MKV subtitles not playing
kitjai
Post Thu Oct 31, 2013 7:45 am
Hi All,
thankyou for creating such a good piece of software. I have a minor issue which doesn't allow me to play embedded subtitles from my MKV file on PC running Serviio to my Sony Bravia KDLHX850.
The file plays well, however the subtitles dont show :(
The file is located on the same HDD that serviio runs on.
Could someone please help me?
Regards
Kitjai
here is the ffmpeg.exe -i on the file:
c:\Program Files\Serviio\lib>ffmpeg.exe -i "E:\Naruto\Shippuuden\[HorribleSubs]
Naruto Shippuuden - 100 [480p].mkv"
ffmpeg version N-57650-gcb52d6d Copyright (c) 2000-2013 the FFmpeg developers
  built on Oct 30 2013 20:29:47 with gcc 4.8.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aa
cenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavp
ack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil      52. 48.100 / 52. 48.100
  libavcodec     55. 39.100 / 55. 39.100
  libavformat    55. 19.104 / 55. 19.104
  libavdevice    55.  5.100 / 55.  5.100
  libavfilter     3. 90.100 /  3. 90.100
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 17.104 /  0. 17.104
Input #0, matroska,webm, from 'E:\Naruto\Shippuuden\[HorribleSubs] Naruto Shippu
uden - 100 [480p].mkv':
    creation_time   : 2009-03-12 11:04:42
  Duration: 00:23:11.08, start: 0.000000, bitrate: 729 kb/s
    Stream #0:0: Video: h264 (High), yuv420p, 848x480, SAR 171:170 DAR 3021:1700
, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1: Audio: aac, 44100 Hz, stereo, fltp (default)
    Stream #0:2: Subtitle: ssa (default)
Codec 0x18000 is not in the full list.
    Stream #0:3: Attachment: unknown_codec
      filename        : BAARS___.TTF
      mimetype        : application/x-truetype-font
Here is a pic for the console:
Media info:
Unique ID                                : 238328314325565291156943066798099079816 (0xB34C5D1C75679E49BCD9BC7109F92288)
Complete name                            : E:\Naruto.mkv
File size                                : 143 MiB
Duration                                 : 23mn 9s
Overall bit rate                         : 866 Kbps
Encoded date                             : UTC 2013-10-24 11:02:39
Writing application                      : mkvmerge v5.2.0 ('I can't explain') built on Dec 18 2011 18:12:03
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Attachment                               : Yes
Format profile                           : Main@L3.1
Format settings, ReFrames                : 6 frames
Duration                                 : 23mn 9s
Nominal bit rate                         : 768 Kbps
Width                                    : 848 pixels
Height                                   : 480 pixels
Bits/(Pixel*Frame)                       : 0.079
Writing library                          : x264 core 120 r2120 0c7dab9
Encoding settings                        : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x1:0x111 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=768 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=1536 / vbv_bufsize=3840 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.60
Forced                                   : Yes
Codec ID                                 : A_AAC
Duration                                 : 23mn 9s
Sampling rate                            : 44.1 KHz
Forced                                   : Yes
Text
Format                                   : ASS
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Compression mode                         : Lossless
Forced                                   : Yes
Thanks Again
kitjai
kitjai
Post Thu Oct 31, 2013 7:47 am
Re: MKV subtitles not playing
detailed log:
2013-10-31 18:38:39,917 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:39,917 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:39,919 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:39,920 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:39 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:39,926 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49027: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:39,926 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:39,927 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:39,927 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:39,927 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:39,927 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:39,928 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:39,928 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:39,928 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:39,930 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:39,931 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:39,931 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:39,933 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:39,933 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:39,933 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:39,933 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:39,934 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:39,934 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:39,935 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:39,937 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:39,937 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:39,938 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:39,939 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:39,940 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\Naruto\Shippuuden\[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:39,940 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -threads auto -i E:\Naruto\Shippuuden\[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv -y -threads auto -c:v copy -bsf:v h264_mp4toannexb -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-2388-sony2012-ORIGINAL.stf
2013-10-31 18:38:40,440 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-10-31 18:38:40,441 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:40,443 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:40,443 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2388) as read
2013-10-31 18:38:40,451 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-31 18:38:40,451 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:40,451 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:40,451 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:40 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-1391/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:42,651 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:42,668 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49028: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=73.620-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:42,669 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:42,669 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:42,669 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:42,669 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:42,669 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:42,669 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:42,670 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:42,670 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:42,671 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:42,673 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:42,673 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:42,674 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:42,674 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:42,674 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:42,675 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:42,675 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:42,675 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:42,676 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:42,678 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:42,678 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:42,679 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:42,679 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-10-31 18:38:42,680 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:42,681 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:42,682 DEBUG [GETMethodProcessor] Delivering bytes 11693056 - 50000000000 from transcoded file, based on time range 73.62 - 1391.0
