Port Forwarding
I got a new cable modem from Motorola SGB6580, I set it up with the following ports being forwarded, 8895, 1900, 23424. I can acess it from http://localhost:23424/mediabrowser/. I can access it from two Samsung TV's. Why cant I access it from my mobile devices or another computer anymore? It worked two days ago. Canyouseeme port checker says it is blocked even with the firewall off. Not sure where I am going wrong. here is the debug file, i thought i turned off the Library part. however it still seem huge, i cut a big piece off. Please help!
2013-11-02 10:40:38,480 INFO [ServiioConsole] Starting Serviio Console
2013-11-02 10:40:38,707 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-11-02 10:40:49,408 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2013-11-02 10:40:59,452 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2013-11-02 10:40:59,485 INFO [Messages] Loaded console message bundle for locale: en
2013-11-02 10:41:02,853 INFO [ServiioConsole] Exitting Serviio Console
2013-11-02 10:41:19,379 INFO [ServiioConsole] Initializing Serviio Console
2013-11-02 10:41:19,426 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-11-02 10:41:19,437 INFO [ServiioConsole] Starting Serviio Console
2013-11-02 10:41:19,552 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-11-02 10:41:19,624 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-11-02 10:41:19,625 DEBUG [ServiioConsole] Checking if server is running
2013-11-02 10:41:30,103 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2013-11-02 10:41:30,104 DEBUG [ServiioConsole] Retrieving console settings
2013-11-02 10:41:40,154 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2013-11-02 10:41:40,171 INFO [Messages] Loaded console message bundle for locale: en
2013-11-02 10:41:46,453 INFO [ServiioConsole] Exitting Serviio Console
2013-11-02 10:42:13,717 INFO [ServiioConsole] Initializing Serviio Console
2013-11-02 10:42:13,774 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-11-02 10:42:13,783 INFO [ServiioConsole] Starting Serviio Console
2013-11-02 10:42:13,881 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-11-02 10:42:13,959 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-11-02 10:42:13,959 DEBUG [ServiioConsole] Checking if server is running
2013-11-02 10:42:24,369 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2013-11-02 10:42:24,370 DEBUG [ServiioConsole] Retrieving console settings
2013-11-02 10:42:34,413 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2013-11-02 10:42:34,430 INFO [Messages] Loaded console message bundle for locale: en
2013-11-02 10:42:37,340 INFO [ServiioConsole] Exitting Serviio Console
2013-11-02 10:44:08,495 INFO [ServiioConsole] Initializing Serviio Console
2013-11-02 10:44:08,536 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-11-02 10:44:08,543 INFO [ServiioConsole] Starting Serviio Console
2013-11-02 10:44:08,642 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-11-02 10:44:08,718 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-11-02 10:44:08,718 DEBUG [ServiioConsole] Checking if server is running
2013-11-02 10:44:10,101 INFO [ServiioConsole] Initializing Serviio Console
2013-11-02 10:44:10,165 DEBUG [ApplicationInstanceManager] Port is already taken. Notifying first instance.
2013-11-02 10:44:10,174 DEBUG [ApplicationInstanceManager] Successfully notified first instance.
2013-11-02 10:44:10,175 INFO [ServiioConsole] Exitting Serviio Console
2013-11-02 10:44:10,175 DEBUG [ApplicationInstanceManager] Shared key matched - new application instance found
2013-11-02 10:44:19,178 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2013-11-02 10:44:19,179 DEBUG [ServiioConsole] Retrieving console settings
2013-11-02 10:44:29,241 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2013-11-02 10:44:29,257 INFO [Messages] Loaded console message bundle for locale: en
2013-11-02 10:44:44,213 INFO [ServiioConsole] Exitting Serviio Console
2013-11-02 10:46:33,592 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-11-02 10:46:33,702 INFO [MediaServer] ------------------------------------------------------------------------
2013-11-02 10:46:33,702 INFO [MediaServer] Serviio DLNA media streaming server v 1.3.1 (rev. f1fc8bc55657)
2013-11-02 10:46:33,702 INFO [MediaServer] Petr Nejedly 2009-2013
2013-11-02 10:46:33,702 INFO [MediaServer] http://www.serviio.org
2013-11-02 10:46:33,702 INFO [MediaServer] Java 1.7.0_45-Oracle Corporation
2013-11-02 10:46:33,702 INFO [MediaServer] OS Windows 7 amd64 6.1
2013-11-02 10:46:33,702 INFO [MediaServer] File encoding: windows-1252
2013-11-02 10:46:33,702 INFO [MediaServer] Headless mode enabled: true
2013-11-02 10:46:33,702 INFO [MediaServer] User: MEDIA-PC$
2013-11-02 10:46:33,702 INFO [MediaServer] User home dir: C:\
2013-11-02 10:46:33,702 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2013-11-02 10:46:34,092 INFO [WebServer] Socket buffer set to 65535 bytes
2013-11-02 10:46:34,123 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-11-02 10:46:34,263 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-11-02 10:46:34,263 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-11-02 10:46:34,294 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-11-02 10:46:34,326 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-11-02 10:46:34,934 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-11-02 10:46:37,836 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2013-11-02 10:46:37,836 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-11-02 10:46:37,836 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-11-02 10:46:37,836 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-11-02 10:46:37,836 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-11-02 10:46:37,836 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-11-02 10:46:37,836 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-11-02 10:46:37,851 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-11-02 10:46:37,851 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-11-02 10:46:37,851 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-11-02 10:46:37,851 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-11-02 10:46:37,851 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-11-02 10:46:37,851 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-11-02 10:46:37,851 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-11-02 10:46:37,851 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2013-11-02 10:46:37,851 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2013-11-02 10:46:37,867 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2013-11-02 10:46:37,882 DEBUG [LicenseValidator] Validating license file (377 bytes)
