Buffering lag
Welsh_J_2000
Post Sat Nov 23, 2013 3:59 pm
Buffering lag
Hi Guys,
I am having trouble with a file playing in 3D, it'll play for a while then start lagging, checked my LAN monitor and the LAN connection drops from about 25%-30% down to 4%-5%? Can anyone help with this? Its really annoying!
Im using a Sony BDV-E490
PC setup
AMD 4300 Quad-Core 3.8GHZ
8 GB ram
So shouldn't be any power issues.
Regards
Jazz.
Post Mon Nov 25, 2013 10:46 am
Re: Buffering lag
Is it being transcoded?
Welsh_J_2000
Post Wed Nov 27, 2013 8:02 pm
Re: Buffering lag
Transcoding is on in Serviio Console.
Post Wed Nov 27, 2013 10:56 pm
Re: Buffering lag
yes, but is the file being transcoded? You can find out by enabling detailed log. Or by checking the OS processes, if there is ffmpeg.exe process running while you're watching the movie, then yes.
