DVR-MS files
• Page 1 of 1
This is my first time posting. The problem I have is that when using an older version of Serviio I was able to play all my dvr-ms files. Since installing the newest version I cannot play them. Can anyone help me.
Re: DVR-MS files
What device, profile and post your detailed log.
Petr
Help translate Serviio
Re: DVR-MS files
Thanks for responding. When I add the folder containing my dvr-ms files to the library, and save it, the folder is empty. i get the message on my Samsung TV "there are no files in folder"
Re: DVR-MS files
I mean "no files available to playback"
Re: DVR-MS files
all good, but....
What TV/DVD/whatever are you trying to play the file on (make and model), which renderer profile are you using (from Serviio console, status tab) and post a detailed log (click on the link) of when you are playing the file. Nobody can assist unless they have that information.
zip wrote:What device, profile and post your detailed log.
Re: DVR-MS files
DEVICE NAME: SAMSUNG "D" SERIES
PROFILE: SAMSUNG (C/D/E/F series)
RE- config / log4j.xml is ......blank
Re: DVR-MS files
If your config/log4j.xml is blank (open it with a text editor?) then this is pointing to a problem with the installation process (this file is created during install, and needless to say, isn't blank). Try re-installing Serviio (if a Windows user you should be able to just go over the top of the existing version, no need to uninstall the first version).
If a re-install doesn't work - do you have a file "serviio.log" in your log folder? If so, post what you have.
Re: DVR-MS files
Went back to Serviio 0.6.2 and my dvs-ms files are now working
Thanks!!
Re: DVR-MS files
can you post ffmpeg -i of the file (preferably using Serviio 1.3.1 ffmpeg)
Petr
• Page 1 of 1
Users browsing this forum: Google [Bot] and 30 guests
