Cannot connect to Serviio server, it does not seem to be run
Angelikfear
Post Fri Nov 01, 2013 3:38 pm
Re: Cannot connect to Serviio server, it does not seem to be
I cant restart the service. it only offers me to start. And when I click on start..... it says it cant. Sorry I cant generate the logs.
Angelikfear
Post Sat Nov 02, 2013 3:05 am
anything else????? i paid for a broken product.
crackedtooth
Post Sun Nov 03, 2013 12:28 pm
Seems EVERY update gives hassle and issues....
Synology update to 1.3.1.. leaves me with NO libray saved... AND normal login from windows pc not working
just peaches.... (again)
Post Mon Nov 04, 2013 2:23 am
Angelikfear wrote:I cant restart the service. it only offers me to start. And when I click on start..... it says it cant. Sorry I cant generate the logs.
You still can - turn on detailed logging (click on this link for how to) and then attempt to restart the Serviio service. After it fails, post the generated log back to the forum - this should assist with diagnosing the issue.
Post Mon Nov 04, 2013 8:08 pm
crackedtooth wrote:Seems EVERY update gives hassle and issues....
That is probably due to the Web UI being out of date / incompatible with 1.3.1. Also 1.3.1 is re-adding your whole library (due to database schema changes / new features), so it might take some time for it to appear
BeNxTwIsTeD
Post Sat Nov 16, 2013 5:46 pm
I'm running Serviio 1.3.1, and had this same error after making some manual changes to Profiles.xml
Java is version 7 update 15
Checking the log shows:
2013-11-16 11:30:17,432 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
Shortly after:
2013-11-16 11:30:39,205 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
Seems to be a general connection error thrown when Serviio engages with Java and cannot connect to the server.
Starting/Restarting the Serviio Service had no effect resulting in the same error.
I removed the changes made and saved the Profiles.xml. I then restarted Serviio services and launched ServiioConsole.exe, and I still received the same error.
I then re-installed Serviio 1.3.1 (did not uninstall first) and was able to launch Serviio and connect to the server from my devices after the reboot.
This allowed me to keep all of my original settings.
My issue was pretty obvious but wanted to post my experience with this error.
Hopefully it helps!
Golimer
Post Sun Dec 01, 2013 8:46 am
2013-12-01 10:45:23,014 INFO [ServiioConsole] Initializing Serviio Console
2013-12-01 10:45:23,025 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-12-01 10:45:23,027 INFO [ServiioConsole] Starting Serviio Console
2013-12-01 10:45:23,056 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-12-01 10:45:23,084 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-12-01 10:45:23,084 DEBUG [ServiioConsole] Checking if server is running
2013-12-01 10:45:33,217 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2013-12-01 10:45:33,218 DEBUG [ServiioConsole] Retrieving console settings
2013-12-01 10:45:43,236 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2013-12-01 10:45:43,244 INFO [Messages] Loaded console message bundle for locale: en
2013-12-01 10:45:51,037 INFO [ServiioConsole] Exitting Serviio Console
P.S. Service starting ok, even i can watch movies, but then i trying to start serviio console showing this error
Win 7 64bit
Java 7
what is the problem?
THANKS IN ADVANCE
Post Mon Dec 02, 2013 9:07 pm
Do you have the server running on the same PC? Is localhost in your hosts file?
Golimer
Post Tue Dec 03, 2013 5:38 pm
Yes same PC
I have reinstall ant now only on startip PC this error. After closing error and startig serviio console working good
Post Thu Dec 05, 2013 8:15 pm
ok, it looks like the console start too early, before the server has a chance to start. You can remove the console from the Start menu's Startup folder and start it manually whenever you need it (it's not needed for the actual streaming, only for setting up Serviio)
Movie Chef
Post Mon Jan 20, 2014 9:12 pm
4 days now I have been unable to start Serviio 1.4 Has worked well up until then. There was a Java upgrade to 7.51. after having problems I went back 7.45 7.25 nothing helped.
I did try removing java, removing Serviio and every combination of the 2, with different versions of both.
