Sound Query On a Samsung
rgill90
Post Thu Nov 14, 2013 10:17 pm
Heya
I'm using Serviio on a synology NAS connected to a Samsung UE46F5500 - everything works as expected - it's just the sound mode. Say I watch an .mkv with a DD Soundtrack (only soundtrack in that mkv container) i have to change the TV Sound to output Dolby Digital rather than PCM through it's SPDIF channel. If i watch another .mkv with Dolby Digital from then on it'll default to dolby digital mode - which is fine. However, if i now play a .mkv with a DTS soundtrack, then TV will go back to outputting PCM through the digial output - i have to go into the menu and change it to DTS manually.
Is there any way I can set the TV to output the "Best" quality sound in a given .mkv file?
Cheers
Rich
rgill90
Post Sat Nov 16, 2013 1:53 pm
Re: Sound Query On a Samsung
anyone..? i'm quite happy to do some experimenting in the profiles.xml under the samsung profile...but just need a few pointers on which sections i should look at / concentrate on under the "Samsung TV / player (C/D/E/F-series)" bit (that's if anyone thinks i'd be able to fix the issue by tweaking the profile)
Post Sun Nov 17, 2013 11:43 am
NOrmally there is no transcoding happening for the Samsung devices, so the file is delivered as-is. This looks like the TV remembers your favourite / last used setting and uses it for all your files subsequently as the default setting. If this is the case it's not in the realm of Serviio to change this.
