Serviio and Now TV Box (Roku)
spudy12
Post Fri Dec 06, 2013 7:39 pm
Just curious as to if anyone has used Serviio server to stream to the Now TV Box (rebranded roku)
I know you can side load on plex and stream from that but is there anyway to do it woth serviio?
Thanks!
Post Fri Dec 06, 2013 11:56 pm
Re: Serviio and Now TV Box (Roku)
spudy12 wrote:Just curious as to if anyone has used Serviio server to stream to the Now TV Box (rebranded roku)
Thanks!
Never heard of the Now box, but there is a Roku channel that will work with Serviio. It's called Chaneru, and overall handles things real well. If your videos are in MP4 format, the Roku plays them native and Serviio does not transcode. Everything else will be transcoded, and Serviio 1.3 has a minor bug with playing the entire length of the movie. However, Zip has it fixed with Serviio 1.4, and that should be released before Christmas.
If the Now TV Box can use standard Roku channels, you might try Chaneru. My only issues have been with HD video, as the Roku will choke on bit rates that get too high. Most play fine, but there are a few that the Roku can't keep up with.
spudy12
Post Sat Dec 07, 2013 12:43 am
this is the now tv box
https://shop.nowtv.com/
i'll have a look in to that app, but may just go for a Pi instead as it can support 1080p at high bit rates.
thanks,
Post Sun Dec 08, 2013 4:14 am
spudy12 wrote:this is the now tv box
thanks,
Ah, that's why I hadn't heard of it. UK only. I'm in the states.
I've briefly looked at the Pi boards, but am unsure what OS and applications they would run. Guess that means I haven't look very close :lol:
Xmantium
Post Mon Dec 09, 2013 11:32 pm
I was looking at this today, Now TV Box is just a rehash or Roku LT - http://www.roku.com/uk/choose-your-roku
But it runs Sky's own version of Roku's OS with limited apps
Now TV Box is really cheap @£9.99 when the Roku LT Box is about £30+
Since theres no custom app like Plex for Serviio to sideload. Unless it supports streaming DLNA videos
spudy12
Post Tue Dec 10, 2013 11:06 pm
I have side loaded Plex on to it but haven't had a chance to try Chaneru
Will try over the weekend / early next week and get back to you. I imagine videos will have to be trans coded down from 1080p but for the price it isn't a half bad option
Mutoidmess
Post Thu Dec 26, 2013 6:05 pm
Anyone had any joy with serviio and now tv?
Jason55
Post Fri Jan 10, 2014 12:17 am
I found the following eBook from Amazon very helpful 'The Practical Guide To Making Your 'Dumb' TV A 'Smarter' TV for Under a Tenner Using A NOW TV Box', it demonstrates streaming network content to a NOW TV/ Roku Box using Serviio.
Post Fri Jan 10, 2014 12:56 am
Can the Now Box load normal Roku channels? If so, Roku has released a new media player that supports DLNA.
Marksuk
Post Fri Jan 10, 2014 9:23 am
Yes you can sideload Plex but the box itself will not let you load standard roku channels, save your money and get a proper Roku, I have a Roku XS and a NOW TV box and the now tv box is quite good value for what it is but does not compare with a real Roku box which is now useable with Serviio (DLNA) with mp4, mp3 and jpeg files.
I find Plex to be a bit unreliable too.
The now tv box in its present form is no good for streaming at all, buy a real Roku instead. :D
hillda01
Post Sat Jan 11, 2014 5:46 pm
Just bought myself a Now TV box today and installed mediabrowser3 but struggling to get it to see my Serviio NAS....
I see mediabrowser3 does a server component but don't want to go to the trouble of installing that on my NAS as well...
Has anyone used mediabrowser3 before to see Serviio or UPNP / DLNA before?
Regards,
Dave.
spudy12
Post Wed Feb 12, 2014 2:02 pm
atc98092 wrote:Can the Now Box load normal Roku channels? If so, Roku has released a new media player that supports DLNA.
What is this media player called? I'll see if I can sideload it like plex
Post Thu Feb 13, 2014 12:21 am
They thought hard on the player name. It's the Roku Media Player :lol:
Return to User experiences
