Can't get transcoding to work at all
joemol
Post Thu Nov 21, 2013 12:12 pm
I have used Serviio without transcoding for a long time and everything has worked fine. I now would like to watch some flv and other files which need to be transcoded. I have enabled transcoding in the console and selected my own transcoding folder and ticked "Best Quality". Nothing I have done has made the thing transcode and I still cant watch flv's.
Here are my details.
Hardware:
i7 930 PC, lots of RAM, lots of HD, 4 cores, no hyperthreading
Samsung BD-C5500 Blue Ray/DVD/CD/DLNA box
Samsung UA40B6000 TV
Software:
Windows 7 Ultimate SP3
Serviio DLNA media streaming server v 1.3.1 (rev. f1fc8bc55657) Pro version. (Paid for it for a "thank you" and also to see if that might make things work better.)
ffdshow 1.3.4500
The console has discovered a "Samsung TV / Player (C/D/E/F-Series)" device with the profile named the same. The profiles are untouched from install.
I have added a small folder of captured videos to the library and they have been correctly cataloged and are visible on my TV, but there is nothing in the transcode folder.
I have attached the log of the session to start, capture video and close Serviio from a clean database.
I have done lots of searches and looked through the documentation and this forum but I still have no idea what I am doing wrong and would very much appreciate if someone could help me and point out the absolutely stupid, dumb things which I am undoubtedly doing.
Thank you all in advance.
Joe M.
Australia
(PS: The Vuze DLNA server has no problems transcoding but I'm not too keen on the result and I like Serviio much better.)
serviio.zip
(31.52 KiB) Downloaded 461 times
Post Mon Nov 25, 2013 10:44 am
Re: Can't get transcoding to work at all
The log doesn't show you trying to play the file. Try it again and post the log again, pls.
Also provide ffmpeg -i of the file you're trying to play.
