Metadata extraction support
Quiffster
Post Fri Jan 28, 2011 11:59 am
Great to see xbmc and some other support but, a real easy quick win would be to support:
1. folder.jpg or folder.png for video folders (not just audio). This is typically used by mediabrowser for WMC7, WMC7 itself and produced from various tools like metabrowser and yammm.
2. mymovies.xml - produced by mymovies, also by metabrowser and some others.
These files are generally in the same folder as the video for the generally accepted folder structure of one movie per folder.
Otherwise - what a great product - the only product that I have successfully used with my Sony Bravia TV (including Mezzmo - which was ....almost there.....) and its ridiculous requirement to have almost everything transcoded....
Steve.
Post Fri Jan 28, 2011 12:40 pm
Re: Metadata extraction support
folder.jpg can be supported, no problem, create a bitbucket ticket please. Currently supported file names are here: http://www.serviio.org/index.php?option ... icle&id=12
It's planned (https://bitbucket.org/xnejp03/serviio/i ... -my-movies), just waiting for them to implement series
dalanik
Post Fri Jan 28, 2011 1:42 pm
while you're at it, it could be a good idea to support .jpg that has the same name as movie...
D.
Quiffster
Post Fri Jan 28, 2011 2:01 pm
Dalanik
I believe it already does - thats what the link says (look at video at bottom of page).
Steve.
Quiffster
Post Fri Jan 28, 2011 2:05 pm
1. Bitbucket created.
2. Try series.xml - these are created by metabrowser. I have lots of examples if you want some.
Steve.
Post Fri Jan 28, 2011 3:12 pm
Quiffster wrote:2. Try series.xml - these are created by metabrowser. I have lots of examples if you want some.
Is mymovies going to use the same format?
Quiffster
Post Fri Jan 28, 2011 3:47 pm
I have no idea. I know that the format is the one used by thetvdb. Look at the series.xml i have attached for the "Chuck" series, and then look at the api query too.
http://thetvdb.com//api/E8D8A47528D5B5A ... 348/en.xml
(80348 is the series ID) and the en.xml is the English series.xml.
These are present for the root of the series folder. There are then subfolders: Season 1, Season 2, Season x etc., and also a "Specials" folder too.
There is a discrete xml file for each episode (I have attached an example) - usually named the same as the episode itself. Metabrowser and mediabrowser use a "metadata" sub folder for each season to store these xml files, and the folders usually include jpg episode screen grabs. the data is all scraped out of thetvdb web service calls....
an example of my Chuck folder structure is here:
Directory of T:\chuck
27/01/2011 17:45 <DIR> .
27/01/2011 17:45 <DIR> ..
27/09/2009 21:53 729,910 backdrop.jpg
27/09/2009 21:53 70,864 banner.jpg
28/07/2010 20:00 815,934 folder.png
28/07/2010 20:00 144,513 folderbkp.jpg
27/01/2011 19:25 <DIR> Season 1
28/07/2010 18:03 <DIR> Season 2
24/01/2011 17:16 <DIR> Season 3
27/01/2011 19:25 <DIR> Season 4
27/01/2011 19:22 2,055 series.xml
5 File(s) 1,763,276 bytes
Directory of T:\chuck\Season 1
27/01/2011 19:25 <DIR> .
27/01/2011 19:25 <DIR> ..
27/01/2011 19:25 729,910 backdrop.jpg
27/01/2011 19:25 133,469 backdrop1.jpg
17/04/2008 12:43 366,534,656 Chuck - s01e01 - Chuck vs. the Intersect.avi
17/04/2008 12:50 367,097,856 Chuck - s01e02 - Chuck Versus the Helicopter.avi
17/04/2008 12:52 366,312,824 Chuck - s01e03 - Chuck Versus the Tango.avi
17/04/2008 13:21 368,031,744 Chuck - s01e04 - Chuck Versus the Wookiee.avi
17/04/2008 13:16 365,899,210 Chuck - s01e05 - Chuck Versus the Sizzling Shrimp.avi
17/04/2008 13:17 366,988,670 Chuck - s01e06 - Chuck Versus the Sandworm.avi
17/04/2008 13:17 367,570,944 Chuck - s01e07 - Chuck Versus the Alma Mater.avi
17/04/2008 13:34 367,056,730 Chuck - s01e08 - Chuck Versus the Truth.avi
17/04/2008 13:35 367,718,516 Chuck - s01e09 - Chuck Versus the Imported Hard Salami.avi
17/04/2008 13:35 365,842,432 Chuck - s01e10 - Chuck Versus the Nemesis.avi
17/04/2008 13:35 367,096,088 Chuck - s01e11 - Chuck Versus the Crown Vic.avi
17/04/2008 13:35 367,765,376 Chuck - s01e12 - Chuck Versus the Undercover Lover.avi
17/04/2008 13:33 366,666,740 Chuck - s01e13 - Chuck Versus the Marlin.avi
27/09/2009 21:53 353,728 folder.png
27/09/2009 21:53 91,846 folderbkp.jpg
28/01/2011 15:32 <DIR> metadata
17 File(s) 4,771,890,739 bytes
Directory of T:\chuck\Season 1\metadata
28/01/2011 15:32 <DIR> .
