Adding files from a network drive
jhall1990
Post Wed Oct 30, 2013 10:28 pm
Hi everyone,
I know that this question has been asked a million times, but none of the results I found worked for me. Most things I've found link to this http://www.serviio.org/component/content/article?id=21#q5.
My problem is I'm not sure which account to use. My setup is as follows.
Laptop (Win7 64bit) is running serviio. I log in with UserA.
Desktop (Win7 64 bit) has the mapped drive. I log in with UserB.
My understanding is that I need to start he serviio service with UserB and UserB's password, problem is when I try to do that I get an error saying the name is invalid.
Is there something else that I need to do in order to load files from my network drive?
Thanks in advance for any help.
verdejt
Post Thu Oct 31, 2013 11:41 am
Re: Adding files from a network drive
What you need to do is map the network drive on the laptop with the same user that is running Serviio. Serviio can't access a drive that is mapped on another computer. The drive has to be mapped on the computer running Serviio. Serviio only sees "local" drives. Meaning that the drive has to be accessible on the machine that is actually running the Serviio software. Or load Serviio onto the desktop machine, which is what I would do.
Post Thu Oct 31, 2013 12:24 pm
jhall1990 wrote:My understanding is that I need to start he serviio service with UserB and UserB's password, problem is when I try to do that I get an error saying the name is invalid.
Make sure your create a UserB user with the correct password on your Laptop.
jhall1990
Post Thu Oct 31, 2013 12:47 pm
I mapped the drive and was still stuck, this was the problem here. I tried to rename my current user and change the password but that wasn't working. I created a new user with the same username and password (as UserB on my desktop) and its loading the files now.
Thanks for the help!
