Samsung B series unsupported error
mrapoc
Post Tue Oct 29, 2013 12:47 am
Hey all :)
I cannot get my samsung to play 90% of my personally ripped movies..which is a shame
Can you help identify where its going wrong? I have the B series profile selected. Anyway for example:
A working file
Complete name                            : \\diskstation\Video\Movies\9\9.mp4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 3.29 GiB
Duration                                 : 1h 19mn
Overall bit rate                         : 5 930 Kbps
Encoded date                             : UTC 2010-09-13 21:20:32
Tagged date                              : UTC 2010-09-13 21:20:32
Format profile                           : High@L4.0
Format settings, ReFrames                : 3 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 1h 19mn
Bit rate                                 : 5 609 Kbps
Maximum bit rate                         : 25.0 Mbps
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.113
Stream size                              : 3.11 GiB (95%)
Title                                    : 9
Writing library                          : x264 core 98 r1643 59a9e03
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=25000 / crf_max=0.0 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr
Tagged date                              : UTC 2010-09-13 21:22:44
Codec ID                                 : 40
Duration                                 : 1h 19mn
Bit rate                                 : 317 Kbps
Maximum bit rate                         : 336 Kbps
Original Channel count                   : 6 channels
Stream size                              : 180 MiB (5%)
Title                                    : Imported with GPAC 0.4.6-DEV (internal rev. 5)
Encoded date                             : UTC 2010-09-13 21:22:31
Menu
And one of the none working files
Complete name                            : \\diskstation\Video\Movies\127 Hours\127 Hours.mp4
Codec ID                                 : isom
File size                                : 1.60 GiB
Duration                                 : 1h 29mn
Overall bit rate                         : 2 548 Kbps
Encoded date                             : UTC 2012-01-05 00:42:26
Tagged date                              : UTC 2012-01-05 00:42:26
Codec ID                                 : avc1
Duration                                 : 1h 29mn
Bit rate                                 : 2 227 Kbps
Width                                    : 720 pixels
Height                                   : 576 pixels
Frame rate                               : 25.000 fps
Standard                                 : PAL
Bits/(Pixel*Frame)                       : 0.215
Stream size                              : 1.40 GiB (87%)
Title                                    : 127 Hours
Writing library                          : x264 core 114 r1924 08d04a4
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Tagged date                              : UTC 2012-01-05 00:43:07
Codec ID                                 : 40
Duration                                 : 1h 29mn
Bit rate                                 : 317 Kbps
Stream size                              : 204 MiB (12%)
Encoded date                             : UTC 2012-01-05 00:42:59
Menu
00:00:00.000                             : Chapter 1
00:06:35.160                             : Chapter 2
00:14:06.120                             : Chapter 3
00:19:51.960                             : Chapter 4
00:28:21.560                             : Chapter 5
00:34:10.240                             : Chapter 6
00:43:55.480                             : Chapter 7
00:49:53.240                             : Chapter 8
00:53:47.480                             : Chapter 9
00:59:56.480                             : Chapter 10
01:03:58.600                             : Chapter 11
01:09:22.400                             : Chapter 12
01:15:47.800                             : Chapter 13
01:19:58.640                             : Chapter 14
01:23:13.760                             : Chapter 15
01:25:45.880                             : Chapter 16
Any help appreciated :)
mrapoc
Post Tue Oct 29, 2013 4:58 pm
Re: Samsung B series unsupported error
A bit more info for you:
ffmpeg
C:\Program Files\Serviio\lib>ffmpeg.exe -i "\\DISKSTATION\Video\Movies\127 Hours
\127 Hours.mp4"
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '\\DISKSTATION\Video\Movies\127 Hours\12
7 Hours.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2012-01-05 00:42:26
  Duration: 01:29:50.98, start: 0.000000, bitrate: 2547 kb/s
    Chapter #0.0: start 0.000000, end 395.160000
      title           : Chapter 1
    Chapter #0.1: start 395.160000, end 846.120000
      title           : Chapter 2
    Chapter #0.2: start 846.120000, end 1191.960000
      title           : Chapter 3
    Chapter #0.3: start 1191.960000, end 1701.560000
      title           : Chapter 4
    Chapter #0.4: start 1701.560000, end 2050.240000
      title           : Chapter 5
    Chapter #0.5: start 2050.240000, end 2635.480000
      title           : Chapter 6
    Chapter #0.6: start 2635.480000, end 2993.240000
      title           : Chapter 7
    Chapter #0.7: start 2993.240000, end 3227.480000
      title           : Chapter 8
    Chapter #0.8: start 3227.480000, end 3596.480000
      title           : Chapter 9
    Chapter #0.9: start 3596.480000, end 3838.600000
      title           : Chapter 10
    Chapter #0.10: start 3838.600000, end 4162.400000
      title           : Chapter 11
