KDL-42W670A Playback Problems
bla99ard
Post Sat Nov 16, 2013 8:09 am
I have searched for the solution but, possibly due to frustration, cannot see the forest for the trees.
I have transcoding enabled and I am running the Sony Bravia TV (2012) profile.
Some files play. Some do not. I can only put it down to video resolution but I don't know. I am very frustrated.
Here is the ffmpeg output of a file that works. It is played in the wrong aspect ratio but at least it plays. :)
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\SHOWS\TV Shows\Star Trek Voyager\
Star.Trek.Voyager.S04\star_trek_voyager.4x03.day_of_honor.ac3.dvdrip.xvid-youngd
angerous.avi"
Input #0, avi, from 'F:\SHOWS\TV Shows\Star Trek Voyager\Star.Trek.Voyager.S04\s
tar_trek_voyager.4x03.day_of_honor.ac3.dvdrip.xvid-youngdangerous.avi':
encoder : VirtualDubMod 1.5.4.1 (build 2178/release)
IAS1 : English
Duration: 00:46:00.34, start: 0.000000, bitrate: 1064 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv
420p, 576x432 [SAR 1:1 DAR 4:3], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, fltp, 192 k
b/s
Here is the ffmpeg output of a file that won't play.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\SHOWS\TV Shows\Star Trek The Next
Generation\Season 6\Star Trek TNG - 6x10 - Chain of Command - Part I.avi"
Input #0, avi, from 'F:\SHOWS\TV Shows\Star Trek The Next Generation\Season 6\St
ar Trek TNG - 6x10 - Chain of Command - Part I.avi':
encoder : VirtualDubMod 1.5.10.1 (build 2366/release)
Duration: 00:42:31.72, start: 0.000000, bitrate: 565 kb/s
Stream #0:0: Video: mpeg4 (DX50 / 0x30355844), yuv420p, 448x352 [SAR 1:1 DAR
14:11], 23.98 fps, 23.98 tbr, 23.98 tbn, 30k tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16p, 80 kb
/s
Post Sat Nov 16, 2013 8:40 am
Re: KDL-42W670A Playback Problems
bla99ard wrote:Here is the ffmpeg output of a file that works. It is played in the wrong aspect ratio but at least it plays. :)
This file is delivered in native format, so nothing to do for aspect ratio. For this particular file, you can select the 2010 Bravia profile on serviio concole (then this file will be transcoded)
bla99ard wrote:Here is the ffmpeg output of a file that won't play.
That could be due to a bad avi container format, or something on video/audio track that your device does not support.
You can also try with 2010 Bravia profile selected.
bla99ard
Post Sat Nov 16, 2013 9:09 am
Neither file will play using the 2010 Bravia profile selected.
I definitely have transcoding enabled.
Thanks anyway.
