ServiioGo not playing files on HTC EVO 3D over 3G
movieaddict
Post Tue Dec 17, 2013 8:17 pm
Serviio Gods... I have a very interesting and confusing problem that I hope you can help me with. I currently have Serviio 1.3.1 running under Windows 7 (with all the latest updates) on an Intel Quad Core machine with 6GB RAM and a 3 TB Hard Drive. I have never had any issues accessing any of the many movies or TV shows that I have with any device located on my internal network (including my HTC EVO 3D when its on WiFi). I was hoping to watch them on the road... so... I recently purchased the Pro license, installed ServiioGo on my HTC 3D phone and manually setup my router to forward port 23424 to my Serviio server. I first tested the connection using the test button on the Serviio console remote tab window and it gave me a big red X... Hmm... I went and rechecked the setup in my router and all looked good... so i thought I would try it anyhow. So... On my HTC 3D running only on 3G and with a good signal to the tower I can get as far as the list of movies (with the correct thumbnails being shown properly ). Once I try and play a movie or TV show - at any of the many resolutions and setting combinations permitted via ServiioGO - the spinner spins like its trying to load the movie... but after a few seconds ServiioGo comes back with "connection the server was lost" "Cancel/Retry". Its odd that it gets that far - allowing me to login and to see what I have in my library , but cannot play the movie??? This does not happen when I am on WiFi - the 3D plays the movie perfectly. BTW, I can also access the MediaBrowser app from my 3D over 3G ... same thing happens though. I will try to attach the end of my log file (after the library loads)... perhaps that may help...
BTW... did I mention that this is one AWESOME app!!!!! Kudos to all the developers and maintainers!!!
2013-12-17 08:01:50,345 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 44220 and profile ServiiGo (HLS)
2013-12-17 08:01:50,345 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Zombieland.vob: HLS
2013-12-17 08:01:50,345 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 73927)
2013-12-17 08:01:50,346 DEBUG [MediaItemDAOImpl] Getting file of media item 44220
2013-12-17 08:01:50,346 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [Any]
2013-12-17 08:01:50,351 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-12-17 08:02:00,686 DEBUG [SearchManager] Committing search index
2013-12-17 08:02:30,688 DEBUG [SearchManager] Committing search index
2013-12-17 08:02:31,280 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller) and address 192.168.10.2, timeout = 0
2013-12-17 08:02:31,280 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 539f0fb7-eebe-3300-8eec-48caabf3c39a
2013-12-17 08:02:33,245 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:08 (advertisement duration is 1800 sec.)
2013-12-17 08:02:35,138 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-12-17 08:02:35,138 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-12-17 08:02:38,154 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2013-12-17 08:02:38,154 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2013-12-17 08:02:38,162 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-12-17 08:02:38,254 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-12-17 08:02:38,354 INFO [FeedUpdaterThread] Finished looking for online resources information
2013-12-17 08:02:38,454 INFO [PluginCompilerThread] Finished looking for plugins
2013-12-17 08:02:38,555 INFO [SearchIndexer] Closing search index writer
2013-12-17 08:02:38,557 INFO [SearchIndexer] Closing search index writer
2013-12-17 08:02:38,558 DEBUG [WebServer] Socket closed
2013-12-17 08:02:38,558 INFO [WebServer] WebServer shutting down
2013-12-17 08:02:38,558 DEBUG [DiscoveryManager] UPNP device 539f0fb7-eebe-3300-8eec-48caabf3c39a (192.168.10.2) is unavailable
2013-12-17 08:02:38,562 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-12-17 08:02:38,592 DEBUG [DiscoverySSDPMessageListener] Socket closed: socket closed
2013-12-17 08:02:38,592 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-12-17 08:02:38,592 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-12-17 08:02:38,593 INFO [EventDispatcher] Leaving EventDispatcher
2013-12-17 08:02:38,594 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth3 (Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller) and address 192.168.10.2, timeout = 0
2013-12-17 08:02:38,594 INFO [DatabaseManager] Shutting down database
2013-12-17 08:02:38,594 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2013-12-17 08:02:39,031 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2013-12-17 08:02:39,031 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-12-17 08:02:39,031 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2013-12-17 08:02:50,684 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2013-12-17 08:03:00,804 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2013-12-17 08:03:10,946 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
Post Tue Dec 17, 2013 8:32 pm
Re: ServiioGo not playing files on HTC EVO 3D over 3G
We will need to see some more of the log, specifically of you connecting to the server, and starting playback. Can you also change org.restlet to DEBUG (in the same place that you turned on normal debug logging).