    Chapter #0.11: start 4162.400000, end 4547.800000
      title           : Chapter 12
    Chapter #0.12: start 4547.800000, end 4798.640000
      title           : Chapter 13
    Chapter #0.13: start 4798.640000, end 4993.760000
      title           : Chapter 14
    Chapter #0.14: start 4993.760000, end 5145.880000
      title           : Chapter 15
    Chapter #0.15: start 5145.880000, end 5390.975000
      title           : Chapter 16
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 720x576 [
SAR 64:45 DAR 16:9], 2226 kb/s, 25 fps, 25 tbr, 100 tbn, 50 tbc
      handler_name    : 127 Hours
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 317 k
b/s
      creation_time   : 2012-01-05 00:42:59
Post Tue Oct 29, 2013 5:17 pm
compare the encoding settings above side by side I guess
mrapoc
Post Tue Oct 29, 2013 7:08 pm
Here is a detailed log of whats going on. Appears it isn't transcoding? Well thats how I interpret it when it says
Delivering file '2012.mp4' in native format
2013-10-29 18:51:30,216 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2013-10-29 18:51:33,592 DEBUG [ServiioHttpService] Incoming request from /192.168.1.9:2808: HEAD /resource/128/MEDIA_ITEM/AVC_MP4_MP_HD_1080i_AAC-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2013-10-29 18:51:33,592 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,593 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,594 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,594 DEBUG [ResourceDeliveryProcessor] Request for resource 128 and type 'MEDIA_ITEM' received
2013-10-29 18:51:33,594 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,594 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,595 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,596 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 128, format AVC_MP4_MP_HD_1080i_AAC and profile Samsung TV (B-series)
2013-10-29 18:51:33,597 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,597 DEBUG [MediaItemDAOImpl] Getting file of media item 128
2013-10-29 18:51:33,615 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 4033561539,Date: Tue, 29 Oct 2013 18:51:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_HD_1080i_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2013-10-29 18:51:33,621 DEBUG [ServiioHttpService] Incoming request from /192.168.1.9:2519: HEAD /resource/128/MEDIA_ITEM/AVC_MP4_MP_HD_1080i_AAC-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,getMediaInfo.sec: 1,Host: 192.168.1.4:8895]]
2013-10-29 18:51:33,621 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,622 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,622 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,622 DEBUG [ResourceDeliveryProcessor] Request for resource 128 and type 'MEDIA_ITEM' received
2013-10-29 18:51:33,622 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,623 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,623 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,624 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 128, format AVC_MP4_MP_HD_1080i_AAC and profile Samsung TV (B-series)
2013-10-29 18:51:33,624 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 4033561539,Date: Tue, 29 Oct 2013 18:51:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_HD_1080i_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,MediaInfo.sec: SEC_Duration=9469000;]]
2013-10-29 18:51:33,637 DEBUG [ServiioHttpService] Incoming request from /192.168.1.9:3233: GET /resource/128/MEDIA_ITEM/AVC_MP4_MP_HD_1080i_AAC-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.4:8895]]
2013-10-29 18:51:33,637 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,638 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,638 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,638 DEBUG [ResourceDeliveryProcessor] Request for resource 128 and type 'MEDIA_ITEM' received
2013-10-29 18:51:33,638 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,638 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,639 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,640 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 128, format AVC_MP4_MP_HD_1080i_AAC and profile Samsung TV (B-series)
2013-10-29 18:51:33,640 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,640 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,641 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,642 DEBUG [VideoDeliveryEngine] Delivering item '128' for client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,642 DEBUG [VideoDeliveryEngine] Delivering file '2012.mp4' in native format
2013-10-29 18:51:33,642 DEBUG [MediaItemDAOImpl] Getting file of media item 128
2013-10-29 18:51:33,649 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 128) as read
2013-10-29 18:51:33,651 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-29 18:51:33,651 DEBUG [GETMethodProcessor] Stream entity has length: 4033561539
2013-10-29 18:51:33,651 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 4033561539,Date: Tue, 29 Oct 2013 18:51:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 0-4033561538/4033561539,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_HD_1080i_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-29 18:51:33,670 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2013-10-29 18:51:33,675 DEBUG [ServiioHttpService] Incoming request from /192.168.1.9:3392: GET /resource/128/MEDIA_ITEM/AVC_MP4_MP_HD_1080i_AAC-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=24-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.4:8895]]
