[PS3] The data type is not supported + other issues
dstruktnine
Post Mon Dec 09, 2013 9:17 pm
Hi there!
I recently installed Serviio on my desktop and I'm having issues with certain video files. I have Windows 7 64bit with an i7-2700K and 16GB RAM. I also have FFDShow installed on my computer. The renderer device is a Playstation 3.
My PS3 is hooked up via HDMI to my Pioneer Elite reciever.
Here is the ffmpgeg output of the file in question:
C:\Program Files\Serviio\lib>ffmpeg.exe -i D:\Torrents\Epic.2013.Repack.BluRay.1
080p.DTS.x264-HDWinG\Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG.mkv
[matroska,webm @ 01D3E840] max_analyze_duration 5000000 reached at 5005000 micro
seconds
[matroska,webm @ 01D3E840] Could not find codec parameters for stream 1 (Subtitl
e: hdmv_pgs_subtitle (pgssub)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
Input #0, matroska,webm, from 'D:\Torrents\Epic.2013.Repack.BluRay.1080p.DTS.x26
4-HDWinG\Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG.mkv':
    creation_time   : 2013-08-09 13:16:59
  Duration: 01:42:29.15, start: 0.000000, bitrate: 8812 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x800, SAR 1:1 DAR 12:5, 2
3.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Subtitle: hdmv_pgs_subtitle (default)
    Stream #0:2: Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default
Here is the mediainfo:
Unique ID                                : 253741084373179913642401773427858580314 (0xBEE4C1582A8C70738B8D3A8B2C1BA35A)
Complete name                            : D:\Torrents\Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG\Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG.mkv
Format version                           : Version 4 / Version 2
File size                                : 6.31 GiB
Duration                                 : 1h 42mn
Overall bit rate                         : 8 812 Kbps
Encoded date                             : UTC 2013-08-09 13:16:59
Writing application                      : mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41
Writing library                          : libebml v1.3.0 + libmatroska v1.4.0
Format settings, ReFrames                : 5 frames
Duration                                 : 1h 42mn
Bit rate                                 : 7 128 Kbps
Height                                   : 800 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.194
Stream size                              : 5.10 GiB (81%)
Writing library                          : x264 core 132 r2323+704+51 d571b1c tMod [8-bit@4:2:0 X86_64]
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.01:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=36 / lookahead_threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=240 / rc=crf / mbtree=1 / crf=17.5000 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.20 / aq=4:0.95 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : ES
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 1h 42mn
Bit rate                                 : 1 509 Kbps
Bit depth                                : 24 bits
Stream size                              : 1.08 GiB (17%)
Text
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : The same subtitle format used on BDs/HD-DVDs
And here is part of my log file that pertains to the file in question:
2013-12-09 12:50:46,344 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG.mkv
2013-12-09 12:50:46,344 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG.mkv: AVC_TS_MP_HD_AC3_ISO
2013-12-09 12:50:46,344 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 31 (local)
2013-12-09 12:50:46,344 DEBUG [VideoDeliveryEngine] Delivering item '31' for client 'Identifier=192.168.1.114, Profile=Playstation 3'
2013-12-09 12:50:46,344 DEBUG [VideoDeliveryEngine] Delivering file 'Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG.mkv' using transcoding
2013-12-09 12:50:46,344 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-30-4-ORIGINAL.stf', will stop the job
2013-12-09 12:50:46,345 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-30-4-ORIGINAL.stf'
2013-12-09 12:50:46,345 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-630,5,ServioThreads]
2013-12-09 12:50:46,355 DEBUG [ProcessUtils] Killing the Windows process: 5572
2013-12-09 12:50:46,370 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2013-12-09 12:50:46,387 DEBUG [TranscodingJobListener] Deleted temp file 'C:\Windows\TEMP\Serviio\transcoding-temp-30-4-ORIGINAL.stf': true
2013-12-09 12:50:46,387 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.114, Profile=Playstation 3'
2013-12-09 12:50:46,388 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: D:\Torrents\Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG\Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG.mkv
2013-12-09 12:50:46,388 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -threads 8 -i D:\Torrents\Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG\Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG.mkv -y -threads 8 -c:v copy -bsf:v h264_mp4toannexb -c:a ac3 -b:a 384k -ac 6 -map 0:0 -map 0:2 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-31-4-ORIGINAL.stf
2013-12-09 12:50:46,889 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-12-09 12:50:46,889 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Epic.2013.Repack.BluRay.1080p.DTS.x264-HDWinG.mkv: AVC_TS_MP_HD_AC3_ISO
2013-12-09 12:50:46,890 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-12-09 12:50:46,890 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-12-09 12:50:46,890 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-12-09 12:50:46,890 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Mon, 09 Dec 2013 20:50:46 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-6149/6149,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-12-09 12:50:47,469 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-12-09 12:50:48,341 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.112:55090s
2013-12-09 12:50:51,345 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.112:55090s
2013-12-09 12:50:54,985 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.100:53946s
2013-12-09 12:50:57,004 DEBUG [ServiioHttpService] Incoming request from /192.168.1.114:54097: GET /resource/29/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.100:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
2013-12-09 12:50:57,004 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.114
2013-12-09 12:50:57,004 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.114, Profile=Playstation 3'
2013-12-09 12:50:57,004 DEBUG [ResourceDeliveryProcessor] Request for resource 29 and type 'MEDIA_ITEM' received
Am I missing something? I really don't want to reencode a bunch of movies.
Another issue is that one of the movies I have, the audio is all static and the video plays at a high speed. If I play a different movie that loads fine, THEN switch back to the previous movie, it will play correctly.
Any help is greatly appreciated it!
Thanks!
dstruktnine
Post Mon Dec 09, 2013 9:42 pm
Re: [PS3] The data type is not supported + other issues
So I tried using my 360 and Epic played with no issues. I also tried a number of other video files that didn't play well on the PS3.
The Xbox is hooked up with component video and toslink for audio.
However, I'm not getting DD or DTS.
EDIT: I did get some audio sync issues.
Post Tue Dec 10, 2013 5:04 pm
Probably something in the h264 stream the PS3 doesn't like. FFmpeg cannot mux DTS to mpegts container, so it changes it to AC3 6 channel.
XBox transcodes the h264 video to WMV, so it'll play as it completely changes the stream. It's converted back to stereo though (there is no FFmpeg encoder for multichannel WMA audio)
dstruktnine
Post Tue Dec 10, 2013 5:09 pm
zip wrote:Probably something in the h264 stream the PS3 doesn't like. FFmpeg cannot mux DTS to mpegts container, so it changes it to AC3 6 channel.
What can I do to make it work on the PS3? Use a different profile for the PS3?
Post Tue Dec 10, 2013 11:34 pm
You could try remuxing the MKV into an MP4 container - the PS3 plays MP4's natively.
Use the command ffmpeg -i "filename.mkv" -map 0 -c copy "filename.mp4" to remux the file - it should be pretty quick. Or use the remux tab in my tool here: viewtopic.php?f=17&t=12136 which will do the same thing.
If the problem is with the h264 stream this wont help (as that stream is simply copied across), but it will help to confirm that to be the issue.
dstruktnine
Post Fri Dec 13, 2013 2:18 am
^^ Spam.
Anyways, I've been using PS3 Media Server and all my files play fine. The main thing I miss about Serviio is how it presented the files on the PS3 and that I could choose which files to index.
Ah well :(
