cannot see files
maleboog
Post Mon Dec 02, 2013 12:52 pm
cannot see files
My Bravia sees the serviio server ok, and when I go to video and go to folders it shows me the folders, but when I go to the folder, it says there are no files to display. I tried it with the video, audio and pictures...I know I am missing something simple. I do use a media server, and when I set up the location I used my server drive letter (under computer, and I store all my tv shows under the drvie letter M:
Post Mon Dec 02, 2013 11:35 pm
Re: cannot see files
Check the permissions you have on drive M (how to depends on your OS, but you need to ensure that the user that Serviio logs in as has full access to drive M). See http://www.serviio.org/component/conten ... e?id=21#q5. It also recommends that you use a UNC rather than a mapped drive.