2013-10-29 18:51:33,675 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,676 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,676 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,676 DEBUG [ResourceDeliveryProcessor] Request for resource 128 and type 'MEDIA_ITEM' received
2013-10-29 18:51:33,677 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,677 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,677 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,678 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 128, format AVC_MP4_MP_HD_1080i_AAC and profile Samsung TV (B-series)
2013-10-29 18:51:33,678 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,678 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,679 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,680 DEBUG [VideoDeliveryEngine] Delivering item '128' for client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,680 DEBUG [VideoDeliveryEngine] Delivering file '2012.mp4' in native format
2013-10-29 18:51:33,680 DEBUG [MediaItemDAOImpl] Getting file of media item 128
2013-10-29 18:51:33,682 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 128) as read
2013-10-29 18:51:33,684 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-29 18:51:33,684 DEBUG [GETMethodProcessor] Stream entity has length: 4033561515
2013-10-29 18:51:33,684 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 4033561515,Date: Tue, 29 Oct 2013 18:51:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 24-4033561538/4033561539,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_HD_1080i_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-29 18:51:33,696 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-29 18:51:33,700 DEBUG [ServiioHttpService] Incoming request from /192.168.1.9:4771: GET /resource/128/MEDIA_ITEM/AVC_MP4_MP_HD_1080i_AAC-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=4153135-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.4:8895]]
2013-10-29 18:51:33,700 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,701 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,701 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,701 DEBUG [ResourceDeliveryProcessor] Request for resource 128 and type 'MEDIA_ITEM' received
2013-10-29 18:51:33,701 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,701 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,702 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,703 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 128, format AVC_MP4_MP_HD_1080i_AAC and profile Samsung TV (B-series)
2013-10-29 18:51:33,703 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,703 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,703 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,704 DEBUG [VideoDeliveryEngine] Delivering item '128' for client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,704 DEBUG [VideoDeliveryEngine] Delivering file '2012.mp4' in native format
2013-10-29 18:51:33,704 DEBUG [MediaItemDAOImpl] Getting file of media item 128
2013-10-29 18:51:33,706 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 128) as read
2013-10-29 18:51:33,708 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-29 18:51:33,709 DEBUG [GETMethodProcessor] Stream entity has length: 4029408404
2013-10-29 18:51:33,709 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 4029408404,Date: Tue, 29 Oct 2013 18:51:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 4153135-4033561538/4033561539,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_HD_1080i_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-29 18:51:33,722 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-29 18:51:33,726 DEBUG [ServiioHttpService] Incoming request from /192.168.1.9:3303: GET /resource/128/MEDIA_ITEM/AVC_MP4_MP_HD_1080i_AAC-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=4033561484-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.4:8895]]
2013-10-29 18:51:33,726 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,727 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,727 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,727 DEBUG [ResourceDeliveryProcessor] Request for resource 128 and type 'MEDIA_ITEM' received
2013-10-29 18:51:33,727 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,727 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,728 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,729 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 128, format AVC_MP4_MP_HD_1080i_AAC and profile Samsung TV (B-series)
2013-10-29 18:51:33,729 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,729 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,730 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,730 DEBUG [VideoDeliveryEngine] Delivering item '128' for client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,730 DEBUG [VideoDeliveryEngine] Delivering file '2012.mp4' in native format
2013-10-29 18:51:33,730 DEBUG [MediaItemDAOImpl] Getting file of media item 128
2013-10-29 18:51:33,733 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 128) as read
2013-10-29 18:51:33,734 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-29 18:51:33,734 DEBUG [GETMethodProcessor] Stream entity has length: 55
2013-10-29 18:51:33,735 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Length: 55,Date: Tue, 29 Oct 2013 18:51:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 4033561484-4033561538/4033561539,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_HD_1080i_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-29 18:51:33,745 DEBUG [WebServer] I/O error: Connection reset