What sort of internet connection do you have at home, and wat mobile internet plan do you have/with who? To start with, use the Low quality option, or pick a non-HD file and use Original.
Do you mean that MediaBrowser video streaming also works over WiFi, but not 3G?
movieaddict
Post Tue Dec 17, 2013 9:03 pm
I will try and get that additional information for you tonight.
For the internet connection at home I have Verizon FIOS Quantum (50 Mbps)
For the Mobile Plan, my provider is Sprint with Unlimited Data....unfortunately I only have 3G in my area.
I did try low quality files on the low setting... same results...
I don't know if MediaBrowser inside a browser app works over WiFi as that I have not tried. It just didn't work over 3G...
However... ServiiioGo worked over WiFi without issues (high quality)
movieaddict
Post Wed Dec 18, 2013 10:20 pm
That is correct. I tried this last night over WiFi and it worked perfectly
As for the log when i connect, I'm not sure exactly what you are looking for in my log file, but here is a snippet from the file. If you need the whole file I can E-Mail it to you. Note that I "AA.BB.CC.DD" my external IP address. Also note that 192.168.10.2 is my internal Serviio server address. I do not know who owns 192.168.10.19?
013-12-18 07:51:09,448 INFO [LogService] 2013-12-18 07:51:09 66.87.114.XYZ - - 23424 GET /cds/browse/serviigo_hls/V_M/BrowseDirectChildren/all/0/0 authToken=7a81395af1cf4e57850907c84d3f3ad9 200 - 0 2577 http://AA.BB.CC.DD:23424 ServiiGo/3.1.1(112); Dalvik/1.6.0 (Linux; U; Android 4.0.3; PG86100 Build/IML74K) -
2013-12-18 07:51:10,376 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:11,385 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:11,391 INFO [LogService] 2013-12-18 07:51:11 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 1 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:51:12,381 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:13,385 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:14,394 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:15,403 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:16,404 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:16,492 INFO [LogService] 2013-12-18 07:51:16 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 1 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:51:17,409 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:18,413 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:19,408 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:19,540 DEBUG [SearchManager] Committing search index
2013-12-18 07:51:20,410 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:21,413 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:21,592 INFO [LogService] 2013-12-18 07:51:21 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 1 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:51:22,423 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:23,419 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:24,414 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:25,430 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:26,426 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:26,692 INFO [LogService] 2013-12-18 07:51:26 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 1 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:51:27,436 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:28,439 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:29,434 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:30,447 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:31,461 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:31,795 INFO [LogService] 2013-12-18 07:51:31 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 1 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:51:32,470 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:33,467 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:34,489 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:35,496 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:36,504 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:36,896 INFO [LogService] 2013-12-18 07:51:36 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 1 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:51:37,511 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:38,517 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:39,525 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:40,516 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:41,518 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:41,996 INFO [LogService] 2013-12-18 07:51:41 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 1 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:51:42,528 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:43,537 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:44,542 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:51:45,543 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.19:41977s
2013-12-18 07:
2013-12-18 07:56:44,660 INFO [LogService] 2013-12-18 07:56:44 66.87.114.XYZ - - 23424 GET /cds/application - 200 - 0 0 http://AA.BB.CC.DD:23424 ServiiGo/3.1.1(112); Dalvik/1.6.0 (Linux; U; Android 4.0.3; PG86100 Build/IML74K) -
2013-12-18 07:56:45,020 DEBUG [LoginServerResource] Successful login, generating security token
2013-12-18 07:56:45,020 WARN [LogFilter] Couldn't find any helper support the HTTP_Serviio challenge scheme.