2013-10-31 18:38:42,682 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:42,682 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:42,682 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:42 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=73.62-1391/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:50,782 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:50,790 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49029: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=86.087-87.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:50,790 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:50,791 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:50,791 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:50,791 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:50,791 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:50,791 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:50,791 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:50,791 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:50,791 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:50,793 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:50,794 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:50,794 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:50,796 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:50,796 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:50,796 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:50,796 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:50,796 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:50,796 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:50,798 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:50,799 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:50,799 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:50,801 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:50,801 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-10-31 18:38:50,801 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:50,802 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:50,802 DEBUG [GETMethodProcessor] Delivering bytes 14597120 - 50000000000 from transcoded file, based on time range 86.087 - 87.087
2013-10-31 18:38:50,802 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:50,803 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:50,803 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=86.087-87.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:51,284 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:51,285 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49030: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=91.087-92.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:51,285 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:51,285 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:51,285 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:51,285 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:51,286 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:51,286 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:51,286 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:51,286 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,288 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,289 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:51,289 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,291 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:51,291 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:51,291 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:51,291 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:51,292 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:51,292 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,295 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,297 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:51,297 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,298 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:51,346 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-10-31 18:38:51,346 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,348 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:51,348 DEBUG [GETMethodProcessor] Delivering bytes 15762432 - 50000000000 from transcoded file, based on time range 91.087 - 92.087
2013-10-31 18:38:51,348 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:51,348 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:51,348 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=91.087-92.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:51,781 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:51,783 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49031: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=96.087-97.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:51,783 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:51,784 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:51,784 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:51,784 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:51,784 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:51,784 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:51,784 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:51,784 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,786 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,787 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:51,787 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,789 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:51,789 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:51,789 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:51,789 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:51,790 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:51,790 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,791 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,793 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:51,793 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,794 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:51,795 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-10-31 18:38:51,795 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:51,796 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:51,796 DEBUG [GETMethodProcessor] Delivering bytes 16927744 - 50000000000 from transcoded file, based on time range 96.087 - 97.087
2013-10-31 18:38:51,797 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:51,797 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:51,797 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=96.087-97.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:52,284 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:52,285 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49032: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=101.087-102.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:52,285 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:52,285 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:52,285 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:52,285 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:52,285 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:52,286 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:52,286 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:52,286 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,287 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,288 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:52,289 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,290 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:52,290 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:52,290 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:52,290 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:52,291 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:52,291 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,292 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,294 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:52,294 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,296 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:52,296 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-10-31 18:38:52,296 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,298 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:52,298 DEBUG [GETMethodProcessor] Delivering bytes 18093056 - 50000000000 from transcoded file, based on time range 101.087 - 102.087
