Undefined Subtitle Language embedded in mkv files
aoshi22
Post Tue Nov 26, 2013 9:50 am
Hi, I've been trying out many different media server today and I have to say that serviio is so far my favorite.
The only problem I have is that some of the mkv files won't display subtitles because their embedded subtitle track language is undefined. I know in other media servers, I can use the "und" code for undefined subtitle track, but is there anything I can do to enable subtitles in serviio that is undefined, aside from extracting the subtitle and renaming it.
My other problem, though a minor one is that serviio can't seem to read folders with special characters such as [] during scanning
Thanks,
Post Tue Nov 26, 2013 2:18 pm
Re: Undefined Subtitle Language embedded in mkv files
aoshi22 wrote:The only problem I have is that some of the mkv files won't display subtitles because their embedded subtitle track language is undefined. I know in other media servers, I can use the "und" code for undefined subtitle track, but is there anything I can do to enable subtitles in serviio that is undefined, aside from extracting the subtitle and renaming it.
Could you provide information about your mkv file (ffmpeg -i result) ? see signature link
Do you try "und" or "default", on serviio console preferred subtitles language ?
In other case you will have to edit the file to give the subtiles track a language code (mkvmerge).
aoshi22
Post Wed Nov 27, 2013 5:48 am
Here's the ffmpeg Log:
ffmpeg started on 2013-11-26 at 21:42:25
Report written to "ffmpeg-20131126-214225.log"
Command line:
ffmpeg -i "D:\\Anime\\Currently Running\\[Commie] Infinite Stratos 2 - 01 [2B46DB69].mkv" -report
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
Splitting the commandline.
Reading option '-i' ... matched as input file with argument 'D:\Anime\Currently Running\[Commie] Infinite Stratos 2 - 01 [2B46DB69].mkv'.
Reading option '-report' ... matched as option 'report' (generate a report) with argument '1'.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option report (generate a report) with argument 1.
Successfully parsed a group of options.
Parsing a group of options: input file D:\Anime\Currently Running\[Commie] Infinite Stratos 2 - 01 [2B46DB69].mkv.
Opening an input file: D:\Anime\Currently Running\[Commie] Infinite Stratos 2 - 01 [2B46DB69].mkv.
[matroska,webm @ 01885F00] Format matroska,webm probed with size=2048 and score=100
[matroska,webm @ 01885F00] Unknown entry 0x437E
st:0 removing common factor 1000000 from timebase
st:1 removing common factor 1000000 from timebase
st:2 removing common factor 1000000 from timebase
[matroska,webm @ 01885F00] File position before avformat_find_stream_info() is 767162
[h264 @ 0188D780] no picture
[matroska,webm @ 01885F00] All info found
[matroska,webm @ 01885F00] File position after avformat_find_stream_info() is 2190113
Input #0, matroska,webm, from 'D:\Anime\Currently Running\[Commie] Infinite Stratos 2 - 01 [2B46DB69].mkv':
    creation_time   : 2013-10-04 10:15:00
  Duration: 00:24:09.66, start: 0.000000, bitrate: 1870 kb/s
    Chapter #0.0: start 0.000000, end 99.999900
      title           : Intro
    Chapter #0.1: start 99.999900, end 189.789600
      title           : OP
    Chapter #0.2: start 189.789600, end 693.793100
      title           : Part A
    Chapter #0.3: start 693.793100, end 1329.795133
      title           : Part B
    Chapter #0.4: start 1329.795133, end 1419.751667
      title           : ED
    Chapter #0.5: start 1419.751667, end 1449.614833
      title           : Preview
    Stream #0:0(eng), 4, 1/1000: Video: h264 (High 10), yuv420p10le, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(jpn), 8, 1/1000: Audio: aac, 48000 Hz, stereo, fltp (default)
      title           : Commie
    Stream #0:2, 0, 1/1000: Subtitle: ssa (default)
Codec 0x18000 is not in the full list.
    Stream #0:3, 0, 1/90000: Attachment: unknown_codec
      filename        : ARNORG.TTF
      mimetype        : application/x-truetype-font
    Stream #0:4, 0, 1/90000: Attachment: unknown_codec
      filename        : BAARS__.TTF
    Stream #0:5, 0, 1/90000: Attachment: unknown_codec
      filename        : backlash.ttf
    Stream #0:6, 0, 1/90000: Attachment: unknown_codec
      filename        : blue highway linocut.otf
    Stream #0:7, 0, 1/90000: Attachment: unknown_codec
      filename        : bluehigh.ttf
    Stream #0:8, 0, 1/90000: Attachment: unknown_codec
      filename        : Cambo-Regular.otf
    Stream #0:9, 0, 1/90000: Attachment: unknown_codec
      filename        : Comfortaa-Bold.ttf
    Stream #0:10, 0, 1/90000: Attachment: unknown_codec
      filename        : CommieSans-Medium.ttf
    Stream #0:11, 0, 1/90000: Attachment: unknown_codec
      filename        : CommieSans-MediumIt.ttf
    Stream #0:12, 0, 1/90000: Attachment: unknown_codec
      filename        : LT.ttf
    Stream #0:13, 0, 1/90000: Attachment: unknown_codec
      filename        : LT_italic.ttf
    Stream #0:14, 0, 1/90000: Attachment: unknown_codec
      filename        : Swiss_721_Bold_Rounded_BT.ttf
Successfully opened the file.