2013-11-02 10:46:38,179 INFO [Device] Created UPnP Device with UUID: c5db91ac-54f5-3daa-b7ba-6fea634c26b1, bound address: 192.168.0.3
2013-11-02 10:46:38,413 INFO [MediaServer] ------------------------------------------------------------------------
2013-11-02 10:46:38,413 INFO [MediaServer] License: PRO (NORMAL, id: 17089584-b13e-4f6a-a01d-b5b2d23df810)
2013-11-02 10:46:39,489 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-11-02 10:46:39,489 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-11-02 10:46:39,676 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-11-02 10:46:39,676 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-11-02 10:46:39,692 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-11-02 10:46:39,692 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-11-02 10:46:39,708 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-11-02 10:46:39,708 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-11-02 10:46:39,708 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-11-02 10:46:39,708 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-11-02 10:46:39,708 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-11-02 10:46:39,708 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-11-02 10:46:39,708 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-11-02 10:46:39,708 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-11-02 10:46:39,708 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E/F-series)' (id=7)
2013-11-02 10:46:39,708 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-11-02 10:46:39,708 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-11-02 10:46:39,723 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-11-02 10:46:39,723 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-11-02 10:46:39,723 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2013-11-02 10:46:39,723 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-11-02 10:46:39,723 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2013-11-02 10:46:39,723 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-11-02 10:46:39,739 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2013-11-02 10:46:39,739 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-11-02 10:46:39,739 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2013-11-02 10:46:39,739 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-11-02 10:46:39,739 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-11-02 10:46:39,739 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-11-02 10:46:39,739 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-11-02 10:46:39,754 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-11-02 10:46:39,770 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-11-02 10:46:39,770 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-11-02 10:46:39,786 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-11-02 10:46:39,786 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-11-02 10:46:39,786 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-11-02 10:46:39,786 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-11-02 10:46:39,786 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-11-02 10:46:39,786 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-11-02 10:46:39,786 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2013-11-02 10:46:39,786 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2013-11-02 10:46:39,786 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2013-11-02 10:46:39,786 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2013-11-02 10:46:39,786 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2013-11-02 10:46:39,910 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-11-02 10:46:39,910 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-11-02 10:46:39,910 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-11-02 10:46:39,910 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ios
2013-11-02 10:46:39,910 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2013-11-02 10:46:39,910 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2013-11-02 10:46:39,910 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2013-11-02 10:46:39,910 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2013-11-02 10:46:39,910 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2013-11-02 10:46:39,910 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2013-11-02 10:46:39,910 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2013-11-02 10:46:39,910 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2013-11-02 10:46:39,910 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-11-02 10:46:39,926 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-11-02 10:46:40,020 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-11-02 10:46:40,020 INFO [PluginCompilerThread] Started looking for plugins
2013-11-02 10:46:40,035 INFO [UpdateChecker] Checking if a new version is available
2013-11-02 10:46:40,051 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-11-02 10:46:40,051 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-11-02 10:46:40,472 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2013-11-02 10:46:40,488 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-11-02 10:46:40,488 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-11-02 10:46:41,845 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-11-02 10:46:41,845 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2013-11-02 10:46:41,845 INFO [PortMapper] Starting port mapping scheduler
