Transcoding
• Page 1 of 1
I am new to Serviio but after looking through some forum message, there is a bit of confusion on my part. Somebody mentioned turning off Transcoding for a specific file, I don't see a way to do that. Also how do you have a different Transcoding Profile? I see none of this in the console.
Re: Transcoding
See http://www.serviio.org/component/conten ... ng-started particularly the bit on Renderer Profiles which will answer your question on setting Transcoding Profile.
You can turn transcoding off by either selecting the Generic DLNA profile (this profile doesn't include transcoding) or turn it off in Serviio Console (Delivery tab from memory).
Re: Transcoding
So turning off transcoding would be setting it to what? There is no setting for Off.
Re: Transcoding
On the Delivery, Transcoding tab there is a tick box labelled "Enable Transcoding". Untick it and press Save.
Re: Transcoding
Re: Transcoding
tried to playing with settings in online transcoding section of profiles... ignored in 1.4 ?
Re: Transcoding
Not afaik. What is it that you are trying to do/fix?
Re: Transcoding
my mistake. works ok, but stream that I watch online changed from rtmp to rtsp so I needed to add rtsp line to online section of profile... works ok.
• Page 1 of 1
Users browsing this forum: No registered users and 50 guests
