Sony KDL46HX820
tidusmomo
Post Mon Nov 11, 2013 10:50 am
Sony KDL46HX820
Hello I'm french,
I need your help, I installed Serviio 1.3.1.
My problem: In the application I can see my Serviio Bravia TV with the IP 192.168.0.50 and I can watch my films. A few minutes later, when I close the file, it is impossible to go back in and when I look on the Serviio console, the IP address has changed for this new IP 192.168.27.14
Thank you for your help.
Post Mon Nov 11, 2013 10:58 am
Re: Sony KDL46HX820
Fix IP address of your Sony device under network settings.
Fix all devices IP address on your rooter settings.
tidusmomo
Post Mon Nov 11, 2013 9:01 pm
Re: Sony KDL46HX820
hello,
the fixed IP address is 192.168.0.50
hellp
tidusmomo
Post Tue Nov 12, 2013 11:11 am
Re: Sony KDL46HX820
hello,
I saw that post raist1976 has the same problem as me the Sun January 15, 2012 12:24 am samsung.
I need your help.
I did not close my eyes yesterday to find a solution.
thank you for your help.
ext3
Post Tue Nov 12, 2013 2:14 pm
Re: Sony KDL46HX820
Are you running serviio from windows? If so, please open "Command Prompt" as administrator (by right clicking) and execute:
ipconfig /all
Copy the result and paste it here (you can click on the top left corner of the Command Prompt window and under Edit you can select all and then select copy.)
I'm wondering if you might have 2 routers giving DHCP in your network....
tidusmomo
Post Tue Nov 12, 2013 5:35 pm
Re: Sony KDL46HX820
hello,
here is:
Microsoft Windows [version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Tous droits réservés.
C:\Users\Bureau>ipconfig /all
Configuration IP de Windows
Nom de l'hôte . . . . . . . . . . : Bureau-PC
Suffixe DNS principal . . . . . . :
Type de noeud. . . . . . . . . . : Hybride
Routage IP activé . . . . . . . . : Non
Proxy WINS activé . . . . . . . . : Non
Carte Ethernet Connexion au réseau local :
Suffixe DNS propre à la connexion. . . :
Description. . . . . . . . . . . . . . : Atheros AR8151 PCI-E Gigabit Etherne
t Controller
Adresse physique . . . . . . . . . . . : 1C-6F-65-E2-D3-24
DHCP activé. . . . . . . . . . . . . . : Non
Configuration automatique activée. . . : Oui
Adresse IPv6 de liaison locale. . . . .: fe80::69ae:dedf:54d9:2831%15(préféré
Adresse IPv4. . . . . . . . . . . . . .: 192.168.0.37(préféré)
Masque de sous-réseau. . . . . . . . . : 255.255.255.0
Passerelle par défaut. . . . . . . . . : 192.168.0.254
IAID DHCPv6 . . . . . . . . . . . : 320630629
DUID de client DHCPv6. . . . . . . . : 00-01-00-01-18-D9-28-E4-1C-6F-65-E2-D3
-24
Serveurs DNS. . . . . . . . . . . . . : 212.27.40.240
212.27.40.241
NetBIOS sur Tcpip. . . . . . . . . . . : Activé
Carte Tunnel isatap.{119AD47A-3DA0-408B-A8D7-8F9E5195D0FD} :
Statut du média. . . . . . . . . . . . : Média déconnecté
Description. . . . . . . . . . . . . . : Carte Microsoft ISATAP
Adresse physique . . . . . . . . . . . : 00-00-00-00-00-00-00-E0
ext3
Post Tue Nov 12, 2013 6:28 pm
Re: Sony KDL46HX820
Thanks for the comeback. I understand your TV is copper wired to the router right? or is it using WiFi?
tidusmomo
Post Tue Nov 12, 2013 8:01 pm
Re: Sony KDL46HX820
hello,
ci joint des printe de la console serviio.