2013-11-02 10:46:41,907 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2013-11-02 10:46:41,907 INFO [WebServer] WebServer starting on port 8895
2013-11-02 10:46:42,251 INFO [Device] Updated bound IP address of Device with UUID: c5db91ac-54f5-3daa-b7ba-6fea634c26b1, bound address: 192.168.0.3
2013-11-02 10:46:42,267 DEBUG [DiscoveryManager] UPNP device c5db91ac-54f5-3daa-b7ba-6fea634c26b1 (192.168.0.3) is available
2013-11-02 10:46:42,267 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-11-02 10:46:42,267 INFO [EventDispatcher] Starting EventDispatcher
2013-11-02 10:46:42,267 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-11-02 10:46:42,283 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-11-02 10:46:42,407 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.0.3, timeout = 0
2013-11-02 10:46:42,407 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.0.3, timeout = 0
2013-11-02 10:46:42,454 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5db91ac-54f5-3daa-b7ba-6fea634c26b1
2013-11-02 10:46:42,485 INFO [RendererSearchSender] Searching for Renderer devices
2013-11-02 10:46:42,485 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.0.3, timeout = 0
2013-11-02 10:46:42,485 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2013-11-02 10:46:42,501 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.3:52842s
2013-11-02 10:46:43,078 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:43,219 DEBUG [ServiioHttpService] Incoming request from /192.168.0.7:42599: GET /deviceDescription/c5db91ac-54f5-3daa-b7ba-6fea634c26b1 HTTP/1.0, headers = [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_BD-C5500/1.0,ACCEPT-LANGUAGE: en-us]]
2013-11-02 10:46:43,219 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.7
2013-11-02 10:46:43,265 DEBUG [ServiioHttpService] Incoming request from /192.168.0.7:55448: GET /deviceDescription/c5db91ac-54f5-3daa-b7ba-6fea634c26b1 HTTP/1.0, headers = [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_BD-C5500/1.0,ACCEPT-LANGUAGE: en-us]]
2013-11-02 10:46:43,265 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.7
2013-11-02 10:46:43,328 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c5db91ac-54f5-3daa-b7ba-6fea634c26b1 from 192.168.0.7 (headers = [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_BD-C5500/1.0,ACCEPT-LANGUAGE: en-us])
2013-11-02 10:46:43,328 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.7
2013-11-02 10:46:43,328 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_BD-C5500/1.0,ACCEPT-LANGUAGE: en-us]
2013-11-02 10:46:43,546 DEBUG [ServiioHttpService] Incoming request from /192.168.0.7:35001: GET /deviceDescription/c5db91ac-54f5-3daa-b7ba-6fea634c26b1 HTTP/1.0, headers = [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_BD-C5500/1.0,ACCEPT-LANGUAGE: en-us]]
2013-11-02 10:46:43,546 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.7
2013-11-02 10:46:43,546 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c5db91ac-54f5-3daa-b7ba-6fea634c26b1 from 192.168.0.7 (headers = [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_BD-C5500/1.0,ACCEPT-LANGUAGE: en-us])
2013-11-02 10:46:43,546 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.3:8895,USER-AGENT: SEC_HHP_BD-C5500/1.0,ACCEPT-LANGUAGE: en-us]
2013-11-02 10:46:44,077 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:44,529 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-11-02 10:46:44,980 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C/D/E/F-series)'
2013-11-02 10:46:45,092 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:46,092 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:47,092 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:48,101 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:48,112 DEBUG [NATPMPGateway] Removing router port mapping (23424 -> 23424)
2013-11-02 10:46:48,368 DEBUG [NATPMPGateway] Adding/updating router port mapping (23424 -> 23424) with lease of 1800 sec.
2013-11-02 10:46:48,501 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-11-02 10:46:49,105 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:50,107 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:51,109 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:52,109 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:52,364 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.0.3, timeout = 0
2013-11-02 10:46:52,364 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5db91ac-54f5-3daa-b7ba-6fea634c26b1
2013-11-02 10:46:53,097 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:54,095 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:54,329 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-11-02 10:46:55,108 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:56,107 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:57,109 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:58,109 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:46:59,109 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:47:00,108 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:47:01,109 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:47:02,104 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:47:02,365 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.0.3, timeout = 0
2013-11-02 10:47:02,365 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5db91ac-54f5-3daa-b7ba-6fea634c26b1
2013-11-02 10:47:03,114 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:47:04,096 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:47:04,330 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:32 (advertisement duration is 1800 sec.)
2013-11-02 10:47:05,106 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:47:06,116 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:47:07,122 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
2013-11-02 10:47:08,150 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.6:55428s