I have never looked at or shared log files before. Mine seems to be longer than others I have seen on here. I am running win 7/64 everything is on one computer
Again sorry if this is too much log file...open to guidance and corrections
2014-01-18 12:19:33,957 INFO [ServiioConsole] Initializing Serviio Console
2014-01-18 12:19:34,035 ERROR [ApplicationInstanceManager] Error connecting to local port for single instance notification
2014-01-18 12:19:34,066 ERROR [ApplicationInstanceManager] Error connecting to local port for single instance notification
2014-01-18 12:19:34,051 ERROR [ApplicationInstanceManager] Unrecognized Windows Sockets error: 87: create
java.net.SocketException: Unrecognized Windows Sockets error: 87: create
at java.net.Socket.createImpl(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at org.serviio.ApplicationInstanceManager.registerInstance(ApplicationInstanceManager.java:105)
at org.serviio.MediaServer.checkForRunningInstances(MediaServer.java:283)
at org.serviio.MediaServer.main(MediaServer.java:106)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
2014-01-18 12:19:34,066 ERROR [ApplicationInstanceManager] Unrecognized Windows Sockets error: 87: create
at org.serviio.console.ApplicationInstanceManager.registerInstance(ApplicationInstanceManager.java:122)
at org.serviio.console.ServiioConsole.checkForRunningInstances(ServiioConsole.java:226)
at org.serviio.console.ServiioConsole.main(ServiioConsole.java:90)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2014-01-18 12:19:34,097 INFO [ServiioConsole] Starting Serviio Console
2014-01-18 12:19:34,113 INFO [MediaServer] ------------------------------------------------------------------------
2014-01-18 12:19:34,113 INFO [MediaServer] Serviio DLNA media streaming server v 1.4 (rev. c307c4dd528d)
2014-01-18 12:19:34,113 INFO [MediaServer] Petr Nejedly 2009-2013
2014-01-18 12:19:34,113 INFO [MediaServer] http://www.serviio.org
2014-01-18 12:19:34,113 INFO [MediaServer] Java 1.7.0_51-Oracle Corporation
2014-01-18 12:19:34,113 INFO [MediaServer] OS Windows 7 amd64 6.1
2014-01-18 12:19:34,113 INFO [MediaServer] File encoding: windows-1252
2014-01-18 12:19:34,113 INFO [MediaServer] Headless mode enabled: true
2014-01-18 12:19:34,113 INFO [MediaServer] User: THE_OFFICE_ZT$
2014-01-18 12:19:34,113 INFO [MediaServer] User home dir: C:\
2014-01-18 12:19:34,113 INFO [MediaServer] Temp dir: C:\windows\TEMP\
2014-01-18 12:19:36,047 INFO [WebServer] Socket buffer set to 65535 bytes
2014-01-18 12:19:36,079 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-01-18 12:19:36,157 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: java.net.SocketException: Unrecognized Windows Sockets error: 87: create
java.lang.RuntimeException: java.net.SocketException: Unrecognized Windows Sockets error: 87: create
at org.serviio.restlet.RestletServer.runServer(RestletServer.java:84)
at org.serviio.MediaServer.main(MediaServer.java:113)
Caused by: java.net.SocketException: Unrecognized Windows Sockets error: 87: create
at java.net.ServerSocket.createImpl(Unknown Source)
at java.net.ServerSocket.getImpl(Unknown Source)
at java.net.ServerSocket.setReuseAddress(Unknown Source)
at org.restlet.engine.http.connector.BaseServerHelper.createServerSocket(BaseServerHelper.java:117)
at org.restlet.engine.http.connector.BaseServerHelper.start(BaseServerHelper.java:251)
at org.restlet.engine.http.connector.HttpServerHelper.start(HttpServerHelper.java:69)
at org.restlet.Server.start(Server.java:585)
at org.restlet.Component.startServers(Component.java:601)
at org.restlet.Component.start(Component.java:528)
at org.serviio.restlet.RestletServer.runServer(RestletServer.java:73)
Movie Chef
Post Fri Jan 24, 2014 12:47 am
Still no connection or solution on the above problem... :(
Post Fri Jan 24, 2014 3:51 pm
Not sure, apart from reinstalling Java - which you have done. Maybe Windows update too?
bsod
Post Mon Jul 28, 2014 6:24 pm
I have the exact same problem, could it be to do with the console trying to start before the server? How can I fix?
Here's my log:
2014-07-28 18:02:16,139 INFO  [MediaServer] ------------------------------------------------------------------------
2014-07-28 18:02:16,141 INFO  [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f)
2014-07-28 18:02:16,141 INFO  [MediaServer] Petr Nejedly 2009-2014
2014-07-28 18:02:16,141 INFO  [MediaServer] http://www.serviio.org
2014-07-28 18:02:16,141 INFO  [MediaServer] Java 1.7.0_05-Oracle Corporation
2014-07-28 18:02:16,141 INFO  [MediaServer] OS Windows NT (unknown) amd64 6.2
2014-07-28 18:02:16,141 INFO  [MediaServer] File encoding: windows-1252
2014-07-28 18:02:16,143 INFO  [MediaServer] Headless mode enabled: true
2014-07-28 18:02:16,143 INFO  [MediaServer] User: DESKTOPBEAST$
2014-07-28 18:02:16,143 INFO  [MediaServer] User home dir: C:\
2014-07-28 18:02:16,143 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2014-07-28 18:02:16,143 INFO  [MediaServer] ------------------------------------------------------------------------
2014-07-28 18:02:16,332 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-07-28 18:02:16,334 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-07-28 18:02:16,410 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-07-28 18:02:16,410 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-07-28 18:02:16,432 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-07-28 18:02:16,444 INFO  [DatabaseManager] Using DERBY database language
2014-07-28 18:02:18,911 INFO  [MediaServer] ------------------------------------------------------------------------
2014-07-28 18:02:18,911 INFO  [MediaServer] License: FREE
2014-07-28 18:02:19,143 INFO  [Device] Created UPnP Device with UUID: 2274a5bf-ce63-3ec5-bef9-aa09883fff29, bound address: 192.168.1.67
