lpcm bit depth setting
THSA
Post Fri Dec 06, 2013 10:32 pm
Hi everyone,
Is it possible to transcode DTS-HD 24 bits to LPCM 16 bits with Serviio/FFmpeg?
Bests,
Post Mon Dec 09, 2013 10:02 am
Re: lpcm bit depth setting
Serviio will not issue any specific command to FFmpeg regarding bitdepth (as far as I can rememember), but you can give it a try. It'll be just stereo, though.
THSA
Post Wed Dec 11, 2013 10:05 pm
OK zip thanks. I'll experiment. I'm fine with stereo as long as I can keep things lossless.
