Profile 2013 download?
steve11
Post Thu Oct 10, 2013 9:38 pm
Have serviio 131 and Sony 55W905. Where can I load the profile for 2013 models?
Post Fri Oct 11, 2013 2:03 am
Re: Profile 2013 download?
Illico is developing a 2013 profile, currently in beta. See viewtopic.php?f=11&t=11147 and follow the instructions in that post.
steve11
Post Fri Oct 11, 2013 2:17 pm
Thank you
BR
Steve
steve11
Post Fri Oct 11, 2013 2:35 pm
Does not function! Now starts serviio no more. Please help!
Steve
Post Fri Oct 11, 2013 2:55 pm
_copy the 2013 profile section code in the profiles.xml file, just before the last </Profiles> element
What is your serviio version ?
steve11
Post Fri Oct 11, 2013 10:23 pm
I have always the current version 1.31. Now it functions!
I work at Sony in Germany and test straight models of 2013 with serviio. Thanks for the great program!
BR
Steve
Post Sat Oct 12, 2013 7:13 am
steve11 wrote:I work at Sony in Germany and test straight models of 2013 with serviio. Thanks for the great program!
Sony Bravia 2013 profile is a beta version but we will probably add it to the next 1.4 version. So if you have problem or suggestion about this profile, post your issue here.
anmol
Post Sun Nov 10, 2013 12:19 am
Hi Guys
I have recently purchased a sony xbr-55x900a. Unfortunately Serviio DLNA server does not get detected by this Sony TV. I have tried supplied profiles with no luck. This is not a networking issue as i can ping TV ip address from serviio server. Sony XBR TV has no issues detecting other dlna server on network- seagate Network attached storage running DLNA server- Seagate central. I quite like serviio and would like to use it with XBR TV. Any help is most appreciated. Many Thanks
- Anmol
Post Sun Nov 10, 2013 8:41 am
What is your country ? US, CA, MX ?
Could you provide information about format supported by your device ?
see signature link
With the 2013 profile, you can try to edit this line :
<FriendlyName>BRAVIA (KDL-\d{2}W[689]\d{2}A.*)|(KD-\d{2}X9005A.*)|(XBR-\d{2}X9\d{2}A.*)</FriendlyName>
anmol
Post Sun Nov 10, 2013 7:44 pm
I am from New Zealand and purchased TV in NZ. I believe this particular model is sold in APAC region.
I have attached DLNA relevant sections from TV manual for reference.
Many Thanks for your help.
manual.zip
TV Manual DLNA section
(486.6 KiB) Downloaded 684 times
anmol
Post Sun Nov 10, 2013 9:38 pm
PS- I will attempt editing line as suggested later tonight and update you
anmol
Post Mon Nov 11, 2013 8:13 am
Is this correct? Mine doesn't look corect
<FriendlyName>BRAVIA (KD-\d{2}W[689]\d{2}A.*)|(KD-\d{2}X9004A.*)</FriendlyName>
TV is
http://www.sony.co.nz/product/kd-55x9004a
Log file attached
Ip address of Tv 192.168.2.213/24
Ip of serviio 192.168.2.222/24
serviio.zip
(476.66 KiB) Downloaded 723 times
Post Mon Nov 11, 2013 8:58 am
anmol wrote:Is this correct? Mine doesn't look corect
TV is
On your friendlyname, BRAVIA disappeared.
Replace the original
<FriendlyName>BRAVIA (KDL-\d{2}W[689]\d{2}A.*)|(KD-\d{2}X9005A.*)</FriendlyName>
by
<FriendlyName>(BRAVIA KDL-\d{2}W[689]\d{2}A.*)|(KD-\d{2}X9\d{3}A.*)</FriendlyName>
anmol
Post Tue Nov 12, 2013 5:47 am
I am assuming that on this forum
Second part where it says code but I only see http get requests- I have not added this second part anywhere in configs. I have added first code bit as per above instructions in profile. still no luck. Serviio not getting detected. I have attached my 2013 profile and log for reference.
logprofile.zip
(435.01 KiB) Downloaded 670 times
anmol
Post Wed Nov 13, 2013 7:37 pm
Hey Guys
Any help is most appreciated?
Regards
Anmol
Post Thu Nov 14, 2013 10:09 am
copy the following code in the original profiles.xml file (backup before), just before the last </Profiles> element, save and restart your PC.
If serviio does not automatically detect your device and select the proper 2013 profile, do it manually on serviio console.