2014-07-28 18:02:19,945 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-07-28 18:02:20,081 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2014-07-28 18:02:20,103 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2014-07-28 18:02:20,109 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2014-07-28 18:02:20,111 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2014-07-28 18:02:20,111 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2014-07-28 18:02:20,115 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2014-07-28 18:02:20,119 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2014-07-28 18:02:20,121 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2014-07-28 18:02:20,121 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2014-07-28 18:02:20,125 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2014-07-28 18:02:20,129 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2014-07-28 18:02:20,129 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2014-07-28 18:02:20,131 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2014-07-28 18:02:20,135 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2014-07-28 18:02:20,135 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2014-07-28 18:02:20,137 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2014-07-28 18:02:20,137 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2014-07-28 18:02:20,139 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2014-07-28 18:02:20,141 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2014-07-28 18:02:20,141 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2014-07-28 18:02:20,143 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2014-07-28 18:02:20,143 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2014-07-28 18:02:20,145 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2014-07-28 18:02:20,145 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2014-07-28 18:02:20,147 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2014-07-28 18:02:20,147 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2014-07-28 18:02:20,149 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2014-07-28 18:02:20,149 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2014-07-28 18:02:20,151 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2014-07-28 18:02:20,151 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2014-07-28 18:02:20,153 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2014-07-28 18:02:20,153 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2014-07-28 18:02:20,153 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2014-07-28 18:02:20,155 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2014-07-28 18:02:20,155 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2014-07-28 18:02:20,157 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2014-07-28 18:02:20,157 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2014-07-28 18:02:20,157 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2014-07-28 18:02:20,159 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2014-07-28 18:02:20,161 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2014-07-28 18:02:20,161 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2014-07-28 18:02:20,163 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2014-07-28 18:02:20,163 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2014-07-28 18:02:20,165 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2014-07-28 18:02:20,165 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2014-07-28 18:02:20,167 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2014-07-28 18:02:20,499 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-07-28 18:02:20,503 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2014-07-28 18:02:20,507 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2014-07-28 18:02:20,509 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2014-07-28 18:02:20,509 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2014-07-28 18:02:20,511 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2014-07-28 18:02:20,519 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2014-07-28 18:02:20,521 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2014-07-28 18:02:20,523 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2014-07-28 18:02:21,841 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2014-07-28 18:02:21,861 INFO  [UpdateChecker] Checking if a new version is available
2014-07-28 18:02:23,323 INFO  [PluginCompilerThread] Started looking for plugins
2014-07-28 18:02:23,553 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2014-07-28 18:02:23,595 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-07-28 18:02:23,631 INFO  [WebServer] WebServer starting on port 8895
2014-07-28 18:02:23,713 INFO  [Device] Updated bound IP address of Device with UUID: 2274a5bf-ce63-3ec5-bef9-aa09883fff29, bound address: 192.168.1.67
2014-07-28 18:02:23,717 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-07-28 18:02:23,717 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-07-28 18:02:23,717 INFO  [EventDispatcher] Starting EventDispatcher
2014-07-28 18:02:23,722 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2014-07-28 18:02:23,751 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net6 (Qualcomm Atheros AR7015 Wireless Network Adapter) and address 192.168.1.67, timeout = 0
2014-07-28 18:02:23,751 INFO  [RendererSearchSender] Searching for Renderer devices
2014-07-28 18:02:34,435 INFO  [ServiioConsole] Initializing Serviio Console
2014-07-28 18:02:34,466 INFO  [ServiioConsole] Starting Serviio Console
2014-07-28 18:02:34,630 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-07-28 18:02:35,261 INFO  [Messages] Loaded console message bundle for locale: en
2014-07-28 18:02:37,953 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2014-07-28 18:02:47,622 WARN  [PresentationView] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2014-07-28 18:04:32,711 INFO  [ServiioConsole] Exitting Serviio Console
2014-07-28 18:05:22,738 INFO  [ServiioConsole] Initializing Serviio Console
2014-07-28 18:05:22,750 INFO  [ServiioConsole] Starting Serviio Console
2014-07-28 18:05:22,822 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-07-28 18:05:32,990 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2014-07-28 18:05:43,016 WARN  [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2014-07-28 18:05:43,021 INFO  [Messages] Loaded console message bundle for locale: en
