Help file mkv Samsung PS50C6500
• Page 1 of 2 • 1, 2
Hello ... with the new 0.5 Serviio mkv files are not supported, you know the reasons? Thanks
Re: Help file mkv Samsung PS50C6500
do you have the proper profile for your TV selected?
Petr
Help translate Serviio
i have same issue ZIP mkv file dont work on samsung C series profie
Yeah I couldn't get it to work either. I went back to 0.4.2 for now and it works great, though I loose some neat new features like the folders stuff.
Can somebody compare the logs from those 2 versions when you play MKV? or post them here for me to have a look.
Petr
i cant even get MKV added to teh library let alone play them on v0.5 will uninstall and install 0.4 tmorrow and try that for you tho.
lol i think i may call this forum home i spend so much tiem here LOLOL
They are not added? that is weird. Post ffmpeg -i pls.
That's cool with me as I can spend more time developing
Petr
zip wrote:i cant even get MKV added to teh library let alone play them on v0.5 will uninstall and install 0.4 tmorrow and try that for you tho.
i renamed it TEST to save me actualy typing its full name i was bein lazy lolol
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i F:\test.mkv
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 011dbd80] max_analyze_duration reached
[matroska,webm @ 011dbd80] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 500.00 (500/1)
Input #0, matroska,webm, from 'F:\test.mkv':
Duration: 00:42:04.59, start: 0.000000, bitrate: N/A
Stream #0.0: Video: h264, yuv420p, 720x576, PAR 64:45 DAR 16:9, 25 fps, 500
tbr, 1k tbn, 50 tbc
Stream #0.1: Audio: vorbis, 48000 Hz, stereo, s16
Stream #0.2(eng): Subtitle: dvdsub
zip wrote:lol i think i may call this forum home i spend so much tiem here LOLOL
fine by me
there is Vorbis audio, which is not recognized by Serviio - that's why it's not added.
Not sure why it was working for 0.4.2, the only possibility would be the older FFmpeg would detect the audio as something else.
Petr
zip wrote:there is Vorbis audio, which is not recognized by Serviio - that's why it's not added.
guess you need to add it to serviio then dont ya bro
Can you confirm with MediaInfo that it indeed is Vorbis track?
Petr
not yet but i can do that today sometime if i get a chance atm im making a version of linux sepcifly designed just run run serviio that can be installed and will work right out of the box
Same problem here (Samsung LE40C550 + Snow Leopard). Unfortunately I cannot report the ffmpeg -i info since I already reinstalled version 0.4.2 (which works nicely).
Thanks for writing Serviio. It is the only program which works nicely with my Samsung TV under OSX. Probably not the best place to write this but here are some suggestions to make it even better:
* The FF RW buttons don't seem to work. Same for resume-play and subtitles/audio tracks within mkv files.
* Automatic subtitle download. This would kick ass, after having a a dlna TV + serviio, this is the only thing I still have to do manually.
* It would be awesome to be able to play internet streaming content through the tv (flv files, youtube videos etc ...)
I was thinking about this a while back. OpenSubtitles have API and support movie hashing, so it could be quite precise. Might do that if there is enough demand for his.
Aiming to provide this for 0.6
Petr
This doesn't seem like a difficult feature to implement (especially considering that Serviio already scans the movie collection for tagging and obtaining screenshots/artwork). Is serviio's source-code available?
aacosta wrote:I was thinking about this a while back. OpenSubtitles have API and support movie hashing, so it could be quite precise. Might do that if there is enough demand for his.
its plain java just open the jar files with winrar...
I am well aware about java bytecode being easy to decompile. I'm not sure if you are encouraging me to decompile the class files in the jars and modify serviio based on the resulting source code, but I didn't have any reverse engineering in mind. I was just asking if the full code was available somewhere, with comments, building system etc ...
zip wrote:* It would be awesome to be able to play internet streaming content through the tv (flv files, youtube videos etc ...)
One question - would in such a system search be possible - this would require user input, that is, communication from TV->Serviio?
D.
dalanik wrote:zip wrote:* It would be awesome to be able to play internet streaming content through the tv (flv files, youtube videos etc ...)
D.
Probably not.
Petr