2013-10-31 18:38:52,298 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:52,298 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:52,298 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:52 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=101.087-102.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:52,783 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:52,787 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49033: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=106.087-107.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:52,787 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:52,787 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:52,787 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:52,787 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:52,787 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:52,787 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:52,788 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:52,788 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,789 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,791 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:52,791 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,792 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:52,792 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:52,792 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:52,792 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:52,793 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:52,793 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,794 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,796 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:52,796 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,797 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:52,797 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-10-31 18:38:52,797 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:52,799 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:52,799 DEBUG [GETMethodProcessor] Delivering bytes 19257344 - 50000000000 from transcoded file, based on time range 106.087 - 107.087
2013-10-31 18:38:52,799 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:52,799 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:52,799 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:52 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=106.087-107.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:52,946 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2013-10-31 18:38:53,285 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:53,286 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49034: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=111.087-112.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:53,287 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:53,287 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:53,287 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:53,287 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:53,287 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:53,288 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:53,288 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:53,288 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:53,290 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:53,292 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:53,292 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:53,293 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:53,293 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:53,293 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:53,294 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:53,294 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:53,294 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:53,295 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:53,297 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:53,297 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:53,299 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:53,349 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-2388-sony2012-ORIGINAL.stf' is complete, sending simple stream
2013-10-31 18:38:53,416 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:53,417 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:53,417 DEBUG [GETMethodProcessor] Delivering bytes 20516864 - 50000000000 from transcoded file, based on time range 111.087 - 112.087
2013-10-31 18:38:53,418 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:53,418 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:53,418 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:53 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=111.087-112.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:54,009 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:54,012 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49035: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=116.087-117.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:54,012 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:54,013 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:54,013 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:54,013 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:54,013 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:54,013 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:54,013 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:54,013 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,015 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,016 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:54,016 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,018 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:54,018 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:54,018 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:54,018 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:54,018 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:54,019 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,020 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,022 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:54,022 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,023 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:54,023 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-2388-sony2012-ORIGINAL.stf' is complete, sending simple stream
2013-10-31 18:38:54,024 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,025 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:54,025 DEBUG [GETMethodProcessor] Delivering bytes 21798912 - 50000000000 from transcoded file, based on time range 116.087 - 117.087
