Samsung TV not showing images
bkreutz
Post Thu Nov 28, 2013 5:50 pm
Hi guys,
I just set up a Serviio Media server at home, I run it on Win7, the latest version of Serviio.
More or less everything works, except I cannot see images on my Samsung UE46F6750 TV. It states that the folder is empty, altough it should have quite few folders and files in it.
I try diging down to Serviio log file where I can see images added to the library.
But when I open Serviio on my TV, select Images, I see "empty folder" message. At that point this record is inserted on Serviio log file:
2013-11-28 18:41:56,480 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: Cannot get number of IMAGE media items in folder: null
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot get number of IMAGE media items in folder: null
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:154)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:243)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.findContainerItems(ContainerNode.java:183)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.findContainerItems(ContainerNode.java:167)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.retrieveContainerItems(ContainerNode.java:85)
at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.browse(ContentDirectoryEngine.java:102)
at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:152)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:66)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
Caused by: org.serviio.db.dao.PersistenceException: Cannot get number of IMAGE media items in folder: null
at org.serviio.library.dao.FolderDAOImpl.getNumberOfFoldersAndMediaItems(FolderDAOImpl.java:327)
at org.serviio.library.local.service.FolderService.getNumberOfFoldersAndMediaItems(FolderService.java:105)
at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.retrieveItemCount(AbstractListObjectsByFSHierarchyCommand.java:186)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeCountAction(ContainerNode.java:223)
at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveContainerItemsCount(ActionNode.java:166)
at org.serviio.upnp.service.contentdirectory.command.ObjectValuesBuilder.instantiateValuesForContainer(ObjectValuesBuilder.java:145)
at org.serviio.upnp.service.contentdirectory.command.ObjectValuesBuilder.buildObjectValues(ObjectValuesBuilder.java:123)
at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.retrieveList(AbstractListObjectsByFSHierarchyCommand.java:91)
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:148)
... 18 more
(there is more of this, it states more or less the same)
Any ideas?
KR, B
bkreutz
Post Fri Nov 29, 2013 6:46 pm
Re: Samsung TV not showing images
I read somewhere in the forum about detailed loging. I enabled it, restart service and try opening Images once again. As expected it didn't work, but I did triggered an insert into log file... unfortunately nothing new there.
Does anybody have any other idea?
Post Sat Nov 30, 2013 12:34 am
a detailed log preceding this error would help
bkreutz
Post Sat Nov 30, 2013 4:35 pm
This is the part of the log file when in debug mode:
2013-11-29 21:24:40,454 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: Cannot get number of IMAGE media items in folder: null
... 18 more
Caused by: java.sql.SQLException: Scalar subquery is only allowed to return a single row.
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeQuery(Unknown Source)
at org.serviio.library.dao.FolderDAOImpl.getNumberOfFoldersAndMediaItems(FolderDAOImpl.java:317)
... 26 more
... 36 more
Caused by: ERROR 21000: Scalar subquery is only allowed to return a single row.
at org.apache.derby.impl.sql.execute.OnceResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.exe.ac018f0039x0142x9fd7xe84bxffff8366333d11.g0(Unknown Source)
at org.apache.derby.exe.ac018f0039x0142x9fd7xe84bxffff8366333d11.reinit(Unknown Source)
at org.apache.derby.impl.sql.execute.BaseActivation.execute(Unknown Source)
at org.apache.derby.impl.sql.GenericActivationHolder.execute(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
... 30 more
2013-11-29 21:24:40,458 WARN [ContentDirectory] Browse for object id I failed with exception: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot get number of IMAGE media items in folder: null
java.lang.RuntimeException: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot get number of IMAGE media items in folder: null
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:246)
Caused by: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot get number of IMAGE media items in folder: null
... 17 more
... 18 more
... 26 more
... 36 more
... 30 more
Post Mon Dec 02, 2013 9:19 pm
Looks like the DB got corrupted. You'll have to reinstall
bkreutz
Post Fri Dec 06, 2013 3:42 pm
I have reinstalled, set the same settings all over again and now it works. Thanx.