2013-12-18 07:56:45,020 INFO [LogService] 2013-12-18 07:56:45 66.87.114.XYZ - - 23424 POST /cds/login - 200 - 0 0 http://AA.BB.CC.DD:23424 ServiiGo/3.1.1(112); Dalvik/1.6.0 (Linux; U; Android 4.0.3; PG86100 Build/IML74K) -
2013-12-18 07:56:45,720 DEBUG [VideoDAOImpl] Retrieving number of video initials [Any]
2013-12-18 07:56:45,820 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [Any]
2013-12-18 07:56:45,830 DEBUG [SeriesDAOImpl] Retrieving number of series
2013-12-18 07:56:45,831 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [Any]
2013-12-18 07:56:45,832 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos [Any]
2013-12-18 07:56:45,861 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2013-12-18 07:56:45,861 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0 [Any]
2013-12-18 07:56:45,892 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2013-12-18 07:56:45,945 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2013-12-18 07:56:46,354 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2013-12-18 07:56:46,384 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2013-12-18 07:56:46,666 DEBUG [VideoDAOImpl] Retrieving number of video release years [Any]
2013-12-18 07:56:46,696 DEBUG [PlaylistDAOImpl] Retrieving number of playlists for VIDEO [Any]
2013-12-18 07:56:46,696 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [Any]
2013-12-18 07:56:46,696 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [Any]
2013-12-18 07:56:46,696 INFO [LogService] 2013-12-18 07:56:46 66.87.114.XYZ - - 23424 GET /cds/browse/serviigo_hls/V/BrowseDirectChildren/all/0/0 authToken=df33be2b109543099235ac311d17d1de 200 - 0 976 http://AA.BB.CC.DD:23424 ServiiGo/3.1.1(112); Dalvik/1.6.0 (Linux; U; Android 4.0.3; PG86100 Build/IML74K) -
2013-12-18 07:56:47,956 INFO [LogService] 2013-12-18 07:56:47 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:56:49,386 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-12-18 07:56:49,406 INFO [LogService] 2013-12-18 07:56:49 66.87.114.XYZ - - 23424 GET /cds/browse/serviigo_hls/V_M/BrowseDirectChildren/all/0/0 authToken=df33be2b109543099235ac311d17d1de 200 - 0 20 http://AA.BB.CC.DD:23424 ServiiGo/3.1.1(112); Dalvik/1.6.0 (Linux; U; Android 4.0.3; PG86100 Build/IML74K) -
2013-12-18 07:56:49,568 DEBUG [SearchManager] Committing search index
2013-12-18 07:56:50,818 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-12-18 07:56:50,818 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-12-18 07:56:52,998 INFO [LogService] 2013-12-18 07:56:52 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:56:58,099 INFO [LogService] 2013-12-18 07:56:58 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:03,200 INFO [LogService] 2013-12-18 07:57:03 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:08,302 INFO [LogService] 2013-12-18 07:57:08 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:13,404 INFO [LogService] 2013-12-18 07:57:13 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:18,504 INFO [LogService] 2013-12-18 07:57:18 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:19,574 DEBUG [SearchManager] Committing search index
2013-12-18 07:57:23,605 INFO [LogService] 2013-12-18 07:57:23 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:28,706 INFO [LogService] 2013-12-18 07:57:28 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:33,806 INFO [LogService] 2013-12-18 07:57:33 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:38,907 INFO [LogService] 2013-12-18 07:57:38 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:44,009 INFO [LogService] 2013-12-18 07:57:44 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:49,111 INFO [LogService] 2013-12-18 07:57:49 127.0.0.1 - - 23423 GET /rest/library-status - 200 - 0 0 http://localhost:23423 Restlet-Framework/@major-number@.@minor-number@@release-type@@release-number@ -
2013-12-18 07:57:49,581 DEBUG [SearchManager] Committing search index
2013-12-18 07:57:50,823 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-12-18 07:57:50,823 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-12-18 07:57:51,463 DEBUG [PlaylistDAOImpl] Reading all Playlists
Post Wed Dec 18, 2013 10:32 pm
That is really odd! I guess it's helpful/consistent that it affects MediaBrowser as well as ServiiGo.
I was hoping to see ServiiGo trying to download the video, did you actually play anything as the log only shows you browsing your movies.
I don't suppose you can try it at work/friends wifi? To rule out carrier blocking (very unlikely).
Can you also try with an audio file?
movieaddict
Post Thu Dec 19, 2013 1:43 am
Yes... very odd.. exactly what I thought. Although I did try and play the movie, all it ever gave me was "connection the server was lost" "Cancel/Retry"..
I will try a friends WiFi and Music tomorrow and post results here
movieaddict
Post Thu Dec 19, 2013 6:20 pm
Ok so I tried music over 3G and that works perfectly. Then went to McDonald's and tried the.movies over 3G and that didn't work. Connected myself to McDs WiFi and low and behold the movies worked flawlessly,
Sent from my PG86100 using Tapatalk
Post Thu Dec 19, 2013 6:54 pm
Could you maybe ask on the forums for your mobile contract provider?
movieaddict
Post Sat Dec 21, 2013 4:01 pm
Ok so its my phone but I'm not sure why. I tried my sons iPhone4 which is on our plan and carrier and both the music and video worked flawlessly. And yes I turned his WiFi off before I tried it. I then tried with my phone and again and it didn't work. Any clues? I was going to try to root my phone and get rid of all of the extra running processees and try again
Post Sat Dec 21, 2013 4:20 pm
It doesn't have some sort of data saving feature?
Post Tue Dec 31, 2013 9:41 am
Return to User experiences