2013-10-31 18:38:54,025 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:54,026 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:54,026 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:54 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=116.087-117.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:54,509 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:54,511 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49036: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=121.087-122.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:54,512 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:54,512 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:54,512 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:54,512 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:54,512 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:54,512 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:54,513 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:54,513 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,514 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,516 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:54,516 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,517 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:54,517 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:54,517 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:54,518 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:54,518 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:54,518 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,519 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,521 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:54,521 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,523 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:54,523 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-2388-sony2012-ORIGINAL.stf' is complete, sending simple stream
2013-10-31 18:38:54,523 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:54,525 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:54,525 DEBUG [GETMethodProcessor] Delivering bytes 23081984 - 50000000000 from transcoded file, based on time range 121.087 - 122.087
2013-10-31 18:38:54,525 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:54,525 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:54,525 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:54 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=121.087-122.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:55,010 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:55,012 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49037: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=126.087-127.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:55,012 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:55,013 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:55,013 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:55,013 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:55,013 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:55,013 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:55,013 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:55,013 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:55,014 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,015 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,017 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:55,017 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,018 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:55,018 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:55,018 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:55,019 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:55,019 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:55,019 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,020 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,022 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:55,022 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,023 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:55,024 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-2388-sony2012-ORIGINAL.stf' is complete, sending simple stream
2013-10-31 18:38:55,024 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,025 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:55,025 DEBUG [GETMethodProcessor] Delivering bytes 24364032 - 50000000000 from transcoded file, based on time range 126.087 - 127.087
2013-10-31 18:38:55,026 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:55,026 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:55,026 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:55 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=126.087-127.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:55,512 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:55,514 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49038: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=131.087-132.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:55,514 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:55,514 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:55,514 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:55,514 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:55,514 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:55,514 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:55,515 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:55,515 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,516 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,518 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:55,518 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,519 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:55,519 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:55,520 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:55,520 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:55,520 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:55,520 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,522 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,523 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:55,523 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,525 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:55,525 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-2388-sony2012-ORIGINAL.stf' is complete, sending simple stream
2013-10-31 18:38:55,525 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:55,527 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:55,527 DEBUG [GETMethodProcessor] Delivering bytes 25647104 - 50000000000 from transcoded file, based on time range 131.087 - 132.087
2013-10-31 18:38:55,527 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:55,527 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:55,527 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:55 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=131.087-132.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:56,013 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:56,016 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49039: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=136.087-137.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 18:38:56,016 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 18:38:56,016 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:56,017 DEBUG [ResourceDeliveryProcessor] Request for resource 2388 and type 'MEDIA_ITEM' received
2013-10-31 18:38:56,017 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:56,017 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:56,017 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:56,017 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2388, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 18:38:56,017 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:56,019 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:56,020 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv
2013-10-31 18:38:56,021 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:56,022 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:56,022 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2388 (local)
