Java
Meat Juice
Post Sat Nov 16, 2013 3:25 am
Java
I have Java 7 Update 45 on my computer.
When I install Serviio It asks to install Java 6. After Serviio's installation I have Java 7 Update 5 x64 listed in my programs next to the above mentioned Java installation. My malware and antivirus keep flagging update 5 as a security risk. But if I uninstall update 5 Serviio will not work.
Any thoughts on this? Updates? Suggestions?
Regards,
MJ
Post Sun Nov 17, 2013 11:28 am
Re: Java
Are you on Windows?
Meat Juice
Post Sun Nov 17, 2013 5:27 pm
Re: Java
Oops, Windows 7 x64. Serviio 1.3.1 Pro.
Post Sun Nov 17, 2013 11:43 pm
Re: Java
uninstall all Java and install the latest Java 7 for 64 bits. You should be fine.
Meat Juice
Post Mon Nov 18, 2013 12:02 am
Re: Java
Thank you for the fix. Given I have a 64 bit OS I had to install both x32 and x64 Java otherwise I receive the following message when Serviio launches:
No JVM could be found on your system.
Please define EXE4J_JAVA_HOME
to point to an installed 64-bit JDK or JRE or dowload a JRE from
http://www.java.com.
With both versions of Java I am up to date and Serviio runs well. Thank you for your time.