2014-07-28 18:07:31,863 INFO  [MediaServer] ------------------------------------------------------------------------
2014-07-28 18:07:31,863 INFO  [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f)
2014-07-28 18:07:31,863 INFO  [MediaServer] Petr Nejedly 2009-2014
2014-07-28 18:07:31,863 INFO  [MediaServer] http://www.serviio.org
2014-07-28 18:07:31,863 INFO  [MediaServer] Java 1.7.0_05-Oracle Corporation
2014-07-28 18:07:31,863 INFO  [MediaServer] OS Windows NT (unknown) amd64 6.2
2014-07-28 18:07:31,863 INFO  [MediaServer] File encoding: windows-1252
2014-07-28 18:07:31,864 INFO  [MediaServer] Headless mode enabled: true
2014-07-28 18:07:31,864 INFO  [MediaServer] User: DESKTOPBEAST$
2014-07-28 18:07:31,864 INFO  [MediaServer] User home dir: C:\
2014-07-28 18:07:31,864 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2014-07-28 18:07:31,864 INFO  [MediaServer] ------------------------------------------------------------------------
2014-07-28 18:07:31,967 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-07-28 18:07:31,968 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-07-28 18:07:32,003 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-07-28 18:07:32,004 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-07-28 18:07:32,017 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-07-28 18:07:32,029 INFO  [DatabaseManager] Using DERBY database language
2014-07-28 18:07:32,740 INFO  [MediaServer] ------------------------------------------------------------------------
2014-07-28 18:07:32,740 INFO  [MediaServer] License: FREE
2014-07-28 18:07:32,825 INFO  [Device] Created UPnP Device with UUID: 2274a5bf-ce63-3ec5-bef9-aa09883fff29, bound address: 192.168.1.67
2014-07-28 18:07:33,193 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-07-28 18:07:33,279 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2014-07-28 18:07:33,290 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2014-07-28 18:07:33,293 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2014-07-28 18:07:33,295 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2014-07-28 18:07:33,296 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2014-07-28 18:07:33,298 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2014-07-28 18:07:33,301 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2014-07-28 18:07:33,302 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2014-07-28 18:07:33,303 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2014-07-28 18:07:33,307 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2014-07-28 18:07:33,309 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2014-07-28 18:07:33,311 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2014-07-28 18:07:33,312 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2014-07-28 18:07:33,315 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2014-07-28 18:07:33,315 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2014-07-28 18:07:33,316 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2014-07-28 18:07:33,317 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2014-07-28 18:07:33,318 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2014-07-28 18:07:33,320 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2014-07-28 18:07:33,321 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2014-07-28 18:07:33,321 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2014-07-28 18:07:33,322 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2014-07-28 18:07:33,323 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2014-07-28 18:07:33,324 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2014-07-28 18:07:33,325 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2014-07-28 18:07:33,326 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2014-07-28 18:07:33,326 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2014-07-28 18:07:33,327 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2014-07-28 18:07:33,329 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2014-07-28 18:07:33,330 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2014-07-28 18:07:33,331 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2014-07-28 18:07:33,332 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2014-07-28 18:07:33,332 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2014-07-28 18:07:33,333 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2014-07-28 18:07:33,334 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2014-07-28 18:07:33,335 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2014-07-28 18:07:33,335 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2014-07-28 18:07:33,336 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2014-07-28 18:07:33,338 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2014-07-28 18:07:33,339 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2014-07-28 18:07:33,340 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2014-07-28 18:07:33,341 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2014-07-28 18:07:33,342 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2014-07-28 18:07:33,343 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2014-07-28 18:07:33,344 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2014-07-28 18:07:33,344 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2014-07-28 18:07:33,397 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-07-28 18:07:33,398 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2014-07-28 18:07:33,399 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2014-07-28 18:07:33,400 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2014-07-28 18:07:33,401 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2014-07-28 18:07:33,402 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2014-07-28 18:07:33,403 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2014-07-28 18:07:33,405 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2014-07-28 18:07:33,406 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2014-07-28 18:07:33,442 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2014-07-28 18:07:33,442 INFO  [PluginCompilerThread] Started looking for plugins