2013-10-29 18:51:33,749 DEBUG [ServiioHttpService] Incoming request from /192.168.1.9:3194: GET /resource/128/MEDIA_ITEM/AVC_MP4_MP_HD_1080i_AAC-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.4:8895]]
2013-10-29 18:51:33,749 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,750 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.9
2013-10-29 18:51:33,750 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,750 DEBUG [ResourceDeliveryProcessor] Request for resource 128 and type 'MEDIA_ITEM' received
2013-10-29 18:51:33,750 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,750 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,751 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,752 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 128, format AVC_MP4_MP_HD_1080i_AAC and profile Samsung TV (B-series)
2013-10-29 18:51:33,752 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 128 (local)
2013-10-29 18:51:33,752 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 128)
2013-10-29 18:51:33,752 DEBUG [VideoDAOImpl] Reading a Video (id = 128)
2013-10-29 18:51:33,753 DEBUG [VideoDeliveryEngine] Delivering item '128' for client 'Identifier=192.168.1.9, Profile=Samsung TV (B-series)'
2013-10-29 18:51:33,753 DEBUG [VideoDeliveryEngine] Delivering file '2012.mp4' in native format
2013-10-29 18:51:33,753 DEBUG [MediaItemDAOImpl] Getting file of media item 128
2013-10-29 18:51:33,755 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 128) as read
2013-10-29 18:51:33,757 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-29 18:51:33,757 DEBUG [GETMethodProcessor] Stream entity has length: 4033561539
2013-10-29 18:51:33,757 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 4033561539,Date: Tue, 29 Oct 2013 18:51:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_HD_1080i_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-29 18:51:34,102 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
This is all new to me but I'm getting to grips with it. So sounds like something in the file isn't triggering transcoding in the profile for the B series. Hmm both files were ripped from bluray and encoded using ripbot264 but it seems the version is slightly different. Any pointers :)
Looking at the comparison side by side one which caught my eye was the difference between
Red being the one that doesn't work
If not that the only difference is FPS and these two
Post Wed Oct 30, 2013 8:06 am
mrapoc wrote:...
Does video track is encoded or copied when you rip your movie? what is the software used?
The problem could be also on mp4 container (not only video track).
Do you try to remux your mp4 to a new mp4 container with ffmpeg processor? (something like ffmpeg -i INPUT.mp4 -v:c copy -a:c copy -f mp4 OUTPUT.mp4 )
mrapoc
Post Wed Oct 30, 2013 4:17 pm
Rip using AnyDVD HD to raw bluray files.
Use ripbot264 to encode to .mp4 h.264 - I followed the same process for both titles. I'll try to remux and see if that makes a difference. Will I lose quality? Or will it literally just put it in a new container?
mrapoc
Post Wed Oct 30, 2013 9:37 pm
Success!
ffmpeg -i video.mp4 -acodec copy -vcodec copy newvideo.mp4
Enables the video to play so it didn't like that library version...so the latest h.264 works!
Post Thu Oct 31, 2013 8:00 am
mrapoc wrote:Will I lose quality? Or will it literally just put it in a new container?
No lose of quality, simply a new container remuxing...
mrapoc wrote:Success!
So, that's confirm that something in the mp4 container is weird. All video/h264 and audio codec are good.
mrapoc
Post Sun Nov 03, 2013 10:08 pm
Ok so that one plays - but at the wrong aspect ratio! :(
The next one I tried didn't play, so I remuxed and it still doesn't play. :(
Mediainfo as follows:
Complete name                            : \\diskstation\Video\Movies\2012\2012 Copy.mp4
Codec ID                                 : isom
File size                                : 3.76 GiB
Duration                                 : 2h 37mn
Overall bit rate                         : 3 409 Kbps
Writing application                      : Lavf55.19.104
Codec ID                                 : avc1
Duration                                 : 2h 37mn
Bit rate                                 : 3 084 Kbps
Bits/(Pixel*Frame)                       : 0.062
Stream size                              : 3.40 GiB (90%)
Writing library                          : x264 core 125 r2208 d9d2288
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Codec ID                                 : 40
Duration                                 : 2h 37mn
Bit rate                                 : 320 Kbps
Stream size                              : 361 MiB (9%)
Whereas this bluray rip works fine
Codec ID                                 : isom
Duration                                 : 1h 19mn
Codec ID                                 : avc1
Duration                                 : 1h 19mn
Title                                    : 9
Codec ID                                 : 40
Duration                                 : 1h 19mn
Bit rate                                 : 317 Kbps
Menu
Both ripped using exactly the same method
mrapoc
Post Sun Nov 10, 2013 2:15 pm
Can't get it to work on the LE40B650
Using Samsung B profile it just doesn't seem to transcode (correctly) so I may just have to install my ps3 downstairs as a workaround :(
All of the media server software I have tried doesn't work with this damn tv!
Users browsing this forum: capitain_jack and 24 guests
