Re: Öppet Arkiv (Swedish Public television archive)
This retrieves more than 18 episodes per show (fixes the bug report regarding Fem Myror... earlier in the thread.
Regards.
/ O
ottomatic wrote:OK, so I have posted yet another version, 1.0.5.
Regards.
/ O
n3mmr wrote:ottomatic wrote:OK, so I have posted yet another version, 1.0.5.
Regards.
/ O
Thanks. Will get back.
Am I the only user???
n3mmr wrote:n3mmr wrote:ottomatic wrote:OK, so I have posted yet another version, 1.0.5.
Regards.
/ O
Have tested the latest version.
> 18 episodes works.
P R and S work, now. Å Ä Ö do not work.
n3mmr wrote:The characters Å, Ä and Ö do not work, for me at least.
ottomatic wrote:n3mmr wrote:The characters Å, Ä and Ö do not work, for me at least.
OK, I'll look into it over the weekend.
n3mmr wrote:ottomatic wrote:n3mmr wrote:The characters Å, Ä and Ö do not work, for me at least.
Actually, Z won't work, either!
ottomatic wrote:New version posted, 1.0.6.
This fixes the problem with "letter URL:s" for Å, Ä and Ö reported by n3mmer.
The link for shows whose names start with Å is still:
http://www.oppetarkiv.se/kategori/titel#Å
The plugin now correctly delivers feed items for the individual episodes of those shows.
n3mmr wrote:This does bring up another, possibly unrelated, idea.
I'd love to be able to do "title editing" on the fly. As it is, many of the Öppet Arkiv shows show up as "Show title, Show title" or, worse, "Very long annoying show name, episode title".
In the first case it's merely annoying, in the latter case it means browsing won't work very well on many players; the common part of multiple consecutive titles takes up all the available screen line space, and many players won't roll the title across. (even if they did, browsing with waiting for each title to roll across to see the distinguishing part is not very pleasant.)
ottomatic wrote:n3mmr wrote:This does bring up another, possibly unrelated, idea.
Not sure what you mean by editing the title "on the fly".
The plugin does some parsing and concatenation in order to present informative titles. The long names, with the show name first, work for me as my DLNA client scrolls the titles and I know that they appear in a logical order.
If you look inside the plugin source, around line 201 is where the title for "letter URL shows" are set.
You could try altering this:
so that it reads like this:
The other places where titles are set are around line 367 and 377. Search for "webResourceItemTitle =". This is where item titles are normally set (for "non letter url:s") and the result of this is what is used "recursively" in line 202 as demonstrated above.
You may experiment and report back to me what works best. Perhaps I'll update the plugin according to the suggestions.
Regards
/ O
Regards
/ O
n3mmr wrote:And given the fact that I can't watch any online shows at all, at least not from SVT, I cannot test this much more.
I suggest you change the line
to be