2013-10-31 18:38:56,022 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2388)
2013-10-31 18:38:56,022 DEBUG [VideoDAOImpl] Reading a Video (id = 2388)
2013-10-31 18:38:56,023 DEBUG [VideoDeliveryEngine] Delivering item '2388' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:56,023 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:56,024 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:56,026 DEBUG [VideoDeliveryEngine] Delivering file '[HorribleSubs] Naruto Shippuuden - 100 [480p].mkv' using transcoding
2013-10-31 18:38:56,026 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:56,027 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 18:38:56,027 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-2388-sony2012-ORIGINAL.stf' is complete, sending simple stream
2013-10-31 18:38:56,028 DEBUG [MediaItemDAOImpl] Getting file of media item 2388
2013-10-31 18:38:56,029 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [HorribleSubs] Naruto Shippuuden - 100 [480p].mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 18:38:56,029 DEBUG [GETMethodProcessor] Delivering bytes 26930176 - 50000000000 from transcoded file, based on time range 136.087 - 137.087
2013-10-31 18:38:56,029 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 18:38:56,030 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 18:38:56,030 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 07:38:56 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=136.087-137.087/1391,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 18:38:56,513 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 18:38:56,515 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:49040: GET /resource/2388/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=141.087-142.087,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
Post Thu Oct 31, 2013 8:05 am
Nothing on detailed log about the embedded subtitle...
Could you rename the mkv file, force the library refresh and check detailed log file to see if serviio/ffmpeg well detects the embedded subtitle track ?
kitjai
Post Thu Oct 31, 2013 9:30 am
Thanks for the reply,
I renamed the file - naruto.mkv
Hope this helps
2013-10-31 20:24:37,258 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46871: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 686,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:37,258 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:37,259 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:37,259 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:37,464 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = 2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2013-10-31 20:24:37,486 DEBUG [VideoDAOImpl] Retrieving number of video initials [Any]
2013-10-31 20:24:37,606 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [Any]
2013-10-31 20:24:37,640 DEBUG [SeriesDAOImpl] Retrieving number of series
2013-10-31 20:24:37,649 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [Any]
2013-10-31 20:24:37,654 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos [Any]
2013-10-31 20:24:37,679 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2013-10-31 20:24:37,679 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0 [Any]
2013-10-31 20:24:37,705 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2013-10-31 20:24:37,758 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2013-10-31 20:24:37,833 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-10-31 20:24:37,833 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-10-31 20:24:37,862 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2013-10-31 20:24:37,956 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2013-10-31 20:24:37,976 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:38,029 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46872: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 687,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:38,029 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:38,030 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:38,030 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:38,232 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = 2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 10, count = 10, sortCriteria =
2013-10-31 20:24:38,233 DEBUG [VideoDAOImpl] Retrieving number of video release years [Any]
2013-10-31 20:24:38,264 DEBUG [PlaylistDAOImpl] Retrieving number of playlists for VIDEO [Any]
2013-10-31 20:24:38,270 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [Any]
2013-10-31 20:24:38,279 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [Any]
2013-10-31 20:24:38,286 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:38,336 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46873: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 686,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:38,336 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:38,336 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:38,539 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = 2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2013-10-31 20:24:38,539 DEBUG [VideoDAOImpl] Retrieving number of video initials [Any]
2013-10-31 20:24:38,572 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [Any]
2013-10-31 20:24:38,590 DEBUG [SeriesDAOImpl] Retrieving number of series
2013-10-31 20:24:38,590 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [Any]
2013-10-31 20:24:38,591 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos [Any]
2013-10-31 20:24:38,604 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2013-10-31 20:24:38,604 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0 [Any]
2013-10-31 20:24:38,620 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2013-10-31 20:24:38,641 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2013-10-31 20:24:38,700 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2013-10-31 20:24:38,711 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2013-10-31 20:24:38,804 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:38,820 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46874: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 687,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:38,820 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:38,821 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:38,821 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:39,031 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = 2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 10, count = 10, sortCriteria =
2013-10-31 20:24:39,031 DEBUG [VideoDAOImpl] Retrieving number of video release years [Any]
2013-10-31 20:24:39,050 DEBUG [PlaylistDAOImpl] Retrieving number of playlists for VIDEO [Any]
2013-10-31 20:24:39,050 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [Any]
2013-10-31 20:24:39,051 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [Any]
2013-10-31 20:24:39,055 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:40,061 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46875: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 688,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:40,061 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:40,061 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:40,263 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2013-10-31 20:24:40,264 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=10) [Any]
2013-10-31 20:24:40,274 DEBUG [CoverImageDAOImpl] Reading a CoverImage for repository (id = 1)
2013-10-31 20:24:40,302 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [Any]
2013-10-31 20:24:40,324 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1092)
2013-10-31 20:24:40,343 DEBUG [CoverImageDAOImpl] Reading a CoverImage for repository (id = 2)
