Serviio Service not Initiating.
Kanguro
Post Thu Nov 28, 2013 3:25 am
Hi guys!
Been using Serviio for about 2 years now.
After the new 1.3.1 update. My Serviio Server doesn't start any longer, even after I manually start its service.
It just shuts itself off. I looked at the log file and the only error i see is a java error plus a disk cache error too.
Here's the log and a lil gif animation of my starting Serviio
and then when it just shuts-off.
Also I've uninstalled serviio and reinstalled it, yet nothing worked.
Thank you!
(26.45 KiB) Downloaded 422 times
Kanguro
Post Fri Nov 29, 2013 4:49 am
Re: Serviio Service not Initiating.
Anyone? :/
Post Fri Nov 29, 2013 8:58 am
From http://stackoverflow.com/questions/2772 ... -bind-java
Address already in use: JVM_Bind
means that some other application is already listening on the port your current application is trying to bind.
what you need to do is, either [change] the port for your current application [not possible for Serviio] or better; just find out the already running application and kill it.
on linux you can find the application pid by using: netstat -tulpn
On Windows I think netstat -anbo will do something similar (from an elevated command prompt). I'm not sure what would be using the same socket as Serviio, but that appears to be the problem.
Kanguro
Post Sat Nov 30, 2013 4:51 am
DenyAll wrote:From http://stackoverflow.com/questions/2772 ... -bind-java
omg freaking thank you!! <3 FOUND IT! Dropbox was the fker. lol. thank you!
Users browsing this forum: No registered users and 54 guests
