Problem with ffmpeg cant play videos
Polliny
Post Sun Nov 10, 2013 11:34 am
Hi @ all,
first of all I apologize for my english.
I have the following problem when i want play a video.
200, Stream not found, NetStream.Play.StreamNotFound, clip: '[Clip] 'http://<my-ip>:23424/cds/resource/6/MEDIA_ITEM/FLV-0/MEDIUM?profile=flv_player&authToken=3376c425b7974462ab51d563d2588b9d''
Then I looked in the log file and found the following Warning
2013-11-10 12:50:07,644 WARN  [ServiioStatusService] Returning error code to the REST layer: Not Found (404) - The server has not found anything matching the request URI
2013-11-10 12:50:18,084 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
Duration: 01:48:37.01, start: 0.000000, bitrate: 898 kb/s
Stream #0.0: Video: mpeg4 (Advanced Simple Profile), yuv420p, 624x352 [PAR 1:1 DAR 39:22], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 44100 Hz, stereo, s16, 139 kb/s
Unrecognized option 'c:v'
Failed to set value 'flv' for option 'c:v'
2013-11-10 12:50:27,966 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/tmp/Serviio/transcoding-temp-5-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
2013-11-10 12:50:28,244 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
2013-11-10 12:50:38,176 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/tmp/Serviio/transcoding-temp-5-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
2013-11-10 12:50:38,451 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
2013-11-10 12:50:48,385 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/tmp/Serviio/transcoding-temp-5-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
ffmpeg version
ffmpeg version 0.8.8-4:0.8.8-0ubuntu0.12.04.1, Copyright (c) 2000-2013 the Libav developers
  built on Oct 22 2013 12:31:55 with gcc 4.6.3
ffmpeg 0.8.8-4:0.8.8-0ubuntu0.12.04.1
libavutil    51. 22. 1 / 51. 22. 1
libavcodec   53. 35. 0 / 53. 35. 0
libavformat  53. 21. 1 / 53. 21. 1
libavfilter   2. 15. 0 /  2. 15. 0
libpostproc  52.  0. 0 / 52.  0. 0
Where is the problem and can you help me pls
Post Sun Nov 10, 2013 6:27 pm
Re: Problem with ffmpeg cant play videos
Old FFmpeg, they are currently on 2.1. You will have to get a newer static build or build one yourself. Look at the wiki.
Polliny
Post Wed Nov 13, 2013 11:56 am
thx that was a problem
here a littel how to update ffmpeg
remove old ffmpeg
apt-get remove ffmpeg
apt-get autoremove
Install Python Software
apt-get install python-software-properties
adding PPA to your System
app-apt-repository ppa:jon-serverinsson/ffmpeg
update
apt-get update
and the last one
apt-get install ffmpeg
thats all
Polliny
Post Wed Nov 13, 2013 12:41 pm
ok but now i have the next problem, serviio dont play videos on the mobile app
2013-11-13 13:30:46,314 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
Duration: 01:10:38.24, start: 0.000000, bitrate: 1385 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 704x416 [SAR 1:1 DAR 22:13], 25 tbr, 25 tbn, 25 tbc
Stream #0:1: Audio: mp2 (P[0][0][0] / 0x0050), 48000 Hz, stereo, s16, 224 kb/s
Unrecognized option 'segment_list_flags'
Failed to set value 'cache' for option 'segment_list_flags'
2013-11-13 13:30:56,217 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/tmp/Serviio/transcoding-temp-349-serviigo_hls-LOW.stf/playlist.m3u8' cannot be found, FFmpeg execution probably failed
2013-11-13 13:30:56,484 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
ffmpeg version 0.10.9-7:0.10.9-1~precise1
built on Oct  4 2013 06:37:30 with gcc 4.6.3
libavutil      51. 35.100 / 51. 35.100
libavcodec     53. 61.100 / 53. 61.100
libavformat    53. 32.100 / 53. 32.100
libavdevice    53.  4.100 / 53.  4.100
libavfilter     2. 61.100 /  2. 61.100
libswresample   0.  6.100 /  0.  6.100
sleky
Post Wed Nov 13, 2013 5:16 pm
Doesn't look like you've updated your ffmpeg yet.
root@nix-01:/mnt/usb3/tv.tmp# ffmpeg -version
ffmpeg version N-57549-g269b3c8
built on Oct 28 2013 12:19:55 with gcc 4.7 (Debian 4.7.2-5)
configuration: --prefix=/root/ffmpeg_build --extra-cflags=-I/root/ffmpeg_build/include --extra-ldflags=-L/root/ffmpeg_build/lib --bindir=/usr/bin --extra-libs=-ldl --enable-gpl --enable-libass --enable-libfdk-aac --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree
libavutil      52. 48.100 / 52. 48.100
libavcodec     55. 39.100 / 55. 39.100
libavformat    55. 19.104 / 55. 19.104
libavdevice    55.  5.100 / 55.  5.100
libavfilter     3. 90.100 /  3. 90.100
libswscale      2.  5.101 /  2.  5.101
libswresample   0. 17.104 /  0. 17.104
Post Wed Nov 13, 2013 7:01 pm
If you want to use ServiiGo with the Enhanced profile (needed for seeking under Medium/Low quality options), then you need a newer version of ffmpeg than includes libx264 support. The best way to do that is to build it from source.
Otherwise you can switch the profile to Standard via the app.
