ps3 help wanted!
starfóx
Post Sun Dec 15, 2013 12:56 pm
ps3 help wanted!
Been using Serviio for along time now. Up until the last few days i've not been able to stream live twitch.tv streams. Nothing has changed other than updating my pc to window 8.1. The errors im getting on the ps3 are 80710723 basically what happens is the screen goes black for like and seems to time out. The other error i've noticed at the start of my boot up on the ps3 is a dlna 2104 error which never usually happens this is a proximity error but the signal strength is 99% so i dont get tht. If any of these errors had happened usually is just to reset the server and everything would be fine. I have no idea whats causing it.
One other thing i've noticed is my pcs wifi turns its self on since i've updated to windows 8.1 would this be interfering with it???? really have no idea.
Ive updated serviio to the latest version and also updated the plugins
very sad panda indeed.
Post Mon Dec 16, 2013 12:27 am
Re: ps3 help wanted!
I see you've also asked in the pluging forum re: twitch.tv - that probably the best place as you can get support from other users of twitch.
wrt the the 2104 error, some users have reported improvement if they reset their Media Server from within the PS3 - in the settings area from memory (disable DLNA, then restart PS3 then re-enable).
However it could also be that your PC is also using wireless bandwidth. If it is using wireless for streaming to the PS3, which is also wirelessly connected, you could be saturating the link, particularly for HD video. It sounds like you don't need to be using wireless for the PC - try disabling it all together for now and seeing if that improves the situation. If that does work, I'd look at Windows support to find out why wireless is turning on when you're connected via cable.