before
Sans titre 1.jpg (113.32 KiB) Viewed 20574 times
after
Sans titre 2.jpg (118.01 KiB) Viewed 20574 times
tidusmomo
Post Tue Nov 12, 2013 9:07 pm
Re: Sony KDL46HX820
help :(
Post Wed Nov 13, 2013 12:24 am
Re: Sony KDL46HX820
Are you using a Freebox router? If so have a read of viewtopic.php?f=10&t=13883&hilit=freebox in which:
If you're not using the Freebox, have a read of viewtopic.php?f=10&t=4842 - it may help (there was no feedback as to whether Cerberus's suggetsion worked, but see if it's relevant to you).
ext3
Post Wed Nov 13, 2013 1:31 am
Re: Sony KDL46HX820
Is there by any chance any other device in your network that might be using the same IP 192.168.0.50?
tidusmomo
Post Wed Nov 13, 2013 8:12 am
Re: Sony KDL46HX820
hello,
Thank you for your reply, I am on Freebox V6 router.
I would do the test tonight, thank you very much for your help.
it will be available when the version 1.4 beta?
for info I have another pc conecter wifi it works very well with Serviio and my tv.
both PCs are on windows is a professional Seven conecter by RJ45 and the other WiFi.
I do not understand anything
tidusmomo
Post Wed Nov 13, 2013 8:20 am
Re: Sony KDL46HX820
ext3 wrote:Is there by any chance any other device in your network that might be using the same IP 192.168.0.50?
no!! I checked
tidusmomo
Post Wed Nov 13, 2013 7:38 pm
Re: Sony KDL46HX820
still no solution
Post Thu Nov 14, 2013 9:55 am
Re: Sony KDL46HX820
The problem comes from the Freebox router. I could not help you there. Check on free forum.
On your router settings (DHCP), you have to fix all IP address of all your devices (TV, PC, printer,etc.) according to there MAC address.
For example, check this "Etape 3 : configurez le serveur DNS": http://www.01net.com/editorial/544932/c ... evolution/
tidusmomo
Post Thu Nov 14, 2013 7:17 pm
Re: Sony KDL46HX820
hello,
thank you for your help, I followed the tutorial in your link.
it still does not function, always the same problem.
here is a screen printing.
thank you for your help, I will not asher case I love your software lol
IP fixe.jpg (187.01 KiB) Viewed 20477 times
Post Fri Nov 15, 2013 7:57 am
Re: Sony KDL46HX820
Freebox config seems good ....
Do you try to fix ip address on Sony Bravia device:192.168.0.50 ?
Home->Network->Network Set-up->Wired Set-up->IP Address Setting->[Manual]:
http://pdf.crse.com/manuals/iManuals/en ... twork.html
[IP Address] : 192.168.0.50
[Subnet Mask] : 255.255.255.0
[Default Gateway] : 192.168.0.254 (ou 192.168.0.1 ??) (Freebox IP address)
[Primary DNS] : 192.168.0.254
[Secondary DNS] : 192.168.0.254
tidusmomo
Post Fri Nov 15, 2013 10:02 am
Re: Sony KDL46HX820
Hello Illico,
I confirm that the Bravia TV is set to the IP address 192.168.0.50 fix
[IP Address]: 192.168.0.50
[Subnet Mask]: 255.255.255.0
[Default Gateway]: 192.168.0.254 (Freebox IP address)
I try to 192.168.0.254 dns
[Primary DNS]: 212.27.40.240
[Secondary DNS]: 212.27.40.241
thank you
Post Fri Nov 15, 2013 10:40 am
Re: Sony KDL46HX820
tidusmomo wrote:Hello Illico,
I confirm that the Bravia TV is set to the IP address 192.168.0.50 fix...
I think, you have to set the router ip address for dns or nothing (192.168.0.254), (212.27.40.240 and 212.27.40.241 are external FAI dns, used by the router for external ip resolution, ie your external internt ip address).
You confirm that 192.168.0.254 is the free router ip address, when you type it on internet explorer browser you enter in the freebox init webpage ?
tidusmomo
Post Fri Nov 15, 2013 3:54 pm
Re: Sony KDL46HX820
hello,
I just tested it does not work at all, I'm after a nerve.
it included a sample configuration on the pc
thank you
Sans titre.jpg (349.76 KiB) Viewed 20418 times
