Hide main folder from navigation
bkreutz
Post Mon Dec 02, 2013 5:51 pm
I am using Serviio 1.3.1 on Win7 with Samsung F6750 TV (latest firmware 1114).
For video content I am only sharing one folder called Video. Inside are all video files because this is easy - when you have a new video you just add content to the folder, and Serviio will automatically scan and import changes to library.
On a TV I select Source "Serviio", then "Video content" and then I see all folders in Serviio maching this type - so my folder "Video" - and then content folders.
For occasions where someone is sharing a single folder for one media type it would be useful to skip folder "Video" and go directly to content. Less clicking and less confusion.
I didn't find any such property in the console, nor did I find anything like this written on the forum. Is this included in a standard package or should this be marked as a feature request?
Post Mon Dec 02, 2013 9:28 pm
Re: Hide main folder from navigation
Go to Presentation settings in the console and use the Only show contents option for the required categories.
bkreutz
Post Tue Dec 03, 2013 9:17 pm
Thanks for the answer, but this doesn't work.
If have this issue for example with Audio, and in console in presentation I have Audio and Folders both set to "Display content only" (all other opions like Albums, Artists, ... are set to "Disabled").
On my TV I still have to select source - Serviio, then type - Audio, then main folder - Audio, then I can see subfolders with music files.
The underlined step is not needed.
Post Thu Dec 05, 2013 9:01 pm
This normally works, if you use the Samsung profile. Not sure if it still works on the F series, but didn't get any such a report so far.
