Serviio Console won't launch
MelissaL48
Post Mon Oct 28, 2013 9:32 pm
I've just downloaded the latest version of Serviio and I'm having issues launching it
I am on Mac OS X 10.7.5
I double click on the Serviio console logo and the Serviio Console tab shows on the File tab ut then it disappears and Serviio won't launch
Im not that good with computers either :s
Anyone could help please?
sleky
Post Mon Oct 28, 2013 11:24 pm
Re: Serviio Console won't launch
Please see: http://serviio.org/component/content/article?id=21#q3 What you are looking to pass is the serviio.remoteHost property field.
OSX
Browse the contents of Serviio.app or Serviio-Console.app and open file Contents/Info.plist in TextEdit. To add the property insert these XML tags under Java/Properties/dict tree:
<key>property_name</key>
<string>property_value</string>
Here is my Info.plist.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<plist version="1.0">
  <dict>
    <key>CFBundleName</key>
    <string>Serviio-Console</string>
    <key>CFBundleShortVersionString</key>
    <string>1.3.1</string>
    <key>CFBundleGetInfoString</key>
    <string>1.3.1 (c) 2009 - 2013 Petr Nejedly</string>
    <key>CFBundleAllowMixedLocalizations</key>
    <string>false</string>
    <key>CFBundleInfoDictionaryVersion</key>
    <string>6.0</string>
    <key>CFBundleExecutable</key>
    <string>JavaApplicationStub</string>
    <key>CFBundleDevelopmentRegion</key>
    <string>English</string>
    <key>CFBundlePackageType</key>
    <string>APPL</string>
    <key>CFBundleSignature</key>
    <string>????</string>
    <key>CFBundleIconFile</key>
    <string>serviio.icns</string>
    <key>CFBundleIdentifier</key>
    <string>org.serviio.serviio-console</string>
    <key>CFBundleURLTypes</key>
    <array>                 <dict>               <key>CFBundleURLName</key>               <string>org.serviio.url</string>               <key>CFBundleURLSchemes</key>               <array>                <string>serviio</string>               </array>              </dict>             </array>
    <key>Java</key>
    <dict>
      <key>MainClass</key>
      <string>org.serviio.console.ServiioConsole</string>
      <key>JVMVersion</key>
      <string>1.6+</string>
      <key>ClassPath</key>
      <array>
        <string>$JAVAROOT/commons-codec.jar</string>
        <string>$JAVAROOT/jul-to-slf4j.jar</string>
        <string>$JAVAROOT/log4j.jar</string>
        <string>$JAVAROOT/org.restlet.ext.net.jar</string>
        <string>$JAVAROOT/org.restlet.ext.xstream.jar</string>
        <string>$JAVAROOT/org.restlet.jar</string>
        <string>$JAVAROOT/serviio-client.jar</string>
        <string>$JAVAROOT/serviio.jar</string>
        <string>$JAVAROOT/slf4j-api.jar</string>
        <string>$JAVAROOT/slf4j-log4j12.jar</string>
        <string>$JAVAROOT/xstream.jar</string>
        <string>$JAVAROOT/config</string>
      </array>
      <key>VMOptions</key>
      <string>-Xms5M -XX:+UseParNewGC -XX:MinHeapFreeRatio=5 -XX:MaxHeapFreeRatio=10</string>
      <key>Properties</key>
      <dict>
        <key>serviio.home</key>
        <string>$JAVAROOT</string>
        <key>java.net.preferIPv4Stack</key>
        <string>true</string>
        <key>serviio.remoteHost</key>
        <string>10.4.20.10</string>
      </dict>
    </dict>
  </dict>
</plist>
Post Wed Oct 30, 2013 9:31 pm
I don't think he wants to access the console remotely.
On OSX there is a problem with the icons staying/disappearing from the dock. Normally you start the server and then the console (the console one should open the configuration app)
Users browsing this forum: No registered users and 60 guests
