Version 1.4 Media Browser cant login
guitareth
Post Sat Dec 21, 2013 3:58 pm
Installed v 1.4 today over v1.3.1. No errors, all my library entries all there etc. However, when I now try to use the Media Browser after entering my password I click login and.... nothing, nada, zip!! No error messages or anything. Just nothing happens so I cannot get into the MediaBrowser interface. :x
Have tried it using Firefox , Chrome and IE. All the same. used to work fine with previous version.
Any suggestions?
Post Sat Dec 21, 2013 5:55 pm
Re: Version 1.4 Media Browser cant login
are there any javaScript errors in the browser's JavaScript console when you try to log in?
Post Sat Dec 21, 2013 9:46 pm
Check the console to see if your password is still there.
guitareth
Post Sun Dec 22, 2013 12:04 pm
Solved it. I was using Roboform password filler to fill in the password field in all 3 browsers. That worked before but not with new version 1.4. However, if I instead manually type in my password the login button turns yellow and I can login OK. Good if you could fix the Roborform prob but not vital.
Meanwhile, I'd copied and pasted following results from java conole so just in case they help you..............
zip wrote:are there any javaScript errors in the browser's JavaScript console when you try to log in?
This is what I get in the Java Console with Firefox (my preferred browser) when I load the page, enter password, click "Remember me" and click "Log In":
12:48:48.537 GET http://localhost:23424/mediabrowser/#/login [HTTP/1.1 200 OK 11ms]
12:48:48.538 GET http://localhost:23424/mediabrowser/ass ... -1.4.0.css [HTTP/1.1 200 OK 89ms]
12:48:48.538 GET http://localhost:23424/mediabrowser/ass ... r-1.4.0.js [HTTP/1.1 200 OK 108ms]
12:48:48.612 Unknown property 'background-position-x'. Declaration dropped. MediaBrowser-1.4.0.css:1
12:48:48.612 Expected media feature name but found '-webkit-min-device-pixel-ratio'. MediaBrowser-1.4.0.css:1
12:48:48.612 Expected media feature name but found '-o-min-device-pixel-ratio'. MediaBrowser-1.4.0.css:1
12:48:48.612 Expected media feature name but found 'min-device-pixel-ratio'. MediaBrowser-1.4.0.css:1
12:48:48.612 Expected colour but found 'none'. Error in parsing value for 'background-color'. Declaration dropped. MediaBrowser-1.4.0.css:1
12:48:48.614 Error in parsing value for 'word-break'. Declaration dropped. MediaBrowser-1.4.0.css:1
12:48:48.614 Unknown property 'user-select'. Declaration dropped. MediaBrowser-1.4.0.css:1
12:48:48.710 Unknown property 'box-sizing'. Declaration dropped. mediabrowser
12:48:49.751 GET http://localhost:23424/mediabrowser/ass ... -shape.png [HTTP/1.1 200 OK 5ms]
12:48:49.752 GET http://localhost:23424/mediabrowser/assets/img/logo.png [HTTP/1.1 200 OK 89ms]
12:48:49.753 GET http://localhost:23424/mediabrowser/ass ... e15x15.png [HTTP/1.1 200 OK 88ms]
12:48:49.754 GET http://localhost:23424/mediabrowser/ass ... adient.png [HTTP/1.1 200 OK 91ms]
12:48:48.812 Password fields present on an insecure (http://) page. This is a security risk that allows user login credentials to be stolen.[Learn More]
12:48:49.755 GET http://localhost:23424/mediabrowser/ass ... -shape.png [HTTP/1.1 200 OK 85ms]
12:48:49.756 GET http://localhost:23424/mediabrowser/ass ... ogo-hd.png [HTTP/1.1 200 OK 81ms]
12:48:49.757 GET http://localhost:23424/mediabrowser/ass ... eckbox.png [HTTP/1.1 200 OK 85ms]
12:48:49.758 GET http://localhost:23424/mediabrowser/ass ... yellow.png [HTTP/1.1 200 OK 101ms]
12:48:49.006 Use of getPreventDefault() is deprecated. Use defaultPrevented instead. MediaBrowser-1.4.0.js:8
12:48:55.392 GET http://www.google-analytics.com/__utm.gif [HTTP/1.1 200 OK 91ms]
12:49:11.856 GET https://phx-sync-3-3-0.services.mozilla ... ollections [HTTP/1.1 200 OK 940ms]
12:49:12.818 POST https://phx-sync-3-3-0.services.mozilla ... orage/tabs [HTTP/1.1 200 OK 258ms]
If I do same in Google Chrome, all the console says is:
event.returnValue is deprecated. Please use the standard event.preventDefault() instead. MediaBrowser-1.4.0.js:8
For IE10 afraid I cant find how to bring up the java console.
Users browsing this forum: Baidu [Spider] and 21 guests
