Blu-Ray Player DMP-BDT130EG (2013)
hagncola
Post Mon Nov 04, 2013 5:58 pm
My Panasonic Blu-Ray Player DMP-BDT130EG works with Profile "Panasonic BD Player" but MKV´s plays not "round" (stutter) . Serviio identify the device as NFLC SDK v1.5. I tried the Vera 2013 profile without success.
Please help.
Post Wed Nov 06, 2013 12:39 pm
Re: Blu-Ray Player DMP-BDT130EG (2013)
Please post MediaInfo details for the stuttering file. Also describe your network and PC.
Have a read of http://www.serviio.org/component/conten ... ?id=21#q12.
hagncola
Post Wed Nov 06, 2013 6:03 pm
My Network is Gigabit. Serviio run on NAS Qnap TS259 Pro. The Panasonic should play MKV without transcoding for my opinion. The player has the option to mount smb network share and play mkv without problems, but for my wife it´s easy to use DLNA. The "problem" regards all my mkv files.
Sample:
Unique ID : 173066003805243695008921585949537188685 (0x82334CC6CBEE191F1199208E8AA7BB4D)
Complete name : /Volumes/network-1/filmeHD/TEST.mkv
Format : Matroska
Format version : Version 2
File size : 11.5 GiB
Duration : 2h 58mn
Overall bit rate : 9 250 Kbps
Movie name : TEST
Encoded date : UTC 2010-11-19 08:14:18
Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') gebaut am Oct 31 2010 18:15:05
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 58mn
Bit rate : 8 298 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.167
Stream size : 10.3 GiB (90%)
Title : TEST
Writing library : x264 core 107 r1772 c9dad9e
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:0.00
Default : Yes
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 2h 58mn
Bit rate mode : Constant
Bit rate : 768 Kbps
Channel count : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 979 MiB (8%)
Title : DTS
Language : German
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : Forced Subs
Language : German
Default : Yes
Forced : No
Post Sat Jan 04, 2014 9:54 am
Sorry about the delay - not sure how this slipped by.
I suspect your stuttering is caused by transcoding - I haven't a Qnap TS259 Pro NAS, but I do know a lot of NAS's do not have the processing power to do any heavy duty transcoding (limited to remuxing only). The Panasonic BD player profile you are using will remux the video and transcode the audio. The confusing part is that the Panasonic 2013 profile should play your file natively (ie. without transcoding).
Can you confirm your file is being transcoded (turn on detailed logging and play the file - the log file will tell you if transcoded or played natively).
I notice this file has subtitles. What are your settings in Serviio console (Delivery, Subtitles tab). Try both profiles with only the top checkbox selected.
Return to Panasonic