2013-10-31 20:24:40,345 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [Any]
2013-10-31 20:24:40,359 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2761)
2013-10-31 20:24:40,360 DEBUG [CoverImageDAOImpl] Reading a CoverImage for repository (id = 3)
2013-10-31 20:24:40,362 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [Any]
2013-10-31 20:24:40,378 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2764)
2013-10-31 20:24:40,379 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [Any]
2013-10-31 20:24:40,381 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-10-31 20:24:40,385 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:40,445 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46876: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 688,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:40,446 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:40,446 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:40,659 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2013-10-31 20:24:40,659 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-10-31 20:24:40,666 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:41,858 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46877: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 695,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:41,858 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:41,859 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:41,859 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:42,060 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2013-10-31 20:24:42,061 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null [Any]
2013-10-31 20:24:42,069 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder null (from=0, count=10) [Any]
2013-10-31 20:24:42,075 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 156)
2013-10-31 20:24:42,082 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 156 (filter: ALL) [Any]
2013-10-31 20:24:42,092 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1558)
2013-10-31 20:24:42,093 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 157)
2013-10-31 20:24:42,094 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 157 (filter: ALL) [Any]
2013-10-31 20:24:42,105 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1559)
2013-10-31 20:24:42,106 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 158)
2013-10-31 20:24:42,106 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 158 (filter: ALL) [Any]
2013-10-31 20:24:42,115 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1560)
2013-10-31 20:24:42,116 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 159)
2013-10-31 20:24:42,117 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 159 (filter: ALL) [Any]
2013-10-31 20:24:42,125 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1561)
2013-10-31 20:24:42,126 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 160)
2013-10-31 20:24:42,130 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 160 (filter: ALL) [Any]
2013-10-31 20:24:42,141 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1585)
2013-10-31 20:24:42,142 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 161)
2013-10-31 20:24:42,145 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 161 (filter: ALL) [Any]
2013-10-31 20:24:42,156 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1899)
2013-10-31 20:24:42,156 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 162)
2013-10-31 20:24:42,157 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 162 (filter: ALL) [Any]
2013-10-31 20:24:42,165 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2195)
2013-10-31 20:24:42,166 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 163)
2013-10-31 20:24:42,166 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 163 (filter: ALL) [Any]
2013-10-31 20:24:42,175 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2220)
2013-10-31 20:24:42,175 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 164)
2013-10-31 20:24:42,178 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 164 (filter: ALL) [Any]
2013-10-31 20:24:42,187 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2226)
2013-10-31 20:24:42,187 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 166)
2013-10-31 20:24:42,188 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 166 (filter: ALL) [Any]
2013-10-31 20:24:42,195 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2630)
2013-10-31 20:24:42,196 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [Any]
2013-10-31 20:24:42,197 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-10-31 20:24:42,205 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:42,236 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46878: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 696,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:42,236 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:42,237 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:42,237 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:42,448 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 10, count = 10, sortCriteria =
2013-10-31 20:24:42,448 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null [Any]
2013-10-31 20:24:42,449 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder null (from=10, count=10) [Any]
2013-10-31 20:24:42,455 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 167)
2013-10-31 20:24:42,456 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 167 (filter: ALL) [Any]
2013-10-31 20:24:42,465 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2631)
2013-10-31 20:24:42,466 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 168)
2013-10-31 20:24:42,469 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 168 (filter: ALL) [Any]
2013-10-31 20:24:42,477 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2675)
2013-10-31 20:24:42,478 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 169)
2013-10-31 20:24:42,479 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 169 (filter: ALL) [Any]
2013-10-31 20:24:42,489 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2687)
2013-10-31 20:24:42,490 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 170)
2013-10-31 20:24:42,491 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 170 (filter: ALL) [Any]
2013-10-31 20:24:42,499 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2711)
2013-10-31 20:24:42,503 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 171 (from=0, count=6) [Any]
2013-10-31 20:24:42,515 DEBUG [MediaItemDAOImpl] Getting file of media item 2725
2013-10-31 20:24:42,519 DEBUG [MediaItemDAOImpl] Getting file of media item 2725
2013-10-31 20:24:42,520 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
2013-10-31 20:24:42,523 DEBUG [VideoDAOImpl] Reading a Video (id = 2725)
2013-10-31 20:24:42,529 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2725 and profile Sony Bravia TV (2012)
2013-10-31 20:24:42,531 DEBUG [MediaItemDAOImpl] Getting file of media item 2725
2013-10-31 20:24:42,532 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2761)
2013-10-31 20:24:42,533 DEBUG [MediaItemDAOImpl] Getting file of media item 2725
2013-10-31 20:24:42,534 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:42,535 DEBUG [GenreDAOImpl] Reading a Genre (id = 11)
2013-10-31 20:24:42,535 DEBUG [VideoDAOImpl] Reading a Video (id = 3141)
2013-10-31 20:24:42,535 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3141 and profile Sony Bravia TV (2012)
2013-10-31 20:24:42,535 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:42,536 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:42,537 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Naruto.mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 20:24:42,537 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3240)
2013-10-31 20:24:42,538 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:42,539 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [Any]
