96khz / 24-bit audio files
clipdin
Post Sat Oct 27, 2012 12:53 am
I'm sorry if I'm the 10,000th person to ask this question, but my head is starting to hurt trying to find the answer. Can Serviio stream 96khz / 24-bit audio files without downsampling them to a lesser quality? Depending on the answer I'll have many follow-up questions. ;)
Post Sat Oct 27, 2012 12:03 pm
Re: 96khz / 24-bit audio files
Depends on what file type they are and what is your device.
rons1972
Post Wed Nov 20, 2013 12:15 pm
Actually, I don't mind the transcoding to LPCM 1.4.... but I just want to play FLAC 24/96. What should I do to make serviio play 24/96 FLAC albeit with appropriate transcoding for my device profile. I use a Sony Blu Ray player 490. So, I guess that best I can have it LPCM 1.4 Mhz.
Post Wed Nov 20, 2013 6:53 pm
There is already tranbscoding of Flac in the Sony profiles, does that not work? If not, post the error message you get from FFmpeg (if any)