2014-07-28 18:07:33,443 INFO  [UpdateChecker] Checking if a new version is available
2014-07-28 18:07:33,482 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2014-07-28 18:07:33,507 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-07-28 18:07:33,531 INFO  [WebServer] WebServer starting on port 8895
2014-07-28 18:07:33,615 INFO  [Device] Updated bound IP address of Device with UUID: 2274a5bf-ce63-3ec5-bef9-aa09883fff29, bound address: 192.168.1.67
2014-07-28 18:07:33,619 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-07-28 18:07:33,620 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-07-28 18:07:33,621 INFO  [EventDispatcher] Starting EventDispatcher
2014-07-28 18:07:33,623 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2014-07-28 18:07:33,656 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net6 (Qualcomm Atheros AR7015 Wireless Network Adapter) and address 192.168.1.67, timeout = 0
2014-07-28 18:07:33,658 INFO  [RendererSearchSender] Searching for Renderer devices
2014-07-28 18:07:39,071 INFO  [ServiioConsole] Initializing Serviio Console
2014-07-28 18:07:39,094 INFO  [ServiioConsole] Exitting Serviio Console
2014-07-28 18:07:59,678 INFO  [FeedUpdaterThread] Started looking for information about online resources
2014-07-28 18:07:59,686 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-07-28 18:07:59,690 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-07-28 18:07:59,690 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-07-28 18:08:14,200 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Formula.1.2014.Hungarian.Grand.Prix.Drivers.Press.Conference.PDTV.x264-W4F.mp4 [VideoDescription [type=FILM, names=[formula 1, null], year=2014, season=null, episode=null]]
2014-07-28 18:08:14,712 INFO  [SearchManager] Starting up search engine
2014-07-28 18:08:15,016 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2014-07-28 18:08:15,033 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2014-07-28 18:08:16,506 INFO  [LibraryAdditionsCheckerThread] Added file 'Formula.1.2014.Hungarian.Grand.Prix.Drivers.Press.Conference.PDTV.x264-W4F.mp4' (title: Formula.1.2014.Hungarian.Grand.Prix.Drivers.Press.Conference.PDTV.x264-W4F) to Library
2014-07-28 18:08:16,523 INFO  [LibraryUpdatesCheckerThread] Updated 'Burn in Hell' (D:\Music\Twisted Sister\Stay Hungry\Burn in Hell - 3.mp3) in Library
2014-07-28 18:08:16,582 INFO  [LibraryUpdatesCheckerThread] Updated 'Don't Let Me Down' (D:\Music\Twisted Sister\Stay Hungry\Don't Let Me Down - 7.mp3) in Library
2014-07-28 18:08:16,644 INFO  [LibraryUpdatesCheckerThread] Updated 'Horror-Teria A) Captain Howdy B) Street Justice' (D:\Music\Twisted Sister\Stay Hungry\Horror-Teria A) Captain Howdy B) Street Justice - 4.mp3) in Library
2014-07-28 18:08:16,708 INFO  [LibraryUpdatesCheckerThread] Updated 'I Wanna Rock' (D:\Music\Twisted Sister\Stay Hungry\I Wanna Rock - 5.mp3) in Library
2014-07-28 18:08:16,803 INFO  [LibraryUpdatesCheckerThread] Updated 'S.M.F.' (D:\Music\Twisted Sister\Stay Hungry\S.M.F. - 9.mp3) in Library
2014-07-28 18:08:16,895 INFO  [LibraryUpdatesCheckerThread] Updated 'Stay Hungry' (D:\Music\Twisted Sister\Stay Hungry\Stay Hungry - 1.mp3) in Library
2014-07-28 18:08:17,003 INFO  [LibraryUpdatesCheckerThread] Updated 'The Beast' (D:\Music\Twisted Sister\Stay Hungry\The Beast - 8.mp3) in Library
2014-07-28 18:08:17,138 INFO  [LibraryUpdatesCheckerThread] Updated 'The Price' (D:\Music\Twisted Sister\Stay Hungry\The Price - 6.mp3) in Library
2014-07-28 18:08:17,176 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Formula.1.2014.Hungarian.Grand.Prix.Practice.One.PDTV.x264-W4F.mp4 [VideoDescription [type=FILM, names=[formula 1, null], year=2014, season=null, episode=null]]
2014-07-28 18:08:17,195 INFO  [LibraryUpdatesCheckerThread] Updated 'We're Not Gonna Take It' (D:\Music\Twisted Sister\Stay Hungry\We're Not Gonna Take It - 2.mp3) in Library
2014-07-28 18:08:17,228 INFO  [LibraryAdditionsCheckerThread] Added file 'Formula.1.2014.Hungarian.Grand.Prix.Practice.One.PDTV.x264-W4F.mp4' (title: Formula.1.2014.Hungarian.Grand.Prix.Practice.One.PDTV.x264-W4F) to Library
2014-07-28 18:08:18,189 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Formula.1.2014.Hungarian.Grand.Prix.Practice.Three.PDTV.x264-W4F.mp4 [VideoDescription [type=FILM, names=[formula 1, null], year=2014, season=null, episode=null]]
2014-07-28 18:08:18,245 INFO  [LibraryAdditionsCheckerThread] Added file 'Formula.1.2014.Hungarian.Grand.Prix.Practice.Three.PDTV.x264-W4F.mp4' (title: Formula.1.2014.Hungarian.Grand.Prix.Practice.Three.PDTV.x264-W4F) to Library
2014-07-28 18:08:18,957 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Formula.1.2014.Hungarian.Grand.Prix.Practice.Two.PDTV.x264-W4F.mp4 [VideoDescription [type=FILM, names=[formula 1, null], year=2014, season=null, episode=null]]
2014-07-28 18:08:19,041 INFO  [LibraryAdditionsCheckerThread] Added file 'Formula.1.2014.Hungarian.Grand.Prix.Practice.Two.PDTV.x264-W4F.mp4' (title: Formula.1.2014.Hungarian.Grand.Prix.Practice.Two.PDTV.x264-W4F) to Library
2014-07-28 18:08:19,587 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Formula.1.2014.Hungarian.Grand.Prix.Team.Principals.Press.Conference.PDTV.x264-W4F.mp4 [VideoDescription [type=FILM, names=[formula 1, null], year=2014, season=null, episode=null]]
2014-07-28 18:08:19,656 INFO  [LibraryAdditionsCheckerThread] Added file 'Formula.1.2014.Hungarian.Grand.Prix.Team.Principals.Press.Conference.PDTV.x264-W4F.mp4' (title: Formula.1.2014.Hungarian.Grand.Prix.Team.Principals.Press.Conference.PDTV.x264-W4F) to Library
2014-07-28 18:08:19,760 WARN  [LibraryManager] Cannot read metadata of file E:\Movies\Brazil (1985)[DVDRip][big_dad_e™]\Brazil (1985)[DVDRip][big_dad_e™].avi via extractor COVER_IMAGE_IN_FOLDER. Message: Could not read block (block start: 302, block length: -14, data length: 288).
