LG BD570 and mkv
rkasperski
Post Sat Jan 29, 2011 9:21 pm
LG BD570 and mkv
"C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe" -threads 4 -i "test.mkv" -y -vcodec mpeg2video -sameq -r 25.0 -g 15 -copyts -acodec ac3 -ab 384k -ac 2 -map 0:9 -map 0:1 -sn -f mpegts C:\Temp\Serviio\transcoding-temp-22174-MPEG2TS.stf
  configuration: --enable-static --disable-shared --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --arch=x86 --e
nable-runtime-cpudetect --enable-w32threads --target-os=mingw32 --cross-prefix=i686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[matroska,webm @ 0104efa0] Unsupported encoding typeUnsupported encoding typeUnsupported encoding typeUnsupported encoding typeUnsupported encoding typeUnsuppor
ted encoding typeUnsupported encoding typeUnsupported encoding typeUnsupported encoding typeUnsupported encoding typeUnsupported encoding typemax_analyze_durati
on reached
[matroska,webm @ 0104efa0] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from 'test.mkv':
  Duration: 00:48:07.16, start: 0.000000, bitrate: 128 kb/s
    Stream #0.0(dan): Subtitle: dvdsub
    Stream #0.1(eng): Subtitle: dvdsub
    Stream #0.2(eng): Subtitle: dvdsub
    Stream #0.3(spa): Subtitle: dvdsub
    Stream #0.4(fre): Subtitle: dvdsub
    Stream #0.5(dut): Subtitle: dvdsub
    Stream #0.6(nor): Subtitle: dvdsub
    Stream #0.7(fin): Subtitle: dvdsub
    Stream #0.8(swe): Subtitle: dvdsub
    Stream #0.9: Video: mpeg4, yuv420p, 720x538 [PAR 1:1 DAR 360:269], 25 fps, 25 tbr, 1k tbn, 25 tbc
    Stream #0.10: Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
Output #0, mpegts, to 'C:\Temp\Serviio\transcoding-temp-22174-MPEG2TS.stf':
    Stream #0.0: Video: mpeg2video, yuv420p, 720x538 [PAR 1:1 DAR 360:269], q=2-31, 200 kb/s, 90k tbn, 25 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, 2 channels, flt, 384 kb/s
Codec type mismatch for mapping #0.1 -> #0.1
It seems that the audio is on stream 10 and not on 1. If I manually convert it after changing the stream id for the input audio stream the resulting file is playable on the bd570.
Thanks for the great work
Post Sun Jan 30, 2011 12:06 am
Re: LG BD570 and mkv