<Profile id="sony2013" name="Sony Bravia TV (2013)" extendsProfileId="1">
   <!-- 2013 models
          Codec list supported : http://pdf.crse.com/manuals/13MW802111/FR/codeclist.html#5
          - Still images: JPEG (*.jpg / *.jpe / *.jpeg), MPO (*.mpo), RAW (*.arw)
          - Music: LPCM, MP1L1 / MP1L2 / MP1L3 / MP2L1 / MP2L2 / MP2L3 / MP2.5L3 (*.mp3), AAC-LC / HE-AAC v1/v2 (*.mp4 / *.m4a / *.3gp / *.3g2), WMA9 (*.wma)
          - Video: MPEG1 / MPEG2PS / AVCHD , MP4, Xvid, Motion JPEG, VC1, MKV, 3gpp, MOV, WebM
   <Detection>
      <UPnPSearch>
         <FriendlyName>.*KD-\d{2}X9\d{3}A.*)</FriendlyName>
      </UPnPSearch>
   </Detection>
   <DeviceDescription>
      <!-- act as WMP so that the TV doesn't show root categories -->
      <ModelName>Windows Media Player Sharing</ModelName>
      <ModelNumber>3.0</ModelNumber>
      <Manufacturer>Microsoft Corporation</Manufacturer>
   </DeviceDescription>
   <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
   <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
   <MediaFormatProfiles>
      <!-- Rename native WMA formats to those supported by the tv -->
      <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMABASE">WMA_BASE</MediaFormatProfile>
      <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMAFULL">WMA_FULL</MediaFormatProfile>
      <!-- Rename 3gp profiles that can be played as AVC -->
      <MediaFormatProfile mime-type="video/mp4" name="AVC_MP4_MP_SD_AAC_MULT5">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
      <!-- Rename native avi formats to those supported by the tv -->
      <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
      <!-- Rename native mpeg2ts with h264+ac3/aac formats to those supported by the tv (aac support is not advertised by the renderer but it works) -->
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
      <!-- Rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
   </MediaFormatProfiles>
   <H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
      <!-- Transcode all h264 video with HIGH/MAIN > Level 4.2 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
      <!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" forceInheritance="true">
         <Matches container="*" vCodec="h264" profile="high_10" />
         <Matches container="*" vCodec="h264" profile="high_444" />
         <Matches container="*" vCodec="h264" profile="high_422" />
         <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
         <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
      <!-- Remux containers with h264 video + AC3 audio to MPEG-TS stream without transcoding -->
      <!-- Remux matroska/mpeg2video + AC3 audio to MPEG-TS stream without transcoding -->
      <Video targetContainer="mpegts" forceInheritance="true">
         <Matches container="avi" vCodec="h264" aCodec="ac3" />
         <Matches container="flv" vCodec="h264" aCodec="ac3" />
         <Matches container="wtv" vCodec="h264" aCodec="ac3" />
         <Matches container="matroska" vCodec="mpeg2video" aCodec="ac3" />
      <!-- Remux all other h264 video to MPEG-TS stream with ac3 audio transcoding -->
      <!-- Remux all other matroska/mpeg2video to MPEG-TS stream with ac3 audio transcoding -->
      <Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true">
         <Matches container="*" vCodec="h264" aCodec="truehd" />
         <Matches container="*" vCodec="h264" aCodec="flac" />
         <Matches container="wtv" vCodec="h264" />
      <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
         <Matches container="mpegts" vCodec="vc1" />
         <Matches container="flv" />
         <!-- example: flv/vp6/mp3 -->
         <Matches container="wtv" />
         <Matches container="ogg" />
         <Matches container="rm" />
         <!--Matches container="3gp" vCodec="mpeg4" /-->
         <!--Matches container="3gp" vCodec="h263" /-->
         <!-- digital camera video formats -->
         <Matches container="asf" vCodec="vc1" aCodec="wmapro" />
         <Matches container="mp4" vCodec="dvvideo" />
      <Audio targetContainer="lpcm" forceInheritance="true">
         <Matches container="rtp" />
         <Matches container="rtsp" />
         <Matches container="flac" />
         <Matches container="adts" />
      </Audio>
   <HardSubsTranscoding>
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" />
   </HardSubsTranscoding>
   <Subtitles>
      <HardSubs>
         <RequiredFor container="mpegts" />
         <RequiredFor container="mp4" />
         <RequiredFor container="avi" />
      </HardSubs>
   </Subtitles>
anmol
Post Fri Nov 15, 2013 9:22 pm
No luck my friend. please refer profile attached
profiles.xml
(110.71 KiB) Downloaded 904 times
Post Sat Nov 16, 2013 8:51 am
I'm not sure to understand your problem.
Could you clear the device list on serviio console, save, and refresh it, what appears now on serviio console device list?
What is your OS?
Do you open TCP 8895 and UDP 1900 ports in firewall?
http://www.serviio.org/index.php?option ... ticle&id=5
anmol
Post Sat Nov 16, 2013 9:23 pm
There is no firewall enabled. This is a single subnet. I have a sony blue ray player with dlna and that gets detected fine by serviio(same computer used for tv) on same network. OS is windows XP sp3. Everything is cabled underfloor with cat6 cabling.
When I remove TV - TV is detected as unknown device and assigned generic profile.
anmol
Post Sun Nov 17, 2013 7:36 pm
Wondering if some sort of logs will help? I can get a wireshark packet capture from serviio server? Would that help?
Users browsing this forum: Baidu [Spider], Google [Bot] and 15 guests
