Sony KDL55W805A add AC3 or transcode DTS
chrismallia
Post Fri Dec 20, 2013 4:36 pm
Hi I have Sony KDL55W805A and I am using the profile created thanks goes to ILLICO and it is working great thank you so much. I kneed some advice the Tv downmixes DTS to stereo and I have a 5.1 system pluged to the tv via optical cable, so I am using popcorn mkv audioconverter to add ac3 audio beside the DTS, Do you think it is best to tweek the profile to transcode the dts to ac3 ?
server running serviio PRO and media browser Intel dual core g2030 3.0Ghz 8gb dd3 ram Microsoft windows server 2012 gigabit network . Devices Sony KDL55W805A, ps3, 2 sony bravia 2011, 5 android devices 2 of them samsung galaxy s3 running bubble upnp and serviigo, netgem netbox , 2 laptops XBMC windows 8
Post Sat Dec 21, 2013 9:22 am
Re: Sony KDL55W805A add AC3 or transcode DTS
chrismallia wrote:...I kneed some advice the Tv downmixes DTS to stereo and I have a 5.1 system pluged to the tv via optical cable...
Could you provide information about your video file (see signature link)?
Does DTS track is transcoded or delivered in native format ?
Could you enable "Delivery" -> "TRanscoding" -> "Keep Original", then save and restart serviio service or reboot PC.
chrismallia
Post Sat Dec 21, 2013 1:47 pm
Here is one of the files it is a mkv what it does it plays in nativ format but the tv downmixes to stereo
Complete name : D:\Movies\Animation\Hotel.Transylvania\hotel.transylvania.mkv
Format : Matroska
Format version : Version 2
File size : 4.37 GiB
Duration : 1h 31mn
Overall bit rate : 6 834 Kbps
Writing application : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08
Writing library : libebml v1.0.0 + libmatroska v1.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 31mn
Bit rate : 5 323 Kbps
Width : 1 920 pixels
Height : 1 040 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.111
Stream size : 3.32 GiB (76%)
Writing library : x264 core 129 r2230 1cffe9f
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5323 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 31mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 988 MiB (22%)
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Language : English
Default : Yes
Forced : Yes
Menu
00:00:00.000 : en:00:00:00.000
00:04:49.372 : en:00:04:49.372
00:10:23.790 : en:00:10:23.790
00:14:19.275 : en:00:14:19.275
00:19:25.498 : en:00:19:25.498
00:25:11.218 : en:00:25:11.218
00:29:49.413 : en:00:29:49.413
00:35:50.815 : en:00:35:50.815
00:41:11.636 : en:00:41:11.636
00:46:29.537 : en:00:46:29.537
00:53:50.227 : en:00:53:50.227
00:57:44.795 : en:00:57:44.795
01:04:15.268 : en:01:04:15.268
01:08:48.499 : en:01:08:48.499
01:15:20.599 : en:01:15:20.599
01:18:50.643 : en:01:18:50.643
Post Sat Dec 21, 2013 7:22 pm
I confirm that this mkv/h264/dts file should be delivered in native format (you can check it on detailed logging file).
If you select "Sony 2012" or other sony profile, dts should be transcoded to ac3 (multichannel)(keep original audio format should be checked on serviio console).
So this is the TV that downstream the audio to stereo on output optical.
Do you check all sony menu settings ?
http://pdf.crse.com/manuals/13MW802111/ ... gaout.html
Do you try to set "Audio System" on menu
http://pdf.crse.com/manuals/13MW802111/ ... nd_sp.html
http://pdf.crse.com/manuals/13MW802111/ ... o_opt.html