2014-07-28 18:08:19,879 INFO  [LibraryUpdatesCheckerThread] Updated 'Brazil' (E:\Movies\Brazil (1985)[DVDRip][big_dad_e™]\Brazil (1985)[DVDRip][big_dad_e™].avi) in Library
2014-07-28 18:08:20,010 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Formula.1.2014.Hungarian.Grand.Prix.The.F1.Show.PDTV.x264-W4F.mp4 [VideoDescription [type=FILM, names=[formula 1, null], year=2014, season=null, episode=null]]
2014-07-28 18:08:20,059 INFO  [LibraryAdditionsCheckerThread] Added file 'Formula.1.2014.Hungarian.Grand.Prix.The.F1.Show.PDTV.x264-W4F.mp4' (title: Formula.1.2014.Hungarian.Grand.Prix.The.F1.Show.PDTV.x264-W4F) to Library
2014-07-28 18:08:20,705 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file 01.Pre-Qualifying.Buildup.720p.mp4 [VideoDescription [type=FILM, names=[01 pre qualifying buildup, formula 1 2014x11 hungary qualifying skyf1], year=null, season=null, episode=null]]
2014-07-28 18:08:20,781 INFO  [LibraryAdditionsCheckerThread] Added file '01.Pre-Qualifying.Buildup.720p.mp4' (title: 01.Pre-Qualifying.Buildup.720p) to Library
2014-07-28 18:08:21,965 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file 02.Qualifying.Session.720p.mp4 [VideoDescription [type=FILM, names=[02 qualifying session, formula 1 2014x11 hungary qualifying skyf1], year=null, season=null, episode=null]]
2014-07-28 18:08:22,021 INFO  [LibraryAdditionsCheckerThread] Added file '02.Qualifying.Session.720p.mp4' (title: 02.Qualifying.Session.720p) to Library
2014-07-28 18:08:22,856 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file 03.Post-Qualifying.Analasys.720p.mp4 [VideoDescription [type=FILM, names=[03 post qualifying analasys, formula 1 2014x11 hungary qualifying skyf1], year=null, season=null, episode=null]]
2014-07-28 18:08:22,912 INFO  [LibraryAdditionsCheckerThread] Added file '03.Post-Qualifying.Analasys.720p.mp4' (title: 03.Post-Qualifying.Analasys.720p) to Library
2014-07-28 18:17:10,218 INFO  [ServiioConsole] Initializing Serviio Console
2014-07-28 18:17:10,252 INFO  [ServiioConsole] Exitting Serviio Console
2014-07-28 18:29:36,208 INFO  [ServiioConsole] Initializing Serviio Console
2014-07-28 18:29:36,237 INFO  [ServiioConsole] Exitting Serviio Console
2014-07-28 18:47:26,359 INFO  [ServiioConsole] Initializing Serviio Console
2014-07-28 18:47:26,392 INFO  [ServiioConsole] Exitting Serviio Console
2014-07-28 18:47:35,559 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2014-07-28 18:47:35,559 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2014-07-28 18:47:35,560 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2014-07-28 18:47:35,561 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-07-28 18:47:35,661 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-07-28 18:47:35,759 INFO  [FeedUpdaterThread] Finished looking for online resources information
2014-07-28 18:47:35,860 INFO  [PluginCompilerThread] Finished looking for plugins
2014-07-28 18:47:35,971 INFO  [SearchIndexer] Closing search index writer
2014-07-28 18:47:35,974 INFO  [SearchIndexer] Closing search index writer
2014-07-28 18:47:35,974 INFO  [WebServer] WebServer shutting down
2014-07-28 18:47:35,974 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2014-07-28 18:47:35,974 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2014-07-28 18:47:35,975 INFO  [EventDispatcher] Leaving EventDispatcher
2014-07-28 18:47:35,975 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2014-07-28 18:47:36,004 INFO  [DatabaseManager] Shutting down database
2014-07-28 18:47:36,319 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-07-28 18:47:38,868 INFO  [MediaServer] ------------------------------------------------------------------------
2014-07-28 18:47:38,869 INFO  [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f)
2014-07-28 18:47:38,869 INFO  [MediaServer] Petr Nejedly 2009-2014
2014-07-28 18:47:38,869 INFO  [MediaServer] http://www.serviio.org
2014-07-28 18:47:38,869 INFO  [MediaServer] Java 1.7.0_05-Oracle Corporation
2014-07-28 18:47:38,870 INFO  [MediaServer] OS Windows NT (unknown) amd64 6.2
2014-07-28 18:47:38,870 INFO  [MediaServer] File encoding: windows-1252
2014-07-28 18:47:38,871 INFO  [MediaServer] Headless mode enabled: true
2014-07-28 18:47:38,871 INFO  [MediaServer] User: DESKTOPBEAST$
2014-07-28 18:47:38,871 INFO  [MediaServer] User home dir: C:\
2014-07-28 18:47:38,871 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2014-07-28 18:47:38,871 INFO  [MediaServer] ------------------------------------------------------------------------
2014-07-28 18:47:39,062 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-07-28 18:47:39,064 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-07-28 18:47:39,134 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-07-28 18:47:39,135 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-07-28 18:47:39,151 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-07-28 18:47:39,167 INFO  [DatabaseManager] Using DERBY database language
2014-07-28 18:47:40,351 INFO  [MediaServer] ------------------------------------------------------------------------
2014-07-28 18:47:40,351 INFO  [MediaServer] License: FREE
2014-07-28 18:47:40,482 INFO  [Device] Created UPnP Device with UUID: 2274a5bf-ce63-3ec5-bef9-aa09883fff29, bound address: 192.168.1.67
2014-07-28 18:47:41,170 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-07-28 18:47:41,316 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2014-07-28 18:47:41,342 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2014-07-28 18:47:41,349 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2014-07-28 18:47:41,352 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2014-07-28 18:47:41,355 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2014-07-28 18:47:41,359 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2014-07-28 18:47:41,362 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2014-07-28 18:47:41,363 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2014-07-28 18:47:41,364 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2014-07-28 18:47:41,369 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2014-07-28 18:47:41,372 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2014-07-28 18:47:41,373 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2014-07-28 18:47:41,375 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2014-07-28 18:47:41,379 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2014-07-28 18:47:41,380 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2014-07-28 18:47:41,381 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2014-07-28 18:47:41,382 