Covert rtmp to http
• Page 1 of 1
Is it possible to convert rtmp to http during streaming?
Re: Covert rtmp to http
No. The rtmp is a request to a server. Obviously an http request with rtmp info would not be recognized by the server.
Ok, thanks for the info. Is it possible to convert rtmp to mp4?
You can 'convert' it to http via Serviio (as it only outputs http) by transcoding it to mpeg2. That should already be set up for most profiles.
Petr
Help translate Serviio
zip wrote:You can 'convert' it to http via Serviio (as it only outputs http) by transcoding it to mpeg2. That should already be set up for most profiles.
Huh?? http is a network protocol.. servio only transcodes the file transmitted via the network protocol regardless if it is http or rtmp, and can only convert from one file format eg: flv to mpeg2 but it does not convert rtmp to http.
• Page 1 of 1
