Sony KDL46HX820
tidusmomo
Post Fri Nov 15, 2013 9:01 pm
Re: Sony KDL46HX820
hello,
I just did a test, I installed on my pc a wifi usb key
is working well is fix the IP address, I do not understand anything.
or may come to the problem?
Post Sat Nov 16, 2013 8:55 am
Re: Sony KDL46HX820
I'm lost too...something with your network setting. Sorry.
Is there some other users here with freebox v6 on Windows 7 OS ?
tidusmomo
Post Sat Nov 16, 2013 10:25 am
Re: Sony KDL46HX820
hello Illico,
thank you clean your quick response and your help.
I just did a test on another PC with the same OS Windows 7 Profressionnel connect RJ45 cable in, no problem works great.
I think he must have problem with my network card :
- "qualcomm Atheros ar8151 PCI Gigabit Ethernet Controller (NDIS 6.20)"
tidusmomo
Post Mon Nov 18, 2013 9:43 am
Re: Sony KDL46HX820
Hellp!!!!
tidusmomo
Post Thu Nov 21, 2013 8:04 pm
Re: Sony KDL46HX820
hellp
Post Fri Nov 22, 2013 8:18 am
Re: Sony KDL46HX820
Try to disable IPV6 support on you freebox rooter.
tidusmomo
Post Fri Nov 22, 2013 10:03 am
Re: Sony KDL46HX820
Hello ILLICO
Thank you for your answer, I have a feeling you're the only one you concerned about my problem.
I will confirm that IPv6 is disabled on the Freebox.
thank you for your help.
Previous
