PACKAGE: Serviio 1.5 for QNAP NAS (ARM & x86 Intel)
Conic
Post Sun Jan 13, 2013 1:45 pm
Re: PACKAGE: Serviio 1.1 for QNAP NAS (ARM & x86 Intel)
Thank you so much, my problem was solved, that was very helpfull. Now i have another problem, but first problem is gone :)
Xmantium
Post Sun Jan 13, 2013 10:19 pm
Ive not had that issue. Maybe a Samsung user can give you more insight.
what about putting all those folders into category folders
hybrid
Post Sat Feb 09, 2013 4:48 pm
Hi
I have the same problem, Qnap 659 Pro + , 6x 2tb WD drives.
I thought it might be cause my Hard drives are sleeping? , cause of the fact that it works after a couple of attempts.
I have 4 Samsung TV's in the house , and it is the same for all.
Could it be that the Database cannot be accessed because the HD's are sleeping?
I have not tried to set the drives to never sleep. Any help , advise would be greatly appreciated.
P.S once it starts , there is no problem at all and it works great.
TVS-871 using Serviio/Mediabrowser (1.5Rev1) on IPad, Iphone, Android Phone , Samsung TV's , OTT MXQ M10 TV Box, PS4 and Xbox.
Xmantium
Post Wed Apr 10, 2013 10:56 pm
The QNAP users just made some custom scripts to upgrade to Serviio 1.2.1 and also install a fresh new ffmpeg in your own QNAP systems, works a treat.
Im not good at compiling but the easy to run scripts does the job for you!!
Use at your own risk, myself and others tested it and works a charm!
https://gist.github.com/tommeier/5324815
csholmq
Post Sun Apr 14, 2013 10:20 pm
I compiled FFmpeg for ARM with libshine, libfdk-aac, etc. Have a look. I also included a wrapper in order to use the fixed point libraries instead of the floating point ones.
_SDK_
Post Sat Apr 20, 2013 3:55 pm
Following... Waiting for 1.2.1, QPKG / Intel
mrrouge
Post Tue Apr 23, 2013 8:50 pm
@Xmantium can you provide instructions on how to use the scripts?
Thanks a lot
r1u0d2y
Post Mon Jun 03, 2013 6:31 pm
is it possible, that we'll become qpkg package for newest Serviio?
http://polish-law.strefa.pl/family-law.html
Regards
Xmantium
Post Sun Oct 06, 2013 9:01 pm
Re: PACKAGE: Serviio 1.3 for QNAP NAS (ARM & x86 Intel)
I have QPKG for ARM chips that i made myself - https://bitbucket.org/Xmantium/serviio- ... m-x19.qpkg
Recommend a clean install.
Intel version will follow very soon ;)
hybrid
Post Tue Oct 08, 2013 9:41 pm
That is great news! , Looking forward to the QNAP Intel Version.
Thank you for all the hard work. :)
Xmantium
Post Sun Oct 20, 2013 5:23 am
hybrid wrote:That is great news! , Looking forward to the QNAP Intel Version.
Wait is over, finally manage to figure out the QNAP developer Kit and bundled the latest Serviio
Downloads are in the first post!
Its still using the old ffmpeg which doesnt support subtitles but released this so all QNAPers can enjoy this who have been on edge how to install it
It works fine, tested it over and over but please use it at your own risk as ive only been using the developer kit for over a month
hybrid
Post Sun Oct 20, 2013 9:14 am
great! , Installed it and will check it too, busy adding library. 8tb of data, might take a while.
Thanks for all your hard work again.
aapires
Post Sat Nov 09, 2013 12:48 pm
i've trying the 1.3.1 b1 and b2 on my Qnap TS421 Arm without success. First io got a web-UI error, which doesnt allow me to change nothing. After i downloaded the web-UI and replace the files, it should work (no error displayed) but i could't start the server. The log had a lot of errors. I tired with Java 6 and 7. Right now i'm using the version 1.1 b10 with java 6, the only one that i manage to work on my NAS. Anyone got it to work?
[edit]
forgot to say: i always did a clean install. Uninstall the version, delete files and then the new version install
hybrid
Post Sat Nov 09, 2013 1:35 pm
Works great for me. Installed 1.3.1 no problem , No errors , Jre 7. :) Good job with the packaging!
aapires
Post Sat Nov 09, 2013 2:51 pm
trying (again):
uninstall Serviio 1.1 b10 and JRE 6. Installing JRE 7 + Serviio 1.3.1 rev 2.
Again, the problem "WARNING: Web UI is optimized for Serviio v1.3 but v was found. There may be a loss of functionality. Please consider updating."
still looking how to fix it. But the logs on serviio:
2013-11-09 15:47:55,959 WARN [ServiioStatusService] ExceptionInInitializerError occured. Returning error code 500 to the REST layer. Message: null
2013-11-09 15:47:56,401 INFO [DBSchemaUpdateExecutor] Updating DB schema
2013-11-09 15:47:58,454 WARN [ServiioStatusService] NoClassDefFoundError occured. Returning error code 500 to the REST layer. Message: Could not initialize class org.serviio.config.Configuration
2013-11-09 15:48:33,108 WARN [ServiioStatusService] PersistenceException occured. Returning error code 500 to the REST layer. Message: Cannot retrieve list of OnlineRepositories
[edit]
After i commented the line "$version_req = "1.3";" on file config.php, the errors disappeared and i could start the server.
Xmantium
Post Sat Nov 09, 2013 4:44 pm
Can you please restart your NAS or disable and enable the QPKG
Please make sure you have Web Server enabled on your QNAP settings.
Xmantium
Post Mon Dec 23, 2013 8:26 pm
Re: PACKAGE: Serviio 1.4 for QNAP NAS (ARM & x86 Intel)
Updated to the latest Serviio 1.4 - Read the original post for instructions
ARM: TS-x10, x12, x19, x20, x21
Serviio 1.4 Revision 1
x86: TS-x39, x59, x69, x70, x70U, x79
jim502
Post Wed Dec 25, 2013 2:19 pm
Xmantium wrote:Updated to the latest Serviio 1.4 - Read the original post for instructions
Thanks for the XMAS present.
Xmantium
Post Wed Dec 25, 2013 3:38 pm
The ARM chips includes the latest ffmpeg that should work for hulu.
Thanks to zip for making one awesome sever.
Qnappers, please consider buying pro edition.
Xmantium
Post Sat Jan 11, 2014 5:40 pm
Here is Revision 2, just updated the compatible Web UI for v1.4
Ive also changed the Intel install script so the temp folder automatically configures to .root/Serviio/tmp, ARM script already had this, thanks Patters for the tip ;)
Serviio 1.4 Revision 2
