Files and Folders Missing
giveituplouie
Post Sun Dec 01, 2013 4:43 pm
I have a Windows Home Server 2011 running with Stablebit Drive Pool. The only files and folders I'm using in Serviio are on the drive K: "the drive pool drive, which is being shared" This use to work fine and I was able to see all the files on my other computers and 2 Sony SMP-N200. But now we are only seeing 51 of the 750 files.
Here's a sample off 2 outputs - Thor works fine and Red does not:
This one works and is seen.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "K:\thor.mkv"
Input #0, matroska,webm, from 'K:\thor.mkv':
creation_time : 2011-08-25 21:59:34
Duration: 01:54:50.67, start: 0.000000, bitrate: 9528 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x816, SAR 1:1 DAR 40:17,
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (de
fault)
title : english
Stream #0:2(eng): Subtitle: subrip
title : english
This one does not work
C:\Program Files\Serviio\lib>ffmpeg.exe -i "K:\red.mkv" |clip
Input #0, matroska,webm, from 'K:\red.mkv':
creation_time : 2011-01-17 18:07:54
Duration: 01:51:09.65, start: 0.000000, bitrate: 10226 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x800, SAR 1:1 DAR 12:5, 2
3.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(eng): Subtitle: subrip (default)
Stream #0:2(fre): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
(forced)
title : Ac3 640 Kbps
Stream #0:3: Subtitle: subrip
Stream #0:4(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s
title : DTS 1509 Kbps
Here is the output from the Serviio log for Red:
2013-12-01 01:28:52,993 WARN [LibraryManager] Skipping processing metadata for an unsupported file (Red.mkv). Message: Unknown video file type.
Post Mon Dec 02, 2013 9:12 pm
Re: Files and Folders Missing
Are you running 1.3.1?
Also check the access rights to the 2 files and if they are the same.
Users browsing this forum: No registered users and 59 guests