2013-10-31 20:24:42,539 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-10-31 20:24:42,546 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:42,606 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46879: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 695,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:42,606 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:42,606 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:42,676 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46880: GET /resource/2761/COVER_IMAGE HTTP/1.1, headers = [transferMode.dlna.org: Interactive,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 20:24:42,677 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:42,683 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 20:24:42,683 DEBUG [ResourceDeliveryProcessor] Request for resource 2761 and type 'COVER_IMAGE' received
2013-10-31 20:24:42,684 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2761)
2013-10-31 20:24:42,685 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 2761
2013-10-31 20:24:42,686 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2761)
2013-10-31 20:24:42,687 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 2761
2013-10-31 20:24:42,687 DEBUG [GETMethodProcessor] Stream entity has length: 6486
2013-10-31 20:24:42,688 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6486,Date: Thu, 31 Oct 2013 09:24:42 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 20:24:42,699 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46881: GET /resource/3240/COVER_IMAGE HTTP/1.1, headers = [transferMode.dlna.org: Interactive,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 20:24:42,699 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:42,700 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:42,700 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 20:24:42,700 DEBUG [ResourceDeliveryProcessor] Request for resource 3240 and type 'COVER_IMAGE' received
2013-10-31 20:24:42,700 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3240)
2013-10-31 20:24:42,700 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 3240
2013-10-31 20:24:42,700 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 3240
2013-10-31 20:24:42,701 DEBUG [GETMethodProcessor] Stream entity has length: 5391
2013-10-31 20:24:42,701 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5391,Date: Thu, 31 Oct 2013 09:24:42 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 20:24:42,808 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2013-10-31 20:24:42,808 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-10-31 20:24:42,815 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:42,874 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46882: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 696,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:42,874 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:42,874 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:43,085 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 10, count = 10, sortCriteria =
2013-10-31 20:24:43,085 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-10-31 20:24:43,095 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:45,826 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46883: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 695,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:45,826 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:45,827 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:45,827 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:46,028 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2013-10-31 20:24:46,028 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-10-31 20:24:46,035 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:46,064 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46884: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 696,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:24:46,064 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:46,064 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:24:46,276 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 10, count = 10, sortCriteria =
2013-10-31 20:24:46,276 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-10-31 20:24:46,283 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:24:48,380 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46885: HEAD /resource/3141/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 20:24:48,381 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:48,381 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 20:24:48,381 DEBUG [ResourceDeliveryProcessor] Request for resource 3141 and type 'MEDIA_ITEM' received
2013-10-31 20:24:48,381 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3141 (local)
2013-10-31 20:24:48,381 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3141)
2013-10-31 20:24:48,386 DEBUG [VideoDAOImpl] Reading a Video (id = 3141)
2013-10-31 20:24:48,387 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3141, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 20:24:48,387 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:48,388 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Naruto.mkv
2013-10-31 20:24:48,388 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:48,388 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Naruto.mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 20:24:48,389 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 09:24:48 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 20:24:48,394 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46886: GET /resource/3141/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 20:24:48,394 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:48,395 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 20:24:48,395 DEBUG [ResourceDeliveryProcessor] Request for resource 3141 and type 'MEDIA_ITEM' received
2013-10-31 20:24:48,395 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3141 (local)
2013-10-31 20:24:48,395 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3141)
2013-10-31 20:24:48,396 DEBUG [VideoDAOImpl] Reading a Video (id = 3141)
2013-10-31 20:24:48,396 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3141, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 20:24:48,396 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:48,397 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:48,397 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Naruto.mkv
2013-10-31 20:24:48,398 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Naruto.mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 20:24:48,398 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3141 (local)
2013-10-31 20:24:48,398 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3141)
2013-10-31 20:24:48,398 DEBUG [VideoDAOImpl] Reading a Video (id = 3141)
2013-10-31 20:24:48,398 DEBUG [VideoDeliveryEngine] Delivering item '3141' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 20:24:48,398 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:48,399 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:48,399 DEBUG [VideoDeliveryEngine] Delivering file 'Naruto.mkv' using transcoding
2013-10-31 20:24:48,400 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 20:24:48,401 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:48,401 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\Naruto.mkv
2013-10-31 20:24:48,401 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -threads auto -i E:\Naruto.mkv -y -threads auto -c:v copy -bsf:v h264_mp4toannexb -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-3141-sony2012-ORIGINAL.stf
2013-10-31 20:24:48,901 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-10-31 20:24:48,902 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:48,903 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Naruto.mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 20:24:48,903 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 3141) as read
