Sony Bravia TV can't see Serviio
ytrebil
Post Wed Nov 13, 2013 8:37 pm
Hi guys, not quite sure what's happened as things were working previously.
I have set up in my Netgear router for the correct ports to be open (TCP port 8895 and UDP 1900). I wasn't sure whether to put it as Inbound or Outbound on my Firewall Rules, so added them both to both Inbound and Outbound and used the LAN IP of the Inbound as the computer's IP where Serviio is installed.
Serviio can see my TV and it has a green dot (Sony Bravia TV (2011)). However, in my TV's settings, I've tried refreshing the server list, deleting it etc and it's just not finding anything.
I've given a static IP address to my TV.
Is there anything I'm missing out? Do I need to create a Firewall Rule for the TV in my router at all?
Thanks a lot guys - driving me nuts!
edit: My Sony Bravia can connect to the internet fine.
edit edit: I know a few people ask to see the ipconfig. I'm not sure if this will help or not:
Windows IP Configuration
Host Name . . . . . . . . . . . . : PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : F4-6D-04-71-AB-CC
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::19dd:b8f3:78fd:a0b5%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 11 November 2013 22:55:07
Lease Expires . . . . . . . . . . : 16 November 2013 19:42:25
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 250899716
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-16-65-D5-2F-F4-6D-04-71-AB-CC
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Post Thu Nov 14, 2013 9:50 am
Re: Sony Bravia TV can't see Serviio
So
- 192.168.0.1 is the router IP address.
- 192.168.0.2(Preferred) is the PC(serviio) IP address.
What is the fixed, Sony IP address ?
ytrebil
Post Thu Nov 14, 2013 10:52 pm
Hi, it's 192.168.0.11
I have a feeling it could be my PC causing the issue though as when trying to access my network settings in windows 7 it freezes and doesn't seem to be playing ball.
I've reinstalled network drivers and run a virus and malware scan but can't seem to fix it right now.