[AVIOContext @ 00339DA0] Statistics: 2203789 bytes read, 0 seeks
Here's from mediainfo:
Unique ID                                : 20759338949800084717043466987745454891 (0xF9E1A6EA6D38F7028E266A5439A2B2B)
Complete name                            : D:\Anime\Currently Running\[Commie] Infinite Stratos 2 - 01 [2B46DB69].mkv
Format version                           : Version 4 / Version 2
File size                                : 323 MiB
Duration                                 : 24mn 9s
Overall bit rate                         : 1 870 Kbps
Encoded date                             : UTC 2013-10-04 10:15:00
Writing application                      : mkvmerge v6.4.1 ('OSERVRHEint') built on Sep 16 2013 21:54:48
Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
Attachment                               : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Format profile                           : High 10@L5.0
Format settings, ReFrames                : 16 frames
Duration                                 : 24mn 9s
Bit depth                                : 10 bits
Writing library                          : x264 core 129 r2245+729M 1a52e03
Encoding settings                        : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.70 / psy_rd=0.60:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.70 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=3:0.80
Codec ID                                 : A_AAC
Duration                                 : 24mn 9s
Title                                    : Commie
Language                                 : Japanese
Text
Format                                   : ASS
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Compression mode                         : Lossless
Menu
00:00:00.000                             : :Intro
00:01:39.999                             : :OP
00:03:09.789                             : :Part A
00:11:33.793                             : :Part B
00:22:09.795                             : :ED
00:23:39.751                             : :Preview
My option for subtitles are "eng,und", but the problem is the subtitle track language is undefined and serviio doesn't seem to process "und".
Post Wed Nov 27, 2013 5:49 pm
there is missing language for the subtitles track, that's why it's ignored
aoshi22
Post Wed Nov 27, 2013 9:12 pm
zip wrote:there is missing language for the subtitles track, that's why it's ignored
I figure that is the case, is there any hope in the future for serviio to identify these tracks?
Post Wed Nov 27, 2013 10:55 pm
i don't think so. the reason being people would be getting burned in subtitles that they don't want. now they select a language code, so it's reasonable to assume the subtitles is requested (incl transoding), without the code, the subtitles could be in any language and you'd be forced to watch the video transcoded with a foreign subtitles (possibly) without the option to turn it off.
aoshi22
Post Wed Nov 27, 2013 11:27 pm
zip wrote:i don't think so. the reason being people would be getting burned in subtitles that they don't want. now they select a language code, so it's reasonable to assume the subtitles is requested (incl transoding), without the code, the subtitles could be in any language and you'd be forced to watch the video transcoded with a foreign subtitles (possibly) without the option to turn it off.
well I'm not very sure how it works, but is it possible to make serviio scan for defined language subtitles first, and then if and only if it could not find any, serviio could then burn in undefined subtitles. Also, you could include a option for the console to execute this function.
mcgreag
Post Wed Jan 15, 2014 12:18 pm
I have run into this problem as well and it would be very nice to see some support for this.
Editing the file is not an option as that would change the checksum which would break the AniDB identification, and in any case I have 40k+ files, manually going over all of them and changing the subtitles language for all who happens to have undefined subtitle language would be months of work.
I understand that getting burned in unwanted subtitles is a problem but just adding support for "undefined" or similar as a preferred language means that only people that actually put that in the preferred language list and therefore hopefully know what they are doing would run the risk of that happening.
pur_berger
Post Sat Apr 05, 2014 11:46 am
I ran into the same issue (of course) and after some digging i found a tool to get over this:
MKVToolNix
http://www.chip.de/downloads/MKVToolnix_42094730.html
Together with this GUI
https://github.com/BrunoReX/jmkvpropedit/releases
Were you simply loaf teh files - at teh subtitle section you enable Edit and Track 1 (as all of my files contain english subtitles only this is valid for me), set the subtitle to Default Track (whci might not be necessarry) and the Language to "English". The Files are directly processed (not rewritten) so as it's only the Flag set I would assume the Hashfile stays the same and you can do a whole buch at one go ...
Users browsing this forum: Baidu [Spider], Google [Bot] and 22 guests