2013-10-31 20:24:48,911 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-31 20:24:48,911 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 20:24:48,911 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 20:24:48,911 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 09:24:48 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-1389/1389,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 20:24:50,945 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 20:24:50,957 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46887: GET /resource/3141/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895]]
2013-10-31 20:24:50,957 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:50,958 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:24:50,958 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 20:24:50,958 DEBUG [ResourceDeliveryProcessor] Request for resource 3141 and type 'MEDIA_ITEM' received
2013-10-31 20:24:50,958 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3141 (local)
2013-10-31 20:24:50,958 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3141)
2013-10-31 20:24:50,958 DEBUG [VideoDAOImpl] Reading a Video (id = 3141)
2013-10-31 20:24:50,959 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3141, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2013-10-31 20:24:50,959 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:50,960 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Naruto.mkv
2013-10-31 20:24:50,960 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:50,960 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Naruto.mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 20:24:50,960 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3141 (local)
2013-10-31 20:24:50,960 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3141)
2013-10-31 20:24:50,961 DEBUG [VideoDAOImpl] Reading a Video (id = 3141)
2013-10-31 20:24:50,961 DEBUG [VideoDeliveryEngine] Delivering item '3141' for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 20:24:50,961 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:50,962 DEBUG [VideoDeliveryEngine] Delivering file 'Naruto.mkv' using transcoding
2013-10-31 20:24:50,962 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:50,962 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Sony Bravia TV (2012)'
2013-10-31 20:24:50,963 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-10-31 20:24:50,963 DEBUG [MediaItemDAOImpl] Getting file of media item 3141
2013-10-31 20:24:50,963 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Naruto.mkv: AVC_TS_MP_HD_AC3_ISO
2013-10-31 20:24:50,963 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 3141) as read
2013-10-31 20:24:50,966 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-31 20:24:50,966 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-31 20:24:50,966 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-31 20:24:50,966 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 31 Oct 2013 09:24:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-1389/1389,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-31 20:25:02,823 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2013-10-31 20:25:12,808 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-31 20:25:13,685 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46888: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 695,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:25:13,685 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:25:13,686 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:25:13,686 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:25:13,887 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2013-10-31 20:25:13,887 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-10-31 20:25:13,893 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:25:13,920 DEBUG [ServiioHttpService] Incoming request from /192.168.1.4:46889: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-55HX850";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55HX850"; mv="1.7";,Host: 192.168.1.10:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 696,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-31 20:25:13,920 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-10-31 20:25:13,920 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.4
2013-10-31 20:25:14,122 DEBUG [ContentDirectory] Browse() called for renderer KDL-55HX850 (profile sony2012) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 10, count = 10, sortCriteria =
2013-10-31 20:25:14,122 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-10-31 20:25:14,127 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-31 20:25:37,286 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2013-10-31 20:25:37,286 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2013-10-31 20:25:37,286 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-10-31 20:25:37,386 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-10-31 20:25:37,486 INFO  [FeedUpdaterThread] Finished looking for online resources information
2013-10-31 20:25:37,586 INFO  [PluginCompilerThread] Finished looking for plugins
2013-10-31 20:25:37,688 INFO  [SearchManager] Starting up search engine
2013-10-31 20:25:37,867 INFO  [SearchIndexer] Closing search index writer
2013-10-31 20:25:37,868 INFO  [SearchIndexer] Closing search index writer
2013-10-31 20:25:37,868 DEBUG [DiscoveryManager] UPNP device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65 (192.168.1.10) is unavailable
2013-10-31 20:25:37,868 DEBUG [WebServer] Socket closed
2013-10-31 20:25:37,868 INFO  [WebServer] WebServer shutting down
2013-10-31 20:25:37,869 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-10-31 20:25:37,869 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-10-31 20:25:37,869 DEBUG [DiscoverySSDPMessageListener] Socket closed: socket closed
2013-10-31 20:25:37,869 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-10-31 20:25:37,869 INFO  [EventDispatcher] Leaving EventDispatcher
2013-10-31 20:25:37,917 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth3 (Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)) and address 192.168.1.10, timeout = 0
2013-10-31 20:25:37,917 INFO  [DatabaseManager] Shutting down database
2013-10-31 20:25:37,917 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2013-10-31 20:25:38,120 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2013-10-31 20:25:38,120 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-10-31 20:25:38,167 DEBUG [TranscodingJobListener] Deleted temp file 'C:\Windows\TEMP\Serviio\transcoding-temp-3141-sony2012-ORIGINAL.stf': true
2013-10-31 20:25:38,167 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2013-10-31 20:25:44,235 INFO  [ServiioConsole] Exitting Serviio Console
2013-10-31 20:25:44,235 DEBUG [RepositoryView] Instructing LibraryCheckingThread to stop
2013-10-31 20:25:44,235 INFO  [ServiioConsole] Serviio Console completely closed
Post Thu Oct 31, 2013 5:14 pm
Re: MKV subtitles not playing
kitjai wrote:Hope this helps
No, you send log section during file playback... I would like when file is added to the serviio library (just after force refresh).
It seems that serviio/ffmpeg does not detect the subtitle track.
kitjai
Post Fri Nov 01, 2013 2:52 am
Here is a link to the log
http://www.filedropper.com/serviiodetailedlog
kitjai
Darkfalz
Post Fri Nov 01, 2013 11:54 am
Bravia 2012 series don't support MKV playback, so your file is being remuxed to mpeg2ts which is why you're losing the subtitle.
Edit: NM, you are trying to hard-encode them.
Sony KDL-55HX750 and BDV-N990W (Home Theatre)
Sony KDL-40D3100 and BDP-S390 (Loungeroom)
kitjai
Post Fri Nov 01, 2013 1:41 pm
I'm not sure, because I installed ums and it play the subtitles.
I don't like ums though
