Sound sync feature
FW: T-VALDEUC-3007.1
zip wrote:It's up to the TV or your AV receiver to do that.
Troutking wrote:Wired or wireless, makes no difference.. Sometimes the sound starts out in sync and slowly goes out, and vice versa. Also if starting to view a season of a series, the first few episodes starts out in sync, but then the later ones goes out of sync. 100ms-1000ms+ out.
edit; spelling
Troutking wrote:zip wrote:It's up to the TV or your AV receiver to do that.
I don't know about any TV or AV receiver that corrects a media file that is recorded/created with sound/picture out of sync. However there is a lot of software players that can correct this, VLC-player being one of them. I was just hoping that it would be possible to advance or retard the sound. I'm not sure if sound and picture/movie are transmitted separate in DLNA protocol, but if they are, should it not be possible?
Cerberus wrote:ok just to be exact on this so other can Benefit.
The Samsung UE40C6000 and UE40C6000.
Troutking wrote:!?Cerberus wrote:ok just to be exact on this so other can Benefit.
No, UE40C6000, UE46C6000, UE406005 and UE406005(they may all be fitted with the junk version of motherboard). Could be other models too, if they are using the same mainboard with the junk firmware.....
Cerberus wrote:
NO other models are fitted with this board and its UE40C6xxx SERIES if you want to get to symantics and to be honest you hijacked a sony topic, with samsung information but oh well.
Cerberus wrote:The Samsung UE40C6000 and UE46C6000 series are shipped with 2 different mainboards using 2 different firmwares.
