humax hd pvr playing video with ac3 audio
wolter72
Post Mon Dec 09, 2013 3:16 pm
I have a lot of divx (avi) movie which are coded with ac3 audio but if i play them on my humax i don't hear sound, the files with mp3 audio do play.
Can i make serviio transcode the audio to mp3 so i have sound? and if yes how can i do this?
Thanx
Wolter
NO audio on Humax with :
Formaat : AC-3
Formaat/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Formaatinstellingen, Endianness : Big
Codec-ID : 2000
Duur : 1h 25mn
Bitrate-modus : Constant
Bitrate : 192 Kbps
Kanaal(en) : 2 kanalen
Kanaalposities : Front: L R
Samplerate : 48,0 KHz
BitDepth/String : 16 bits
Stroomgrootte : 118 MiB (6%)
Uitlijning : Uitgelijnd op interleaves
Interleave, duur : 32 ms (0,77 videoframes)
Interleave, preloadduur : 512 ms
With this there is audio :
Formaat : MPEG Audio
Formaatversie : Version 1
Formaatprofiel : Layer 3
Format_Settings_Mode : Joint stereo
Format_Settings_ModeExtension : MS Stereo
Codec-ID : 55
Codec-ID/Hint : MP3
Duur : 1h 25mn
Bitrate : 192 Kbps
Stroomgrootte : 118 MiB (10%)
Interleave, duur : 24 ms (0,60 videoframes)
Interleave, preloadduur : 24 ms
Gebruikte encoderbibliotheek : LAME3.98.2
Post Tue Dec 10, 2013 5:10 pm
Re: humax hd pvr playing video with ac3 audio
Can you post ffmpeg -i of the file(s)?
wolter72
Post Wed Dec 11, 2013 6:14 pm
File 1: (thsis one works)
ffmpeg started on 2013-12-11 at 19:10:17
Report written to "ffmpeg-20131211-191017.log"
Command line:
ffmpeg -i "h:/divx/film/komedie/scary movie 4 (nl sub).avi" -report
ffmpeg version N-58882-ga12f679 Copyright (c) 2000-2013 the FFmpeg developers
built on Dec 8 2013 22:01:45 with gcc 4.8.2 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 52. 56.100 / 52. 56.100
libavcodec 55. 45.100 / 55. 45.100
libavformat 55. 22.100 / 55. 22.100
libavdevice 55. 5.102 / 55. 5.102
libavfilter 3. 92.100 / 3. 92.100
libswscale 2. 5.101 / 2. 5.101
libswresample 0. 17.104 / 0. 17.104
Splitting the commandline.
Reading option '-i' ... matched as input file with argument 'h:/divx/film/komedie/scary movie 4 (nl sub).avi'.
Reading option '-report' ... matched as option 'report' (generate a report) with argument '1'.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option report (generate a report) with argument 1.
Successfully parsed a group of options.
Parsing a group of options: input file h:/divx/film/komedie/scary movie 4 (nl sub).avi.
Opening an input file: h:/divx/film/komedie/scary movie 4 (nl sub).avi.
[avi @ 003238e0] Format avi probed with size=2048 and score=100
[avi @ 033308a0] use odml:1
[avi @ 003238e0] Before avformat_find_stream_info() pos: 10008 bytes read:5625200 seeks:4
[avi @ 003238e0] All info found
[avi @ 003238e0] After avformat_find_stream_info() pos: 13760 bytes read:5625200 seeks:4 frames:2
Input #0, avi, from 'h:/divx/film/komedie/scary movie 4 (nl sub).avi':
title : SM40EUW1________________________.Title1.DVDRip
album : SM40EUW1________________________
encoder : Lavf52.33.0
Duration: 01:25:46.08, start: 0.000000, bitrate: 1905 kb/s
Stream #0:0, 1, 1/25: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 720x388 [SAR 1:1 DAR 180:97], 25 tbr, 25 tbn, 25 tbc
Stream #0:1, 1, 1/24000: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16p, 192 kb/s
Successfully opened the file.
[AVIOContext @ 033307e0] Statistics: 5625200 bytes read, 4 seeks
File 2 (this file does not work)
ffmpeg started on 2013-12-11 at 19:12:20
Report written to "ffmpeg-20131211-191220.log"
Command line:
ffmpeg -i "h:/divx/film/komedie/scary movie 5 (nl sub).avi" -report
Reading option '-i' ... matched as input file with argument 'h:/divx/film/komedie/scary movie 5 (nl sub).avi'.
Parsing a group of options: input file h:/divx/film/komedie/scary movie 5 (nl sub).avi.
Opening an input file: h:/divx/film/komedie/scary movie 5 (nl sub).avi.
[avi @ 002e38e0] Format avi probed with size=2048 and score=100
[avi @ 036c08a0] use odml:1
[avi @ 002e38e0] non-interleaved AVI
[avi @ 002e38e0] Before avformat_find_stream_info() pos: 4108 bytes read:2501008 seeks:8
[avi @ 002e38e0] first_dts 0 but no packet with dts in the queue
[avi @ 002e38e0] All info found
[avi @ 002e38e0] After avformat_find_stream_info() pos: 26516 bytes read:2501008 seeks:8 frames:5
Input #0, avi, from 'h:/divx/film/komedie/scary movie 5 (nl sub).avi':
encoder : MEncoder Sherpya-MT-SVN-r31027-4.2.5
Duration: 01:25:46.78, start: 0.000000, bitrate: 3124 kb/s
Stream #0:0, 1, 1/24: Video: mpeg4 (Simple Profile) (XVID / 0x44495658), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 24 tbr, 24 tbn, 24 tbc
Stream #0:1, 4, 4/125: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, fltp, 192 kb/s
[AVIOContext @ 036c07e0] Statistics: 2501008 bytes read, 8 seeks
Post Fri Dec 13, 2013 2:43 pm
You could add a profile like this and try that:
<Profile id="humax" name="Humax HD PVR" extendsProfileId="1">
    <Video targetContainer="mpegts" targetACodec="mp3">
      <Matches container="avi" aCodec="ac3" />
wolter72
Post Tue Dec 17, 2013 1:52 pm
I tried this but i still have no sound.
mightymouse2045
Post Tue Dec 17, 2013 6:09 pm
wolter72 wrote:Hello,
Have you opened the serviio console and confirmed your client has that profile applied to it?
Users browsing this forum: Baidu [Spider] and 16 guests
