Re: ServiiDroid (Android Console) - Get it on Google Play
While it is a bit more of pain for users to setup, I'm hoping over time a decent number of you will sign up, and that way when I do have a version to test you will get it automatically.
Xmantium wrote:Hi will, how do i disable or enable a device? cant seem to find the option
running 1.3 beta 3 on my QNAP
Xmantium wrote:Ah the arrows are not clear if its disable or enable
It would be very cool if ServiiDroid got a refresh with the new Android card UI used in Play, Google Now ect - http://www.findmysoft.com/img/news/insi ... 849127.png
==== 2.1 ====
*Added initial support for Serviio 1.3
**Set access rules for new devices
**Set character encoding for subtitles
**Only show series in relevent categories
*Added option to set the bound IP address on Serviio 1.2+
*Added a note showing which server versions are supported
*Internal restructuring - you will need to re-add any homescreen shortcuts
*Fixed the number of new files being truncated when greater than 9999 (#67)
*Updated libraries
Users browsing this forum: Baidu [Spider] and 20 guests
