Samsung F serie problem with 59p
cdr
Post Wed Nov 13, 2013 2:23 pm
I've tried to use Serviio to play on my Samsung 40F6500 my camcorder files via DLNA. These files are MP4 h.264 1920x1080@60p (60 progressive frames).
Without transcoding they do not play, so I've tried with "DIrectTV HD-DVR" profile and obtained the same error from TV: frame rate 59p not supported.
The camera specs (Sanyo FH1) show 60p and not 59p. However, how to set servio to transcode properly ?
Is it possible to change only frame rate to 60 ?
Thank you.
Best regards,
cdr
Post Fri Nov 15, 2013 3:23 pm
Re: Samsung F serie problem with 59p
can you post ffmpeg -i of the file. And possibly upload a small video example for me to try to reproduce?
cdr
Post Fri Nov 15, 2013 10:34 pm
zip wrote:can you post ffmpeg -i of the file. And possibly upload a small video example for me to try to reproduce?
Thank you for response :)
Here is the video example and command output:
http://www.mediafire.com/?1lev0vw2xdvmjrq
D:\video\Sanyo FH1\>ffmpeg.exe -i SANY1826.MP4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'SANY1826.MP4':
major_brand : mp42
minor_version : 1
compatible_brands: mp42avc1
creation_time : 2013-11-01 11:43:56
comment : SANYO DIGITAL CAMERA FH1
comment-eng : SANYO DIGITAL CAMERA FH1
Duration: 00:00:30.26, start: 0.000000, bitrate: 24314 kb/s
Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuvj420p, 1920x108
0 [SAR 1:1 DAR 16:9], 24092 kb/s, 59.94 fps, 59.94 tbr, 60k tbn, 119.88 tbc
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 12
7 kb/s
Best regards,
cdr
Post Sun Nov 17, 2013 11:44 am
Thanks, I'll look at it in a few days and try to reproduce it.
cdr
Post Wed Nov 27, 2013 9:30 am
zip wrote:Thanks, I'll look at it in a few days and try to reproduce it.
Hi zip,
have you been able to repoduce the problem ?
Thank you.
Best regards,
cdr
Post Wed Nov 27, 2013 11:10 pm
I don't have access to a Samsung at the moment, but will in a week or so, so will test then.
Post Tue Dec 03, 2013 9:49 pm
I have the same problem with the file. There is no way to change frame rate on the fly in Serviio, so you will have to reencode the file to 60fps. Hopefully that will sort that out for you.
cdr
Post Mon Dec 09, 2013 10:53 am
zip wrote:I have the same problem with the file. There is no way to change frame rate on the fly in Serviio, so you will have to reencode the file to 60fps. Hopefully that will sort that out for you.
Thank you but I've a huge collection of files recorder by Sanyo FH1 and was hoping to see them on my Samsung F6500 through Serviio ...
I think the problem with F6500 serie is for all files with FPS > 30 (progressive); so, will be possible with Serviio to half the frame rate ?
Thank you again.
Best regards,
cdr
Post Tue Dec 10, 2013 5:06 pm
Not currently
Users browsing this forum: No registered users and 51 guests