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2014-07-28 18:47:41,384 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2014-07-28 18:47:41,387 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2014-07-28 18:47:41,388 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2014-07-28 18:47:41,388 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2014-07-28 18:47:41,389 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2014-07-28 18:47:41,390 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2014-07-28 18:47:41,390 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2014-07-28 18:47:41,391 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2014-07-28 18:47:41,392 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2014-07-28 18:47:41,394 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2014-07-28 18:47:41,394 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2014-07-28 18:47:41,395 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2014-07-28 18:47:41,396 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2014-07-28 18:47:41,397 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2014-07-28 18:47:41,400 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2014-07-28 18:47:41,400 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2014-07-28 18:47:41,402 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2014-07-28 18:47:41,403 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2014-07-28 18:47:41,404 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2014-07-28 18:47:41,405 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2014-07-28 18:47:41,408 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2014-07-28 18:47:41,410 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2014-07-28 18:47:41,411 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2014-07-28 18:47:41,412 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2014-07-28 18:47:41,413 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2014-07-28 18:47:41,416 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2014-07-28 18:47:41,418 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2014-07-28 18:47:41,419 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2014-07-28 18:47:41,420 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2014-07-28 18:47:41,536 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-07-28 18:47:41,538 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2014-07-28 18:47:41,542 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2014-07-28 18:47:41,543 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2014-07-28 18:47:41,544 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2014-07-28 18:47:41,545 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2014-07-28 18:47:41,546 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2014-07-28 18:47:41,551 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2014-07-28 18:47:41,554 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2014-07-28 18:47:41,605 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2014-07-28 18:47:41,609 INFO  [UpdateChecker] Checking if a new version is available
2014-07-28 18:47:41,616 INFO  [PluginCompilerThread] Started looking for plugins
2014-07-28 18:47:41,708 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2014-07-28 18:47:41,755 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-07-28 18:47:41,790 INFO  [WebServer] WebServer starting on port 8895
2014-07-28 18:47:41,905 INFO  [Device] Updated bound IP address of Device with UUID: 2274a5bf-ce63-3ec5-bef9-aa09883fff29, bound address: 192.168.1.67
2014-07-28 18:47:41,912 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-07-28 18:47:41,915 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-07-28 18:47:41,916 INFO  [EventDispatcher] Starting EventDispatcher
2014-07-28 18:47:41,923 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2014-07-28 18:47:41,983 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net6 (Qualcomm Atheros AR7015 Wireless Network Adapter) and address 192.168.1.67, timeout = 0
2014-07-28 18:47:41,992 INFO  [RendererSearchSender] Searching for Renderer devices
2014-07-28 18:47:43,849 INFO  [ServiioConsole] Initializing Serviio Console
2014-07-28 18:47:43,881 INFO  [ServiioConsole] Exitting Serviio Console
2014-07-28 18:48:06,466 INFO  [ServiioConsole] Initializing Serviio Console
2014-07-28 18:48:06,488 INFO  [ServiioConsole] Exitting Serviio Console
2014-07-28 18:48:08,026 INFO  [FeedUpdaterThread] Started looking for information about online resources
2014-07-28 18:48:08,030 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-07-28 18:48:08,038 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-07-28 18:48:08,043 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2014-07-28 18:48:19,014 INFO  [SearchManager] Starting up search engine
2014-07-28 18:48:19,401 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2014-07-28 18:48:21,588 INFO  [LibraryUpdatesCheckerThread] Updated 'Burn in Hell' (D:\Music\Twisted Sister\Stay Hungry\Burn in Hell - 3.mp3) in Library
2014-07-28 18:48:21,787 INFO  [LibraryUpdatesCheckerThread] Updated 'Don't Let Me Down' (D:\Music\Twisted Sister\Stay Hungry\Don't Let Me Down - 7.mp3) in Library
2014-07-28 18:48:21,898 INFO  [LibraryUpdatesCheckerThread] Updated 'Horror-Teria A) Captain Howdy B) Street Justice' (D:\Music\Twisted Sister\Stay Hungry\Horror-Teria A) Captain Howdy B) Street Justice - 4.mp3) in Library
2014-07-28 18:48:22,012 INFO  [LibraryUpdatesCheckerThread] Updated 'I Wanna Rock' (D:\Music\Twisted Sister\Stay Hungry\I Wanna Rock - 5.mp3) in Library
2014-07-28 18:48:22,140 INFO  [LibraryUpdatesCheckerThread] Updated 'S.M.F.' (D:\Music\Twisted Sister\Stay Hungry\S.M.F. - 9.mp3) in Library
2014-07-28 18:48:22,275 INFO  [LibraryUpdatesCheckerThread] Updated 'Stay Hungry' (D:\Music\Twisted Sister\Stay Hungry\Stay Hungry - 1.mp3) in Library
2014-07-28 18:48:22,379 INFO  [LibraryUpdatesCheckerThread] Updated 'The Beast' (D:\Music\Twisted Sister\Stay Hungry\The Beast - 8.mp3) in Library
2014-07-28 18:48:22,492 INFO  [LibraryUpdatesCheckerThread] Updated 'The Price' (D:\Music\Twisted Sister\Stay Hungry\The Price - 6.mp3) in Library
2014-07-28 18:48:22,621 INFO  [LibraryUpdatesCheckerThread] Updated 'We're Not Gonna Take It' (D:\Music\Twisted Sister\Stay Hungry\We're Not Gonna Take It - 2.mp3) in Library
2014-07-28 18:48:26,718 WARN  [LibraryManager] Cannot read metadata of file E:\Movies\Brazil (1985)[DVDRip][big_dad_e™]\Brazil (1985)[DVDRip][big_dad_e™].avi via extractor COVER_IMAGE_IN_FOLDER. Message: Could not read block (block start: 302, block length: -14, data length: 288).
