Only show music albums but not audiobooks
mysteray
Post Mon Dec 02, 2013 2:39 pm
Hi there,
I was wondering, if I could only display music albums but not audiobooks and the other way around.
One way would be to use the genre description "audiobook" for audiobooks and filter using the genre view, which is not the most comfortable way to browse your music collection, as you always have to select one genre and don't get to see all your albums in one window.
It would be great, if I could create a custom view for music albums, i.e. show all albums which have a genre entry unequal to audiobook.
Is that kind of tweaking possible?
Post Mon Dec 02, 2013 9:15 pm
Re: Only show music albums but not audiobooks
No, unless you split your folders and only share audio and not audio books.
mysteray
Post Tue Dec 03, 2013 2:04 pm
Damn!
Do you think, it would be realistic that something like that will ever be implemented by you in a future version?
It'd be great if there was a view for audiobooks, i.e. for all audio data having genre set to audiobook and one for music, i.e. for all audio data with genre field to set something else.
Post Thu Dec 05, 2013 8:09 pm
Don't know, seems to be a request for a very minor group of users.
mysteray
Post Fri Jan 31, 2014 2:28 pm
Okay. But it would be great to add audio without meta tags so you could access the files in the folder view without clogging up the other views.
