No sound with XBox 360
beto
Post Sun Nov 24, 2013 6:50 pm
I have problems with a video file. I can see the video with XBox 360, but I get no sound.
Below you can find the ffmpeg information.
Thank you
beto
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'hs.mp4':
    major_brand     : mp42
    minor_version   : 1
    compatible_brands: isommp42
    creation_time   : 2013-11-22 22:23:33
    copyright       :
    copyright-eng   :
  Duration: 00:35:47.80, start: 0.000000, bitrate: 1530 kb/s
    Stream #0:0(deu): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 852x480 [
SAR 1:1 DAR 71:40], 1404 kb/s, 25 fps, 25 tbr, 1k tbn, 50 tbc
      handler_name    : GPAC ISO Video Handler
    Stream #0:1(deu): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 56
 kb/s
      handler_name    : GPAC ISO Audio Handler
    Stream #0:2(und): Data: none (rtp  / 0x20707472), 60 kb/s
      creation_time   : 2013-11-22 22:25:54
      handler_name    : GPAC ISO Hint Handler
    Stream #0:3(und): Data: none (rtp  / 0x20707472), 4 kb/s
      creation_time   : 2013-11-22 22:25:55
Post Mon Nov 25, 2013 8:23 am
Re: No sound with XBox 360
This file should be transcoded...
Enable detailed logging and check the ffmpeg command line used for transcoding your file.
Post Mon Nov 25, 2013 7:22 pm
I don't think it should be transcoded, it's normal mov/h264/aac 2ch. Probably the XBox just doesn't like the AAC audio track's encoding settings. You might have to reencode the audio in the file.
Users browsing this forum: Google [Bot] and 79 guests