28/01/2011 15:32 <DIR> ..
28/07/2010 20:10 21,405 332179.jpg
27/09/2009 21:53 21,405 332179bkp.jpg
27/09/2009 21:54 171,280 336270.png
27/09/2009 21:54 34,206 336270bkp.jpg
27/09/2009 21:54 183,225 336271.png
27/09/2009 21:54 37,096 336271bkp.jpg
14/04/2010 20:03 26,347 336272.jpg
27/09/2009 21:54 206,211 336272.png
27/09/2009 21:54 20,121 336272bkp.jpg
27/09/2009 21:54 157,535 337832.png
27/09/2009 21:54 30,164 337832bkp.jpg
27/09/2009 21:54 225,963 337833.png
27/09/2009 21:54 26,633 337833bkp.jpg
27/09/2009 21:54 211,729 337834.png
27/09/2009 21:54 24,957 337834bkp.jpg
27/09/2009 21:54 194,876 339150.png
27/09/2009 21:54 17,933 339150bkp.jpg
27/09/2009 21:54 204,699 339469.png
27/09/2009 21:54 59,760 339469bkp.jpg
27/09/2009 21:54 218,814 341881.png
27/09/2009 21:54 45,113 341881bkp.jpg
27/09/2009 21:54 236,433 341882.png
27/09/2009 21:54 32,858 341882bkp.jpg
27/09/2009 21:54 228,760 349301.png
27/09/2009 21:54 36,353 349301bkp.jpg
27/09/2009 21:54 92,745 349302.png
27/09/2009 21:54 19,215 349302bkp.jpg
28/07/2010 20:10 1,138 Chuck - s01e01 - Chuck vs. the Intersect.xml
20/02/2010 11:35 1,189 Chuck - s01e01 - Pilot.xml
20/02/2010 11:35 1,182 Chuck - s01e02 - Chuck Versus the Helicopter.xml
20/02/2010 11:35 1,145 Chuck - s01e03 - Chuck Versus the Tango.xml
20/02/2010 11:35 1,061 Chuck - s01e04 - Chuck Versus the Wookie.xml
02/05/2010 09:49 1,047 Chuck - s01e04 - Chuck Versus the Wookiee.xml
20/02/2010 11:35 1,228 Chuck - s01e05 - Chuck Versus the Sizzling Shrimp.xml
20/02/2010 11:35 1,206 Chuck - s01e06 - Chuck Versus the Sandworm.xml
20/02/2010 11:35 1,284 Chuck - s01e07 - Chuck Versus the Alma Mater.xml
20/02/2010 11:35 1,318 Chuck - s01e08 - Chuck Versus the Truth.xml
20/02/2010 11:35 1,205 Chuck - s01e09 - Chuck Versus the Imported Hard Salami.xml
20/02/2010 11:35 1,180 Chuck - s01e10 - Chuck Versus the Nemesis.xml
20/02/2010 11:35 1,240 Chuck - s01e11 - Chuck Versus the Crown Vic.xml
20/02/2010 11:35 1,212 Chuck - s01e12 - Chuck Versus the Undercover Lover.xml
20/02/2010 11:35 1,303 Chuck - s01e13 - Chuck Versus the Marlin.xml
42 File(s) 2,803,774 bytes
Directory of T:\chuck\Season 2
and so on......
You will see from looking inside the episode xml file the reference to the relevant screen grab etc.
Hope this helps....
(1.11 KiB) Downloaded 710 times
series.xml
Chuck Series.xml file.
(2.01 KiB) Downloaded 689 times
Post Fri Jan 28, 2011 5:54 pm
I'm already using thetvdb.com for series metadata extraction. I'll wait for them to implement it, hopefully it'll be soon
Return to Feature requests
