Rebooting Serviio only way to restart video streams
sliprock
Post Sat Dec 07, 2013 9:53 pm
OK guys I am going to throw this problem out to the forum. I couple of problems with Serviio which I got fixed and downloaded Vettle plugin and the web resource to get my channels to come up. Not all the channels are playing all the time but can understand that. But this problem happens continuously.
When I load up Servillo I can get quick response to channel changes and download programs quickly. But after about 2.5 hours the channels start degrading and finally the system says "Cant feed file". After rebooting Serviio everthing works great for 2.5 hours. This is not intermittent problem. This happens consistently since I downloaded Vettle. The degrading is consistent with low bandwith. I checked internet speed before and after download. It has stayed at the recommended speed. I think that there is something happening within the computer to hang slowly hang the program up and after awhile slowly interfere with the dnla process. When this happens the internet radio continue to play great. So this tells me it is something in the vettle plugin. Checked in forum about the router not passing the right packets but my router seems to be working fine. Checked in log files there is nothing to show that there is any error code until the "Cant read file" shows up. Open to suggestions as to what is happening and how to get the problem fixed.
thanks Sliprock
sliprock
Post Tue Dec 10, 2013 4:46 am
Re: Rebooting Serviio only way to restart video streams
OK ppl . I turned servillo off for a couple of days and restarted my Windows 7 getting the following code (see below). Stopped and stated the program using the Serviio console. Getting the same code unless I reboot the program and clears the error code out. Something on input from the http: service is hanging the processor up and when start and stop is not resetting it. But have not got a clue what it is. Anybody else got any suggestions.
Thanks Sliprock
[code][/code]
2013-12-09 22:20:48,166 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-12-09 22:20:48,166 INFO [WebServer] WebServer shutting down
2013-12-09 22:20:48,173 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-12-09 22:20:48,173 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-12-09 22:20:48,173 INFO [EventDispatcher] Leaving EventDispatcher
2013-12-09 22:23:21,737 INFO [WebServer] WebServer starting on port 8895
2013-12-09 22:23:21,853 INFO [Device] Updated bound IP address of Device with UUID: 26f8d836-e8a6-3368-b500-608a6ae82b25, bound address: 192.168.1.112
2013-12-09 22:23:21,854 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-12-09 22:23:21,856 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-12-09 22:23:21,863 INFO [EventDispatcher] Starting EventDispatcher
2013-12-09 22:23:21,896 INFO [RendererSearchSender] Searching for Renderer devices
2013-12-09 22:23:21,897 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.112, timeout = 0
2013-12-09 22:25:36,166 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 0189CFA0] HTTP error 404 Not found
http://216.221.144.233:80/flv/52a40ad542b86/testat123: Input/output error
2013-12-09 22:26:01,665 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 031DCFA0] HTTP error 404 Not found
http://216.221.144.234:80/flv/5182a69d8d061/testat123: Input/output error
2013-12-09 22:26:27,231 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 035ECFA0] HTTP error 404 Not found
http://216.221.144.235:80/flv/52a4d256d6a80/testat123: Input/output error
2013-12-09 22:26:53,281 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 01A7CFA0] HTTP error 404 Not found
http://216.221.144.231:80/flv/52a26b1b3cd8c/testat123: Input/output error
2013-12-09 22:27:18,298 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 0352CFA0] HTTP error 404 Not found
http://216.221.144.214:80/flv/52a3022ecb4a6/testat123: Input/output error
2013-12-09 22:27:43,813 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
http://216.221.144.163:80/flv/525ea3cb8ee14/testat123: Input/output error
2013-12-09 22:28:09,333 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 01A3CFA0] HTTP error 404 Not found
http://216.221.144.203:80/flv/52a3b5aef31ed/testat123: Input/output error
2013-12-09 22:28:34,820 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 0365CFA0] HTTP error 404 Not found
http://216.221.144.163:80/flv/527c61b6a6e65/testat123: Input/output error
2013-12-09 22:29:00,262 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
http://216.221.144.242:80/flv/52a42bf0d1e32/testat123: Input/output error
2013-12-09 22:29:25,789 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 01A2CFA0] HTTP error 404 Not found
http://216.221.144.203:80/flv/509aac82a99b5/testat123: Input/output error
2013-12-09 22:29:52,377 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 0377CFA0] HTTP error 404 Not found
http://216.221.144.178:80/flv/5293e747adbe2/testat123: Input/output error
2013-12-09 22:29:53,166 WARN [PipedOutputBytesReader] Error reading bytes stream from external process: Stream closed
2013-12-09 22:30:18,706 WARN [PipedOutputBytesReader] Error reading bytes stream from external process: Stream closed
2013-12-09 22:30:19,475 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 0367CFA0] HTTP error 404 Not found
Post Tue Dec 10, 2013 6:03 am
Hi sliprock - have moved your topic under the more general Support and Help forum as I don't think the issue is Panasonic related. You may get more support here.
Post Tue Dec 10, 2013 4:57 pm
the error is only related to a stream URL that doesn't exist, nothing that should affect the system stability.
Are you playing the same stream of flicking between multiple streams during the 2.5 hours?
Users browsing this forum: No registered users and 64 guests
