Unexpected stopping playing LG 42LM640T
nickmz
Post Thu Nov 07, 2013 8:10 am
Re: Unexpected stopping playing LG 42LM640T
Googled this post. I have the same error with Serviio 1.3.1, Ubuntu 12.04, BubbleUPnP client on Android
2013-11-04 20:31:25,126 WARN  [ResourceDeliveryProcessor] Invalid request, sending back 400 error
org.serviio.upnp.protocol.http.transport.InvalidResourceRequestException: Invalid incoming request: /resource/30226/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0
        at org.serviio.upnp.protocol.http.transport.RequestedResourceDescriptor.<init>(RequestedResourceDescriptor.java:69)
        at org.serviio.upnp.protocol.http.transport.AbstractProtocolHandler.getRequestedResourceDescription(AbstractProtocolHandler.java:36)
        at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:65)
        at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
        at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 3
        at org.serviio.upnp.protocol.http.transport.RequestedResourceDescriptor.<init>(RequestedResourceDescriptor.java:66)
        ... 8 more
nickmz
Post Thu Nov 07, 2013 8:40 am
I think you should protect
this.quality = DeliveryQuality.QualityType.valueOf(requestFields[3]);
with
 if (requestFields.length > 3) {}
and use default value for QualityType.
Sorry, was too upset and used JD-GUI :)
jayhawk81
Post Thu Nov 07, 2013 5:29 pm
Can you please elaborate on the above code? Where does it need to go? Is this replacing the first line of code with the second you provided or adding the second one?
nickmz
Post Fri Nov 08, 2013 4:53 am
It's all about the internal Java code - developers should know what to do with that. The problem is that Java code accesses the element by index #3 without ensuring that the array has at least 4 header elements.
Post Sun Nov 10, 2013 6:52 pm
do you have a longer log to see the incoming request?
From my experience, BubbleUPnP caches some responses, so if you switch profiles it'll still send request for files that don't exist for the current profile (particular transcoded versions). That is a bad request, and sending a default quality (or a file transcoded to an unsupported file for a different profile) would be wrong.
nickmz
Post Mon Nov 11, 2013 6:33 am
Here it is - https://dl.dropboxusercontent.com/u/314 ... iio.log.gz
I've switched to using "MediaHouse UPnP / DLNA Browser" - I'll see how it works.
Post Mon Nov 11, 2013 5:19 pm
Could you try AV media Controller (see Intel tools in my signature), browse to the same file, get its properties and post here the resource URLs?
The URLs in the log are missing the /ORIGINAL bit, I need to confirm if it's the player ignoring it or Serviio not serving it.
nickmz
Post Wed Nov 13, 2013 7:07 am
Sorry - I have no .NET/Mono installed. I tried UPnP-Inspector instead.
Here is the DB selection for failed items:
https://dl.dropboxusercontent.com/u/3146456/serviio/serviio.txt
Here are the screenshots of UPnP-Inspector for two failed items:
https://dl.dropboxusercontent.com/u/3146456/serviio/Browse%20MediaServer%20Serviio%20(nas)_024.png
https://dl.dropboxusercontent.com/u/3146456/serviio/Browse%20MediaServer%20Serviio%20(nas)_025.png
It seems that Serviio provides correct URL - at least right now and for UPnP-Inspector
Post Fri Nov 15, 2013 3:43 pm
Looks like it..
nickmz
Post Sun Nov 17, 2013 6:53 am
I've checked once again. The exception occured on Android both in Bubble UPnP and MediaHouse but ONLY when a video is passed to MX Player. Passing to any other video player didn't lead to the exception. The exception in Serviio didn't stop MX Player from playing the video - I didn't noticed any visual problem.
bubbleguuum
Post Sun Nov 17, 2013 12:41 pm
nickmz wrote:I've checked once again. The exception occured on Android both in Bubble UPnP and MediaHouse but ONLY when a video is passed to MX Player. Passing to any other video player didn't lead to the exception. The exception in Serviio didn't stop MX Player from playing the video - I didn't noticed any visual problem.
MX Player does additional http requests based on the http URL is was given to play, to infer eventual subtitles URLs.
In these additional requests it may remove the last path segment of the URL.
subora
Post Sun Mar 23, 2014 6:51 pm
Hello! Once again that error - jusi watching and unexpected stopping playing.
DS413, serviio 1.4.1.1, last 1.7 java
This is log:
2014-03-23 21:59:14,384 INFO [RendererManager] Stored a new renderer: uuid='9382df87-7c09-4b84-a90f-898e3b752e4b', name = 'LG TV / player', ipAddress='192.168.0.119', profile = '8'
2014-03-23 22:06:07,672 INFO [RendererManager] Stored a new renderer: uuid='2996bba4-1dd2-11b2-86e1-fe92e7b41bda', name = 'LG TV', ipAddress='192.168.0.119', profile = '1'
2014-03-23 22:08:45,667 INFO [RendererManager] Stored a new renderer: uuid='497ec32e-3b20-43d5-8d0d-9f82910295ca', name = 'LG TV / player', ipAddress='192.168.0.119', profile = '8'
2014-03-23 22:13:08,498 INFO [RendererManager] Stored a new renderer: uuid='2996bba4-1dd2-11b2-86e1-fe92e7b41bda', name = 'LG TV', ipAddress='192.168.0.119', profile = '1'
2014-03-23 22:46:20,780 INFO [RendererManager] Stored a new renderer: uuid='c724ea79-d9d8-4016-aa31-608dd10d808b', name = 'LG TV / player', ipAddress='192.168.0.119', profile = '8'
2014-03-23 22:46:21,121 WARN [EventDispatcher] Couldn't send event message for subscription 98267348-d048-45df-9c93-8516062e05ce, will keep trying until subscription expires
2014-03-23 22:46:21,126 WARN [EventDispatcher] Couldn't send event message for subscription e9241561-9d2f-477c-8155-36c84a46dd8d, will keep trying until subscription expires
subora
Post Wed Apr 02, 2014 7:08 am
Hello! Once again and smth new erorrs:
see more: http://pastebin.com/39U2SER3
Previous
Return to LG
Users browsing this forum: Baidu [Spider] and 2 guests
