How do I play a video? I don't see a library anywhere on my computer or TV, a 2012 Panasonic Viera ST 50. I did choose the correct profile from the list.
Roger
Post Mon Oct 28, 2013 11:56 am
Re: How do I play a video?
MediaBrowser:
http://www.serviio.org/support/10-uncat ... diabrowser
TV:
There should be some media menu on the TV, maybe check the Panasonic forum for tips.
sleky
Post Mon Oct 28, 2013 5:54 pm
Can you browse the different categories on your TV? If not, you probably just need to enable the device in the console.
As far as the password, it is sent on the console. Under 'REMOTE'.
