streaming from my PC and no subtitles
BSTF
Post Tue Dec 03, 2013 7:31 am
Hello guys,
My gear is : BluRay Player Sony BDP S-790, TV Sony 40V4000, AV Receiver Sony STR DG-810, PC Dell quad core 6Gb ram. I cant see the subtitles when i stream from my PC, but I can see them when I put a movie on a flash drive and insert in the front USB from the BDP.
I would appreciate a good advice.
Thx all :D
Post Tue Dec 03, 2013 12:57 pm
Re: streaming from my PC and no subtitles
Enable Burned-in subtitles in the console and make sure you select the right profile.
BSTF
Post Tue Dec 03, 2013 1:09 pm
The sutitles are a .srt file, sorry for not telling that in the firs place.
Profile .... ??? Where pls?
Post Tue Dec 03, 2013 5:57 pm
BSTF
Post Wed Dec 04, 2013 9:05 pm
Thank you zip!!
Now an other problem, how do I increase the font size pls?
Thx ZIP
Post Thu Dec 05, 2013 9:18 am
If it's external and the TV supports that, you would in the TV's settings menu somewhere. If it's burned in, it's not currently possible, unless you use ass/ssa subtitles, which you can edit to change the font style.
BSTF
Post Thu Dec 05, 2013 2:07 pm
Ok thank you !!
BSTF
Post Sat Dec 07, 2013 12:10 pm
For the configuration described in my first post the photo in the attachment is the setting that works for the subs.
Best regards all
settings
Return to General discussion