2014-07-28 18:48:26,985 INFO  [LibraryUpdatesCheckerThread] Updated 'Brazil' (E:\Movies\Brazil (1985)[DVDRip][big_dad_e™]\Brazil (1985)[DVDRip][big_dad_e™].avi) in Library
2014-07-28 18:51:07,574 INFO  [ServiioConsole] Exitting Serviio Console
2014-07-28 18:51:11,636 INFO  [ServiioConsole] Initializing Serviio Console
2014-07-28 18:51:11,653 INFO  [ServiioConsole] Starting Serviio Console
2014-07-28 18:51:11,800 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-07-28 18:51:12,697 INFO  [Messages] Loaded console message bundle for locale: en
2014-07-28 18:51:15,650 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2014-07-28 18:58:17,845 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file 01.Pre-Race.Buildup.720p.mp4 [VideoDescription [type=FILM, names=[01 pre race buildup, formula 1 2014x11 hungary race skyf1], year=null, season=null, episode=null]]
2014-07-28 18:58:17,974 INFO  [LibraryAdditionsCheckerThread] Added file '01.Pre-Race.Buildup.720p.mp4' (title: 01.Pre-Race.Buildup.720p) to Library
2014-07-28 18:58:19,662 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file 02.Race.Session.720p.mp4 [VideoDescription [type=FILM, names=[02 race session, formula 1 2014x11 hungary race skyf1], year=null, season=null, episode=null]]
2014-07-28 18:58:19,721 INFO  [LibraryAdditionsCheckerThread] Added file '02.Race.Session.720p.mp4' (title: 02.Race.Session.720p) to Library
2014-07-28 18:58:20,589 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file 03.Post-Race.Analysis.720p.mp4 [VideoDescription [type=FILM, names=[03 post race analysis, formula 1 2014x11 hungary race skyf1], year=null, season=null, episode=null]]
2014-07-28 18:58:20,651 INFO  [LibraryAdditionsCheckerThread] Added file '03.Post-Race.Analysis.720p.mp4' (title: 03.Post-Race.Analysis.720p) to Library
Post Wed Jul 30, 2014 9:17 pm
It could be, just remove the console from the Start menu's Startup folder. Then you just start the console when you need it.
bsod
Post Sat Aug 16, 2014 4:43 pm
It was definitely a problem with the console trying to start before the service. I am not sure why this was happening. I didn't have the service set to automatic (delayed).
Anyway I resolved it by using a free piece of software called startup delayer http://www.r2.com.au/page/products/down ... p-delayer/
I wonder why this is happening and if there is an integrated solution for the servio console to start after the server. But I couldn't find anything itself in the start/stop server scripts.
In fact, the start/stop server scripts do nothing for me. Neither does the button in the console. I have to do it in windows' services.msc
bsod
Post Mon Sep 29, 2014 7:06 pm
Thought id update here. I did a fresh install of windows 8.1 since my last visit, installed Java, installed Serviio. Same problem. The application tries to launch before the server has started.
I don't know, but I suspect this may be due to my use of an SSD. Maybe the application is loading up so fast that it doesn't wait for the service first.
Anyway, i wondered if there is any way to change how fast the application launches on boot, rather than just using a method of placing a shortcut in the windows startup folder? A script or something built into the application?
Right now the easiest fix is to run manually, or use startup delayer.
symbi0nt
Post Sun Nov 23, 2014 5:23 pm
Running win7 64bit.
Had this exact problem and did a Google search on this exception:
Which took me to a solution suggesting this DOS command
netsh winsock reset
After running this command and a reboot, my issue was fixed and the serviio server console started.
Hope this helps somebody else :)
qwer
Post Sat Mar 07, 2015 10:19 pm
I have installed Serviio (1.5.1) the first time. But I can also not start the console (manual/automatic). Console is visible in the task manager, but only for this message: "cannot connect to serviio server it does not seem to be running. Exiting..."
System: Win 8.1 / JRE8u40
Log:
2015-03-07 22:59:59,213 INFO [ServiioConsole] Initializing Serviio Console
2015-03-07 22:59:59,323 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2015-03-07 22:59:59,338 INFO [ServiioConsole] Starting Serviio Console
2015-03-07 22:59:59,604 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2015-03-07 22:59:59,698 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-03-07 22:59:59,698 DEBUG [ServiioConsole] Checking if server is running
2015-03-07 23:00:14,682 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2015-03-07 23:00:14,682 DEBUG [ServiioConsole] Retrieving console settings
2015-03-07 23:00:24,761 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - The connector failed to connect to the server
2015-03-07 23:00:24,761 INFO [Messages] Loaded console message bundle for locale: en
2015-03-07 23:03:21,857 INFO [ServiioConsole] Exitting Serviio Console
I have already deinstalled/installed Serviio again. Restarted my PC und deinstalled/installed the newest Java.
Please help. Thanks.
Post Sun Mar 08, 2015 4:37 pm
Looks like your server is not running. Check if the Windows service (Serviio) is installed and is running.
Users browsing this forum: Baidu [Spider] and 59 guests
